Question about Crosley CAWC529JQ Top Load Washer
Washer gets out of balance during the spin cycle
    Genius:
  • 1,400 Answers
Hello
Either the wash or laundry is unbalanced and moving to one side or the machine is no longer level on the floor.
Try putting in less clothes or seperate heavy from light.
Check all four corners of washing machine,while empty.For level,there should be two movable floor slider you can screw in or out to level machine.
Posted on Apr 06, 2011
  • 12 Answers
SOURCE: The washer is consistently off balance during the
Usually over a period of use the washer tends to get out of balance, and then make more noise when it get to the spin cycle. I would suggest leveling the washer and then trying it out. The best way to fix this issue is by getting yourself a water level, u can get it in any hardware store. I personally would recommend a small circular water level for this job. Place the water level on top of the washer; make sure it is in the center. Take a look at the level and see where the bubble is in the water level? Accordingly you have to lower or raise either 4 corners of the washer to bring the bubble in the water level to the center. Now you have to be very gentle and small increments when rising or lower the corners of the washer, it does not take too much to move the bubble in the center.
If the problem continues then you have to open the top cover in your case since its a top load the back cover and check inside if any of the weights are out of place. 9 out of 10 the washer needs to be leveled.
Posted on Aug 10, 2010
  • 240 Answers
SOURCE: washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Posted on Mar 14, 2009
onthejob5130
  • 640 Answers
SOURCE: Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Posted on Feb 07, 2009
sdmc73
  • 121 Answers
SOURCE: grinding noise spin cycle jumping around
what brand
Posted on Nov 29, 2008
robocop
  • 90 Answers
SOURCE: whirlpool washer wont spin during high spin cycle
Try www.Repairclinic.com.
Posted on Jan 19, 2009
Washer rocks during spin cycle
sounds like u need to balance it by adjusting the legs and then use a leveler to see if its balanced
Mar 23, 2015 | Washing Machines
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Why does my washer gets off balance during the spin cycle and how to repair it
A QUICK FIX IS TO OPEN THE DOOR TO STOP WASHER, THEN RE-DISTRIBUTE THE LOAD SO IT BALANCES OUT IN THE SPIN CYCLE. OR, REMOVE SOME OF THE CLOTHES, IT COULD HAVE TO MANY IN IT.
Feb 21, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Is off balance during the spin cycle mor often
I have a 10yr old Maytag Atlantis model MAV7258AWW. Here is how I solved my balance problem. It appeared that I had two problems. One was that it would not spin fast, the second was that it would spin off balance. To get the washer to spin fast like it should I had to open the lid then close it, re-engaging the spin cycle. I opened the top and watched the motor engage in the spin cycle. with the top open, I would open and close the lid activating the lid switch. Each time I closed the lid I noticed that the motor would move a little bit more on its glides to tighten the belt. Sort of like a automatic adjuster. The motor is designed to pivot one way for the agitator the other way for spin. If the motor does not pivot correctly, the belt will not tighten and will slip. I removed the front panel, cleaned and lubed the pivot area. Now the motor glides on the pivots like it should. I ran the spin cycle and the motor slid all the way to one side like it should, the belt tightens and the spin cycle spins. Now that the spin cycle works, quess what?? The balance problem is fixed as well. It appears that the reason that the tub was going off balance was because the belt was slipping not spinning the tub at maxium speed as designed causing the off balance problem. The tub was not spinning fast enough causing the off balance problem. I have ran several loades in the washer and not a problem. I did replace the snubber, it was worn out but it still spun off balance. I hope this helps to all who have a balance problem.
Mar 02, 2010 | Washing Machines
OUt of balance during rinse and spin cycles
I have the same problem. During the spin cycle, the washer spins all over the room.....very loudly.
Dec 26, 2009 | Maytag Washing Machines
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer sounds like off balance during spin
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Crosley CAWC529JQ Top Load Washer Logo
252 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
