Question about Amana Refrigerators
The frig was working great, we were giving it to the church. We unplugged it. removed the doors and took it to the chuch in an upright position. It would not work when we plugged it in, checked the outlet for power. The light in the frig comes on but nothing else. We are at a loss as to what has or could have happen. Can you help. I can not find the paper work on it and it was purchased in 1997. Thanks
    President:
  • 2,468 Answers
The ptc overload relay on the compressor is bad,unplug it from the side of the compressor and replace it,it supplies start and run power to the compressor and protects it also,get an exact replacement and plug it back on the compressor and it will again work
Posted on Apr 06, 2011
If you have a home garden, and you grow more than what you can use, what do you do with the extra? Do you give it to friends and family or do you give it to those in need by way of food pantries at...
I have too many vegetable plants in my garden and I give some of the vegetables to needy people who starve as its a great work and you should also do the same.
http://www.gardeningnorthside.com.au/tree-removal-north-shore/
Aug 26, 2013 | ValuSoft Your Complete Landscape and...
Why is my freezer working but not my frig in frigidaire upright with seperate doors
Check the rear is clean and clear. The condenser should be warm, not hot. If it cools down towards the end of the rungs and the last bit is cold. suspect short of gas.
Further check any fans etc and remove any excess ice, and make sure the door seals ok.
Aug 06, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
I HAVE AN OVER AN OVERHEAD PROJECTOR ONE OTHER CHURCH WAS DOING A PROGRAM AT MY CHURCH TYPE THERE NAME ON THE PROJECTOR AND THE NAME OF THAT CHUCH IS ENBEDED ON TE PROJECTOR: HOW DO I GET IT OFF
Go to the menu settings & change the display logo back to factory or press reset to factory original settings. The other church simply put in their logo.
Apr 14, 2011 | Dell 1209S DLP Projector
My back windows won't go back up... Is it a fuse?
this might be hard to explain,
since you have the door panels off,you a test light at the window rocker switch,one wire will be hot all the time,probe one of the other wires with the test light and try the switch up and down,one wire will have power when you try the up position and the other will have it only in the down position, if this check shows no power to one side of the switch,your problem is the switch. if you get power to both wires up and down your problem is the motor.
Nov 23, 2009 | 1992 Dodge Dynasty
Line and air flow box between freezer and frig freezing up, we took apart, defrosted . air comes into frig, but still not cool enough. freezer works great This is a side by side model # ED25PWXAN01
If the fan is running in the freezer compartment, temperatiure is normal, and no frost is building up on the back panel in the freezer panel, then there is a good chance the return air shutes in the fresh food compartment are blocked with ice. The return ducting is just as important as the the supply shute which you melted out. Difficult if not impossible to see.
My recomendation is to empty, unplug and air dry the whole machine preferably with a fan blowing air into the fresh food compartment.
Haste makes waste with this machine. Using heat can cause the plastic shutes to melt and distort.
Should be defrosted in this manner for 24 hours.
Restart and give the machine 24 hours to recover. Common problem with Whirlpool products.
P.S. Check to see if lights go out when closing fridge door. In fact this should be your first step. Jack
Nov 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Upright frig/freezer not getting cold, compressor running
1.My first suggestion, is to clean out the compressor area located at the bottom of the refrigerator. Refrigerator unplugged from power. Remove the cardboard panel from the bottom, (Watch the water line), and use a vacuum. I also bring the refrigerator towards an open door, and use compressed air to blow it out, afterward. You'd be surprised how much gunk builds up here, and how cleaning it out will help your fridge tremendously! (Good tip for air conditioners also. Power unplugged, case cover removed. Use a garden hose to flush the fins out. Let it dry, reinstall the cover) 2.Your refrigerator may be low on Freon. This requires a professional to purge the system, and reinstall Freon and lubricant. (Oil)
Jun 15, 2009 | Whirlpool ED5VHGXM Side by Side...
Freeze will not freeze.
I had a similar problem. The frost in the back is an indication that your coils are frozen. This could be from food packages falling out of the freezer drawers in the back and blocking the air circulation vents or maybe the freezer door was not closed completely and letting moist/humid air in and freezing the coils.
For me it was the first problem listed.I had to completely empty the freezer and Frig. and take the back panel off in the freezer. There you will see the coils and lots of ice!
1. Remove all items from the frig. and freezer and unplug frig.
2. Pull all the freezer drawers out.
3. On my GE side by side I took the light cover off and removed the bulb. There you will see two panel screws. Remove the screws.
4. Now pull out the mouldings on each side and you should be able to remove the panel.
5. Take a hair drier and completely defrost all the ice from the coils.
Be sure to keep plenty of towels handy for all the water mess. Remember to keep an eye on the drain tray in the back of the frig. and use a sponge to collect the water that will build up.
Hope this helps!.....
Woody
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer has frost in back- frig not coolling
You have a defrost parts issue.
Unplug the fridge. Remove the back freezer panel and check the defrost heater and defrost thermostat.
Without a model number I can not tell you where the defrost timer is.
Mar 04, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer not working
I have a Kenmore Freezer model # 253.9251310 serial # s510347256
10\95 Makes all kinds of noises and now is defrosting. Sounds like fan is working but no noises besides fan. any ideas
Dec 12, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire upright freezer and frig with freezer on top
it might have low volatge to compressor and burned out overload try unplugging it again wait a few hours and plug it back in it might start working good luck if it doesnt try replacing relay overload compasator they sell a kit called a 3 n 1 start kit
Aug 27, 2007 | Frigidaire 14.1 cu. ft. Upright Freezer...
Refrigerators Logo
48 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
