Question about Maytag Bravos MTW6600T Top Load Washer
Maytag Bravo washers is staining my cloths.......any thoughts on what may be causing this?
    President:
  • 2,468 Answers
The upper transmission seals bad its under the tub agitator and letting oil into the water called "wash back" you need to replace this seal and stains will disappear
Posted on Apr 06, 2011
I've also had this problem when using fabric softener...
Posted on May 06, 2013
A407 maytag washer getting grease on clothes occassionaly what would the replacement part
Maytag washing machine gets grease on clothes ... - Fixya
www.fixya.com/.../t14582529-maytag_washing_machine_gets_grease
Oct 8, 2012 - Maytag washing machine gets grease on clothes occasionally. ... some of their clothes ruined by grease stains from their front loader Kenmore. .... remove the agitator from a Maytag washing machine Model A407 series 02?
Aug 24, 2015 | Maytag Washing Machines
Ol code cabrio
"oL" error code, even when unloaded - Fixitnow.com
fixitnow.com/.../whirlpoolkenmore-cabrio-and-maytag-bravo-washers-th...
Sep 18, 2010 - The "oL" error code in the Cabrio and Bravo washers means the ... is almost always caused by using non-HE detergent in this washer- see this ...
Aug 17, 2015 | Washing Machines
CLOTHES COMING OUT OF WASHER WITH DARK STAINS
Hi Lynn, this is AP.
I understand you are seeing stains and lint on your clothes once removed from your top load washer, model FWS833A. There could be several culprits causing this to happen. To confirm, are the stains not being removed during cycle or do you believe the washer is the cause of the stains? If you believe the stains are being caused from the washer it could possibly be undiluted liquid fabric softener poured directly on fabric. Something more serious could be a broken transmission causing oil to leak in the tub.
There are some basic troubleshooting tips for lint to check such as undissolved detergent can leave residue on clothing. Separate clothing items which shed lint from items which attract lint. Permanent press, synthetic, knit and corduroy items will pick up lint from towels, rugs and chenille bedspreads. Make sure to Use correct amount of detergent, water temperature and water level.
There are some simple troubleshooting tips listed above and in your owner's manual, if you find they do not resolve your concern I would recommend contacting a local authorized technician to inspect the washer.
Thanks,
Mar 30, 2014 | Frigidaire FWS833A Top Load Washer
Washer makes stains on clothes
same thing happened in mines i put it though a hot wash with no clothes or washing powder it seemed to do the trick
Mar 16, 2012 | Maytag PAV2300 Top Load Washer
Maytag bravo mvwb750wq 28"
Have you tested the lid switch, if it is not making the washer will not spin. try using a pen or small bladed screwdriver to depress on the switch to see if you hear it clicking, although sometimes it wont work even if it clicks when they go bad. The washer should work as normal till it gets to the spin cycle, then without the lid switch working it won't go any furthur. You can try jumping across the leads to see if this gets it to spin and this will tell you if the switch is bad or not.
Mar 08, 2011 | Maytag Washing Machines
I'm getting small orange spots/stains on my clothing after washing them in my Maytag washing machine. it is a 2010 machine too. Any thoughts as to what could be causing the stains?
Unless there is a child's crayon or something similar causing it, then suspect that the agitator shaft seal, or the drum seal is leaking oil into the drum. Hopefully, there is still warranty on the machine. Good luck!
Jan 10, 2011 | Maytag Centennial MTW5800TW Top Load...
Washer leaves oil type stain on clothes.what could be cause?
Stains on clothes from this model of washer are usually caused by the door boot or the tub bearing going out. I recommend cleaning off the surface of the door boot and if you still get stained clothes I recommend having the rear tub & basket checked. I am also sending you more troubleshooting tips in the image below.
Dec 31, 2010 | Kenmore 98702 Stacked Washer/Dryer
Grease stains from Maytag MAV7200AWW washer
HI! I just posted a question to "justask.com" and am having the exact same problem. I paid $9 for this answer and was happy to pay it because I now know what it is! From what I have been told, it is from the transmission in your washer and will cost at least $400 to fix it (that's just a ballpark figure... I have a Frigidaire and that was the figure I was given). So, basically, it would be more cost effective for you to purchase a new washer.
Apr 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis black oil like residue and can't remove agitator
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
this is a very common happening and it means
This usually means that a seal is degrading or dissolving.
This washer is a top loader, Right!
I believe it calls for HE ( High Efficient) laundry detergent.
If we use to much of either it will cause this !
This usually happens due to using to much detergent or bleach.
You said, Black oil like residue discharged from washer during use. Stain clothes, almost impossible to remove. Loosened nut on agitator but it will not budge, and am afraid of damage if I try to pry between agitator and bottom of drum.
Please remember to leave a rating before you go!
Thank you
Sep 20, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Stains on clothes
yeah if the seal has gone even slightly then it will send grease out 1 way to check if the bearings are on there way out is pull the washer out take the back panel off and look in to see if there are any green spots on the back off the washer if there is then there on there way out another way is to place your palm on the front of washer place your fingers into the drum and pull your fingers up if there is movement then there going m8
Feb 09, 2008 | Washing Machines
Maytag Bravos MTW6600T Top Load Washer Logo
790 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
