Question about Husqvarna Prelude 370 Sewing Machine
I have a Husqvarna Prelude 370; only just started using it. The reverse button seems to have got stuck; I cannot get the machine to sew forwards anymore. Can you please help me? Tnx! kind regards, Josephine. josmarwe@hotmail.com
  • 3 Answers
SOURCE: MACHINE SEWING IN REVERSE
If you have located the reverse button and pressed it once - this should shut off that feature. If this does not, then I am afraid you are going to have to take it in to be reprogramed. Any local shop that is familiar with Husky should be able to help you out. Good Luck!
Posted on Nov 19, 2007
SOURCE: reverse only?
I too just aquired a husqvarna viking 6030 that was stuck in straight-stitch reverse. No forward, no zig zag, no button hole, no cam stitches. I also suspected a broken spring, since the reverse button was slack and had no resistance. But after inspecting every moving part, I realized it was just stuck from many years of non-use. I finally got it free today! I had used some Tri-Flow oil and applied it sparingly to all moving points (but not belts or motor). I exercised all the buttons and like another poster (either here or elsewhere, not sure) I used my hair dryer to apply heat to the inside of the machine through the cam slot. After you remove the white cover on back of machine that holds the two spool spindles, you will see a formed aluminum part just behind the reverse dial that has a rounded-pointed protrusion which sort of looks like a fat flat head screwdriver. It is supposed to travel in an up-down motion when reverse button is pressed. I used a flat head driver to coax its movement, and once it began moving, I continued with heat and drops of oil. Good luck.
Posted on Feb 04, 2008
  • 323 Answers
SOURCE: reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Posted on Jun 05, 2008
  • 188 Answers
SOURCE: needle stuck in right position, will only sew tiny,tiny stitches
oil it. down the shaft if you can get to it. and where ever there is a hole it always helps.
Posted on Mar 26, 2009
  • 192 Answers
SOURCE: My Husqvarna Prism 990 only sews in reverse.
You could have an electronic problem on the main printed circuit board or in the feed length stepper motor. You may also just have a bound section in the feed mechanism. I don't think there is a cure all answer for this problem.
A 1/2 second hesitation between depressing the foot control and motor response is very common in these machines
If your husband lubricated the bushings on the upper and lower shafts of your 990 I recommend that you have him remove all of the lubricant possible and keep your fingers crossed. The 990 is a self-lubricating machine and applying machine oil to these bushing will probably cause them to seize. The 990 should never be lubricated in many of the places you would lubricate many machines. Hopefully, you haven't done irreparable damage.
Posted on Apr 23, 2009
I can't return to normal stitching after using buttonhole function on Husqvarna Prelude 370. Top thread fails to catch & bobbin thread continues to gather as if it is still in buttonhole function.
You might try turning the machine off and unplugging it for about 15 minutes. That may reset it. Also, consult the owner's manual for troubleshooting issues.
Oct 11, 2015 | Husqvarna Sewing Machines
How can i have a manual for Husqvarna Prelude 370?
contact this number and ask them about a manual for the machine
Call a1sewingmachines.com
518)469-5133
Aug 18, 2013 | Husqvarna Prelude 370 Sewing Machine
Won't operate. Won't go forward or in reverse, happened all of the sudden. Hand crank fine, but the whirring sound comes from that area.
it's possible that something in the machine has come loose or broken
it would have to be serviced at a sewing machine shop
Sep 23, 2011 | Husqvarna Prelude 370 Sewing Machine
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Reverse sewing button stuck HELP!!
The mechanism requires lubrication from the back, would be best to have machine serviced.
Jun 30, 2008 | Husqvarna Viking 1
sewman7
Jun 03, 2008 | Husqvarna Viking 1
Reverse only?
Nov 11, 2007 | Husqvarna Viking 1
Husqvarna Prelude 370 Sewing Machine Logo
52 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
