Question about Technics Audio Players & Recorders
Technics SU-X9920D amp cuts out due to overheating unit gets very hot fan motor has been replaced there is also scorching to the PCB
    Brigadier General:
  • 8,546 Answers
Keep a fire extinguisher handy and never walk away from it while it's turned on.
If you're NOT overdriving it and it has sufficient all around clearance for coolign airflow you should take it to a competent technician for evaulation before you burn the house down.
Posted on Apr 06, 2011
Technics su a900
I have the same TECHNICS SU A900 MKII as you are talking about and it always runs warm I think using 4R speakers instead of 8R speakers should solve the problem and actually I am thinking of switching to 4R as well.
Oct 13, 2013 | Audio Players & Recorders
Why does stereo amp cut out at higher volume
You seem to have the answers to your question. I would just resolder the connections anyway without checking. If it solves the problem you have saved yourself a lot of money. If it doesn't follow the other steps in order of cheapness!
May 03, 2013 | Audio Players & Recorders
Technics SU-V 450 power prob
output ic shorted out most likely....thats the big unit mounted to the heatsink...may be obsolete...I have su series integrated amp and cannot find parts for it...good luk
Jan 17, 2012 | Audio Players & Recorders
I have a technics su-g75 amplifier, this system hasn't been hooked up for a few years but seems to be in excellent condition. It plays and seems to work great. I don't know whether this is a problem or...
Yes the unit will get fairly hot. If you can keep turning it up at some point the fan should kick in, if it doesn't then it need looking into further.
Apr 23, 2011 | Technics SC-DV290 System
Fan quit working. Is it likely the board, or the fan? Currently have a Radio Shack fan mounted; it's 120v, plugged into the AUX power on the back of the unit. It's noisy, otherwise unit works and runs...
Hi, Have got and still use a Technics SA-GX910 Dolby Amp. It had an overheating problem too due to Air temp and power drain etc and the internal fan only engaged at certain volume level. Overheating was overcome by adding another internal fan.
Your unit however might need a bit more of a fix-me-up or throw it away
Oct 09, 2010 | Technics SA-DX1040 Receiver
Technics amplifier su-v98, cuts off at 22-24 desibls
The most common cause of this is defective coupling caps inside. These allow some DC voltage to pass through to the final amp stage. This DDC voltage is detected by the protection circuit and the unit shuts down. This unit will require service. Please note that this should be a simple and inexpensive repair. The cost should be less than $10 for parts.
Dan
Jul 04, 2009 | Technics SUV500 2-Channel Amplifier
Su-g91
Have you checked the fuse in the unit?
Aug 31, 2008 | Technics SA-AX540 Receiver
I have a technics su x502 amp & it works for a while then goes off & then comes back on after about 5 mins,the rest of hifi stays on its just the amp.
take out the cooling unit (the fan) and use a cpu fan out of a pc connected to an external power source like a 12v dc/ac adaptor and use it to blow constant cool air through the hole onto the heat sink. i know it sounds like a ruff job but it does work, my amp doesnt even get hot and it plays all night long without cutting out once. you will get noise from the fan constantly on but i just turn it up louder. this is just a ruff quick fix.
Aug 09, 2008 | Audio Players & Recorders
Over heating
make sure there is nothing within several inches of it to start off. if need be, use a small house fan pointed at the amp to help cool it, if all else fails and/or you don't want to hear the noise from the big fan; get a computer fan the same size as the one in the case. connect it in place of the fan that does not work(may have to cut/splice the wires). that should work. oh, check the voltage and whether the fan is AC or DC from the stereo. this makes a huge difference!!!! if the fan says "DC" DO NOT CONNECT AN AC FAN TO IT!!! the fan will short and BLOW UP!!!
May 19, 2008 | Audio Players & Recorders
Sound cuts when volume is turned up
check that power amplifier rating(how many watt)must be more than total speaker rating by 20% at least..
exampel:if speakers watts are 100 watt-amplifier watt must be 120 watt.
Mar 14, 2008 | Technics SUV500 2-Channel Amplifier
75 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
