Question about Sewing Machines
I have a Toyota Model 501a. I am having trouble getting the bobbin in place. Can you help me?
2 Suggested Answers
  • 13 Answers
SOURCE: Model # 385,11206300 Having troube getting the
go to sewusa.com they have threading diagrams showing how to use the bobbin winder.
Posted on Mar 05, 2010
Are the bobbin winder rubber rings universal
Well, instead of going to all that trouble, why not buy an inexpensive bobbin winder? They're available on Amazon and eBay, as well as many other places, for about $25.00, and it's my opinion that they do a better job anyway.
Feb 24, 2017 | Singer Sewing Machines
How do i install a bobbin in a toyota rs2000 please
Your machine has a removable bobbin case and vertical rotary hook (front loading) so it is very alike to many other machines in that you insert the bobbin into the bobbin case in a clockwise direction, pull the thread into the tension spring on the case, then place the case into the front of the rotary hook while pulling out the little latch on the case, then release it to secure into the rotary hook. The latch usually goes into the "12" position on the rotary hook, there should be a little indentation for it.
If you go to this page https://sewing.aisin.com.au/upload/1255582851068_file_RS2000SD2D3D.pdf you can download Toyota RS2000 manual and full instructions and drawings are there about page 8.
If you go to www.sewing.about.com, http://sewing.about.com/od/sewingmachineindex/ss/windbobbin.htm there is lots of helpful sewing machine pages too, general threading up, trouble shooting and getting the right needle for the job. How you wind the bobbin is important and you need to put it into the bobbin case the right direction so the thread comes off the bobbin then reverses direction through the tension spring.
Great video on You tube too which should help you http://www.youtube.com/watch?v=KHl-j4pYx4I
visually its so much easier than trying to describe the steps. But once you've mastered a bobbin case and bobbin system, they are all very similar between makes and models.
Jul 25, 2011 | Sewing Machines
I'm in trouble deep-I was trying to fix an old
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Toyota SE-06 Mechanical Sewing Machine
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
Good day!
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
Good day!
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
Need bobbins
Bobbins are freely available in a variety of places. If you don't have a sewing specialty shop handy, there's always the internet. eBay is a good place to start. Also you could Google search for "bobbins (your brand and model of machine)" you should find some without any trouble. I live in Australia and have bought bobbins from the USA at very cheap prices and the postage costs were extremely small.
Oct 08, 2010 | Husqvarna Designer I
Bobbin trouble
Remove the needle plate for better access and try using a seam ripper to gently cut the threads and continue to remove with the tweezers.
The needle plate is the metal plate under the presser foot and is held into place with at least two screws.
The bobbin fits into the bobbin case.
The bobbin case fits into the bobbin shuttle.
Once you get the jam cleaned away, raise the needle to it's highest position and remove the bobbin case and/or replace the bobbin case.
Jamming can cause the machine to be out of time.
If you thead the machine with the presser foot up, have the bobbin inserted into the bobbin case correctly and the stiching is loose and loopy the machine may need to go into the shop for service.
May 01, 2010 | PfaFF Hobby 4260
Feb 27, 2010 | Sewing Machines
Needle does not pick up thread from bobbin
rethread the bobbin and/or check the bobbin is placed correctly, rethread upper thread
Feb 11, 2010 | Sewing Machines
Sewing Machines Logo
67 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
