Question about Coffee Makers & Espresso Machines
I have a rancilio miss kathy unit the water is very slow coming out not enough it just steams
unclebuck521
SOURCE: water will not come through the steam wand
I had the same problem. I took the steam wand off, and checked for steam out of the unit. It was OK, so I stuck a thin wire up through the steam wand and dislodged what look like pieces of a green washer or O-ring.
In short...the wand was plugged.
Posted on Feb 03, 2009
EsWorld
  • 1618 Answers
SOURCE: tripping high temp cut out
The temp on the machine is set by one of the 3 thermostats on the boiler, check resistance and replace the faulty thermostat.
Posted on Mar 25, 2009
z34aga
  • 137 Answers
SOURCE: leaking steam valve rancilio miss audrey
you should take out the knob first, than you try to disasembke the SHAFT of valve from the valve body, in this types(small espresso coffe machines) usualy producer use conical valve, without seals she close metal to metal, when you get out the SHAFT you will see one line on the conical end. for repairing it will be enough to visit one metal vorkery where they will take a small amount of brass from end and polish it. then you put it back and work again with your machine.
ps: notice you only polish the SHAFT , dont let them to short the more than 0.5 mm
Posted on Apr 02, 2009
EsWorld
  • 1618 Answers
SOURCE: My Rancilio Epoca E1 espresso machine has no steam
It is possible that the reset connected to the boiler tripped.
Posted on Sep 29, 2009
EsWorld
  • 1618 Answers
SOURCE: Rancilio Silvia: The steam works only for about 10 seconds
Remove the top panel and check the 3 thermostat on the machine one of them is not functioning properly, find the wire to the steam switch and trace it to the thermostat.
Posted on Jan 27, 2010
Rancilio coffee machine .no water coming out of the group head . steam coming of the group head
Hi Ewah,
If you are getting steam from the group and no water when you turn on the water button - then you may have a group blockage.
The fix depends on the type of machine you have.
If it is a commercial type - then call in a qualified coffee technician.
If it is a domestic type like rancilio sylvia, the you could try to descale - maybe too late, but worth a go.JURA descaling tablets
If when descaling, no water is coming from the group try leaving the steam tap open when asking for water.That way you may get the descaler liquid moving inside the boiler and it may clear the solenoid valve blockage.
If no joy with that you may need to replace solenoid valve.
230V 9W PARKER SOLENOID
Domestic machines need regular descaling to avoid group blockages.
Mar 18, 2017 | Rancilio Coffee Makers & Espresso Machines
Descaling rancilio
Use Citric Acid.
  1. Dissolve about one tablespoon of citric acid in the water reservoir.
  2. Fill the boiler completely. Open the steam valve and start a hot water cycle until water comes out the steam vent. Stop the hot water cycle, close the vent.
  3. Let the boiler heat up about 5 minutes. Then turn off the power.
  4. Let the acid solution work for about 1/2 hour.
  5. Pull a 30 second shot to change the water in the boiler.
  6. Repeat flushing cycles (steps 3, 4, & 5) until the water looks clear. Refill the reservoir with water and acid as needed.
  7. Wash out the water reservoir.
  8. Pull 5 or shots to get the acidic water out of the boiler. Run a hot water cycle to clean the acidic water out of the steam vent.
  9. Let the unit come to temperature and look for leaks.
  10. Make some coffee and look for leaks.
  11. Froth some milk and look for leaks.
Jan 18, 2014 | Rancilio Audrey
Hi - I have a new Rancilio that I just opened today. Steam is coming but not enough water for a brew
maybe is just air in pump,try prime water on steam wand.open steam valve and press button for make espresso,keep couple seconds
Jul 07, 2009 | Rancilio Silvia Espresso Machine
Good morning; i have a H-330 INSTAND water heater
the low voltage may cause the unit to over heat when you dont have enough volts the amps go up .i have also seen units that are working fine dribble water due to expansion of water when heated
Apr 14, 2009 | Emerson Water Heaters
Leaking steam valve rancilio miss audrey
Apr 01, 2009 | Rancilio Audrey
Rancilio miss silvia dispenses cold water
If there is steam in the machine, the only other problem would be if the portafilter was cold and you are brewing into metal or glass demitasse that has not been heated.
Jan 12, 2009 | Rancilio Silvia Espresso Machine
Tripping high temp cut out
Jan 11, 2009 | Rancilio SILVIAespresso&cappuccino machine
Water will not come through the steam wand
Dec 07, 2008 | Rancilio Silvia Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
