Question about Pioneer Car Audio & Video
How to set the cd player
  • richny26 Aug 08, 2008
    I Have A Pioneer DEH-P5900IB
    Problem Solver:
  • 20 Answers
Please tell me the model of radio. Try messing with the main on your amp.
Posted on Aug 07, 2008
Setting the sound from my amp
I would need to know exactly what you are connecting this amplifier too. Is this going to run your subs? Your highs? Or your entire system? This amplifier may be used to run stereo and mono speaker components at the exact same time.
Mar 19, 2014 | Kenwood KAC-7204 Car Audio Amplifier
I have 2 amps instalkled in my car one is sony 1200w 2 channel amp for speakers and one is solid audio f2500d for 3 subs my sound and every thing was good but suddenly from yesterday im having trouble when...
First disconnect the CD head unit from the sub amp and see if the other amp works. If yes, the problem is the wires to the amp, the amp itself, or the subs/sub wiring. If no, the problem is the head unit--probably an internal short.
If the other amp works with the sub amp disconnected, reconnect the sub amp to the head unit, but disconnect the sub wires from the amp. Try the CD player. If the amp goes to protect with no speaker wires attached, the amp is bad. If the amp is OK, the problem is the subs or sub wires. Hook the wires up to the amp again, but disconnect them from the speakers. Try the player again. If the amp goes to protect, the problem is the amp wiring. If not, the problem is the subs. Check the impedance of each sub using an ohmmeter to determine which amp is out of spec.
Please let me know if you have questions, and thanks for using Fixya.
Jun 11, 2011 | Solid Audio F2500D 1-Channel Amplifier Car...
I have an Alpine CDE-100 and when I hooked up my subs and amp I would only get subs with radio and regular speakers for my ipod via usb and the cd player? I had a friend that use to install sound systems...
While I don't know the specifics of this head unit, I would guess that it has settings that can be adjusted for each source. You might check to see if there's a menu that allows you to turn the subs on/off for the various program sources.
Nov 08, 2010 | Car Audio & Video
Subs just rumble at higher levels...??? help!
there is a loose piece inside my 10" cozmik series. how do i get it out?
Mar 12, 2010 | Quantum Audio Cozmik QCA2300 Car Amp
I have a pioneer DEH-p3100 and I dont understand all the different levels and at what HZ to put the low high and mids at. i have (2) 12" kenwood speakers and a 600W alpine amp. I am lost when it comes to...
dude honestly you could get 101 answers for this and 101 oppinions a real person who knows what there talking about will tell you put on a sound cd with high and lows made for sound testing and play with the setting to you get the best sound to your ear every system is different even if i had the same system i would want mind different because of maybe different cars subs facing different way.prted boxes theres just to man it comes down to you having to play with it and use your headunit manual or find a printout for the basic controls so you actuall know what your changing around till you find the best sound
Jan 15, 2010 | Pioneer DEH-P3100 CD Player
No sound
hi there
on your CD deck or what ever unit you plugged the RCA wires to needs to be set on subs the radio needs to be set to put sound to your amp.....on your CD player if you press the F/function button a few times it will scroll to SW which is for the subs set this to the on position or if your CD player has a button with SW press it and turn on this feature......if this has been done......check the fuse or fuses on the amp.......if you have done all of the above check the back of the CD unit to make sure you are plugged into sub-woofer RCA or R (rear) RCA ..........sometimes people accidentally put the RCA wires into the aux input RCA,,,,,, double check this.........
hope this helps
Mar 07, 2009 | Crunch PZi1000.1 Car Audio Amplifier
Cd player plays, but no sound comes out of speakers.
first off the amp gets power straight from the battery. the amp is used to power the subs. the subs are suppose to be connected to the amp only( never the speakers).
for the second part you mostlikely killed the wires. you should get some one to look at it and check the wires. thee speakers might need to be re-wired
Jan 31, 2009 | Kenwood KDC-MP238 CD Player
Alpine subs not hitting hard
could it be as simple as bass boost??? maybe you have the subs hooked up wrong... have to have the ohms right.....hopefully this helped
Jan 26, 2009 | Pioneer GM-X962 Car Audio Amplifier
Amp on but no sound from subs
Make sure that you have a good set of RCA cables. Then make sure that you have 14 gauge speaker wire. As for amp make sure that you use 8 or 10 gauge wire. Make sure you have a good GROUND.
May 21, 2008 | Alpine MRP-F250 Car Audio Amplifier
What kind of subs, are the duel voice coil?
is just run normal series and see if you get sound, series will alwase give u sound
Jan 02, 2008 | Alpine CDA-9833 CD Player
Car Audio & Video Logo
64 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
