Question about Toshiba TEC B-472 Thermal Label Printer
Why is the ribbon sticking like static to the 4 x 6 labels? It worked fine yesterday , but this morning I have this issue
    Champion:
  • 254 Answers
You may be working with the parameter direct thermal or the rewind motor is out of order
Posted on Aug 04, 2011
Printer printer duplicate labels
i have the same issue, this case happened when out of paper or ribbon, while this program and label form works fine with the zebra printer
Oct 18, 2012 | Intermec EasyCoder PM4i Label Printer
I have a Zebra 105Se zebra Printer for testing. When a label is printed it just prints 1/4th of the label,then the printer stops and paper/ribbon light,Pause light and data light is on.When I open the...
Make sure that both ribbon and media paths are clean (no glue, or sticked labels). Make shure the ribon and the media are corect installed on their paths.
Sep 23, 2011 | Zebra 105Se Thermal Printer
How do I shut off the auto calibration on start-up? Every morning 1 am wasting 4 labels and ribbon for calibration.
Can only be done by sending a ZPL command. The ZPL manual can be downloaded from the Zebra web site.
Apr 28, 2011 | Zebra Stripe S600 Thermal Label Printer
I keep getting wrinkled ribbon in my zebra XiIII printers Part seems to be caused by static, the ribbon will not rewind properly
Its probably not static. 1. Wipe the print head and platen roller with alcohol dampened qtip or lint free cloth. Print about 30 labels while gently pressing on the ribbon supply, causing it to drag a little and observe if the wrinkles stop. If so tighten the nut on the end of the ribbon supply a little at a time until wrinkles disappear. Check the head pressure toggles on top of the print head and make sure they are adjusted about the same. If you have been printing a lot of the same size labels, check the platen roller (white) at the point where the right edge of the label rides on it for a slight offset where the roller is worn down. If it is worn, the only fix is to replace the platen roller.
Feb 17, 2011 | Zebra Xi Series 170XiIII Thermal Label...
Hi, my printer is printing blanks. Windows XP, Zebra ribbon I replaced the ribbon and still no luck. I tried setting the darkness to maximum, but that didn't work either. I tried the "dump"...
The zebra ribbon has ink on one side and the other side has a backcoating which protects the printhead. simple way to check is to peel off a label and momentarily stick to ribbon and remove. This will show you which side is inked.
If ribbon is installed correctly then reset the printer and re-calibrate it. 1. install labels and ribbon 2. power on printer. If you have a solid green light on then 3 turn printer off. 4 hold down feed key 5 power printer on and after 2 seconds release feed key. printer will perform a calibration routine and eventually print out status page. IMPORTANT 6 Hit Feed Key once more. Printer will display Out Of Dump message. Your printer has now been sucessfully calibrated.
May 06, 2009 | Zebra LP 2844 Thermal Printer
Zebra 105SL label issues
I am surprised that you are using that sequence of buttons to solve this problem. I am pretty sure that they want you to go into the "Media Sensor Calibration" setup in the config menu. It is a bit more complicated than what you have described. I also believe that the size of the gap on two of your labels might be out of tolerance (they are usually 1/8" gaps between the labels). The black marks are a problem for the transmissive sensors. You may need to move the transmissive media gap sensor (remember it has two parts: upper and lower). I would usually setup mine for a place beyond the black mark so that you are looking at just the white paper.
To start out:
1. Load the backing of a 6" strip of media (no label attached).
2. Remove a ribbon (if you usually use one).
3. Close the printhead.
4. Press SETUP/EXIT and then NEXT/SAVE until "Media and Ribbon Calibrate" appears.
5. Press "+" to start the calibration procedure. You should see the "Load Backing" in the LCD Display. You already have the backing loaded so continue to the next step.
6. Press "+" to answer the message and the next screen should say, "Remove Ribbon". You have also removed the ribbon.
7. Press the "+" to continue. You should see the screen say, "Calibrating Please Wait". After the sensors are setup by the machine a new screen should appear, "Reload All".
8. Open the printhead, and move the labels until they are loaded correctly to print. Smooth out the ribbon and load it correctly.
9. Withe media and ribbon now loaded, press "+" to continue and the machine should say, "Media and Ribbon Calibrate".
10. Press the Setup/Exit button once. It should say, "Save Changes Permanent". Press Next/Save to finish the process.
11. Do a normal calibration of your stock and print a label.
You are done. The machine will run for the labels you have setup the sensors for. Unfortunately, you must do this for each of the media types. To automate this, you could run a Configuration listing, capture the settings you just created for each type of label. Take these to a programmer to have them send the setup to the machine before the job. This is beyond the scope of this type support to really help you.
May 13, 2008 | Zebra 105SL Thermal Label Printer
Labels sticking to ribbon
If I had a guess...this label material sounds old or stored improperly...possibly to much head pressure....I would suggest some known good material and retry.
Mar 07, 2008 | Zebra Z4M Printer
Paxar 9855
If you have not found an answer to your issue, you may wish to call their tech support at monarch.com.
Labels are supposed to come off the liner, but if you have the supplies or ribbon loaded incorrectly, or if you have adhesive coming in contact with the ribbon before the media indexes to the next label, I can see where the ribbon can get attached to the labels.
You shouldn't have any slack in your ribbon when the printer prints, and if you do, you may need to make minor adjustments to take up that slack.
As for a heating adjustment, I'm not sure what you mean, but there is an adjustment to increase the printhead temperature, but that is only to increase the contrast on your labels, and should have zero effect on your reported issue.
Contact monarch.com's tech support line if you find that the data in this response isn't able to guide you to the culprit.
Feb 13, 2008 | Paxar Monarch 9855 Thermal Printer
Z6M printing issue
try adjusting the presure of the printhead
here is the site for the manual
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
good luck
Dec 12, 2007 | Zebra Z Series Z6M Thermal Label Printer
Toshiba TEC B-472 Thermal Label Printer Logo
91 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
