I have a B&O BG model 8002.Often when I push "play", the tone arm carriage moves about 1" and returns in about 1 second. When it does move all the way to the edge of the record, it will not drop the arm and the stop button does not activate the return and shut off. The < > functions work fine. The platter turns as it should on "turn" mode and the stop button will turn it ioff in the "turn" mode. The 33-45 lights are OK and the + - buttons are working. HELP! Thanks, Jim Moore
  • mybeolink Apr 06, 2011
    I'm sure it is a problem in the board, probably a capacitor causing the arm to return & shut off. I can replace it if I knew which one it is. Thanks
    Thanks help mech. I'll give that a shot.
  • 5,370 Answers
In most of the cases, when capacitor gets faulty or weak.It gets bulged up from its top or, it gets leaked from top or it has burnt mark on its side and it looks bit different from other good capacitors on its side.Also this capacitors are soldered on the board.If the soldering gets loose the capacitor looses its connection to the board and it gets short in circuit.Just dry solder complete board.So if there is in case , the issue of loose component, then dry soldering will re-tight the loose components.This will help.Keep updated.Thanks.Helpmech.
Posted on Apr 06, 2011
  • raj somaiya Apr 06, 2011
    Yes keep updated.Thanks.Helpmech.
  • 11,800 Answers
The arm is moved by a tangential motor and an normal motor. Both are electronically / quartz controlled. If you encounter problems with them then the control board is defective - either the power circuits or the photoelectric sensors are defective.
The only way to fix it is to replace the damaged parts. Unfortunately, due to the old age and rarity of the unit your only possible source of parts is B&O , you will have to contact them. You might also find them online, salvaged from discarded unit, but that is a long shot.
On the other hand you could sent your unit to an extremely good electronics repairman - he could adapt other components. But it must be a really good one, with a well equipped laboratory.
  • Azrael SRL Apr 06, 2011
    On such an old unit probably all of them need replacing. But i doubt it's them. Anyway, you have nothing to lose replacing them all, they're less than 50 cents each.
My turntable a Crosley CR49 is about 14 years old. It plays just fine, but have to manually reset, clicking the tone arm after every record I play, either 45s or 33 1/3. How Can I fix this?
You will need to get to the underside of the turntable. There you should find that the arm when it gets to the centre of the record it will push on a switch. This switch might be out of position or just get stuck by grease or dirt. Correcting it should solve the problem.
Dec 08, 2015 | Crosley Audio Players & Recorders
How can I stop the tone arm from returning too early on smaller records?
The adjustment for auto return position is normally at the tone arm base on the left side under a rubber grommet. Use a flat blade screw driver to move adjustment screw, then test. Keep fine tuning until arm lifts at desired position. Cheers John. Stylus City NZ
Jun 14, 2014 | Crosley 0187SST Turntable
Type Crosley Model # of your device user manual " into search engine and it will show sites to get manual. In it there might be a way to help you
Tone arm on technics Sl-BD22 lifts before the end of an album
the anti-skate is set wrong, this stops the arm skatting on to the label in the middle of the record & destroying your stylus tip.
Mar 03, 2013 | Technics SL-BD22 Turntable
I have a Wurlitzer one more time. vinyl record jukebox.. I moved ( or turned) the turn arm forward to clean behind it and now the records will start to play and return to the changer. How do I adjust it.
Look up underneath the mechanism. You've moved the tone arm with respect to the bracket beneath it (which closes the trip switch). Select a record...turn the machine off...then look up under whilst someone moves the tone arm and you will see what it is attched to. If you are lucky you can hold that tight and gently move the arm back the other way a bit.
Jul 28, 2011 | Wurlitzer Jukebox 1015 One More Time...
Tone arm will not move over on self-start unless
Hi, they are not an auto start model turntable. To start lift tone arm off rest and move into position at start of record. It will automatically lift and return to rest as well as shut off at end of record. cheers john ,, Styluscity.com
Feb 21, 2010 | Thorens TD-190 Turntable
Tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
Mar 20, 2009 | Technics SL-BD20D Turntable
My prolectrix usb turntable won't play properly
i also have the same problem, im sure its something to do with the tone arm, like at the start of playing a 12'inch you have to hold the arm at the end of the vinyl for 5 seconds, have i answered my own question, i'll let u know ......
Jan 06, 2009 | Audio Players & Recorders
37 people viewed this question
 Grubhead
Grubhead
