Question about Sceptre DCL20A 20 in. LCD TV
My power light just blinks but the power button doesnt do anything
  • 592 Answers
Hi.
This is becoming a major problem nowadays with flat screen tv's.
A few years ago, there was some companies that made the capacitors.
Well, they did so without having any quality control standards, and the made about 10 million capacitors that were defective.
They chose profit over quality and put all the junk parts onto the market anyways.
The capacitors are starting to fail at an alarming rate.
A good quality capacitor should last between 25-30 years, but these junk ones are failing really quickly.
Some are going out in as little as 6 months.
Unfortunately, they aren't really a part that the normal consumer can replace on their own.
The reason isn't because they are soldered in..alot of people can fix that on their own.
It's because the capacitors act like a booster battery, and energizes the screen, convergence filter, and raster grid all at once.
That's why when you turn on a flat screen it pops right on, and the old tube type took a little while to come on.
The old tube types had to charge the tube after the power was turned on building a charge inside the tube slowly compared to new ones.
Also, the capacitors can be dangerous to handle, because they have gel in them just like batteries, and the gel can be harmful to humans.
I would recommend taking it to either Fry's, or to BestBuy.
They have special techs trained in the removal and replacement of these capacitors, as well as training of the proper handling of the damaged ones.
The electronics industry has a special repository that the bad parts are sent to, that way they can keep track of which companies the junk parts were coming from, length of time to failure, types of failures, and frequency of each type of failure.
I know you were hoping that this would be an easy fix, but sadly this is not the case.
Before you pay to get it repaired, get an estimate first from the electronics store...you may find the repair costs are as much as a new tv.
I hope that this helps you understand what has happened, and I hope you get it going again.
Good luck to you, and have a nice day.
If this helps you out, then please give a good rating for me, as this is what maintains my status as a premium expert.
Thanks !!
Posted on Apr 06, 2011
HI I HV A HUWAEI M931 AND IT WAS WORKING PERFECT AND ALL OF SUDDEN IT DOESNT POWER ON AND I JUST GET A FLASHING RED...
Make sure the battery is full charger or remove it and use the power cable only .if the power work the problem is the battery. Press the power button 3 time then hold it until il power off. Turn back on. Open it and make sure the conection from the LCD is right pug it to the main circuit look for standby and weikup key combination on the manual.
Nov 23, 2013 | Huawei Cell Phones
Error code 13 on mitsubishi wd52628
wait for the light to go out then press power. Then if it doesnt power up hold the menu and the Device/input buttons on the set both in together for 5 seconds the light will blink a series of blinks pause briefly then blink another number of blinks then pause then it will repeat the same two digit blink sequence a few times . Let me know the two digit blink sequence.
Aug 29, 2012 | Mitsubishi WD-52628 52" Projection HDTV
Compaq Presario wont start.
It might be the motherboard that needs to be replaced or the power button.
Apr 07, 2010 | Compaq Presario 5000 PC Desktop
TV doesnt turn on
Replace your Lamp XL2400 Mats Has them 1-800-628-1118
Mar 24, 2010 | Sony KDF46E2000 46" Projection HDTV
Protection light blinks and beeping
it has been through an overload (hence the protection light) and needs its breaker to be reset (look for a poped out button and push it back in) or it needs a new fuse (replace ONLY WITH THE EXACT SAME MODEL OF FUSE or it will either blow too early or too late (or not at all) when there is a surge.
Aug 17, 2009 | Monster Cable Monster Mobile PowerStation...
Only red light bliking, no screen
the red blinking light is indicating that you have a missed call, unread message, or unread email.
which makes sense if you cant see the screen.
holding the power down for 5 seconds doesnt do anything?
how about pulling the battery and replugging it in and turning it on via the Red hangup/power button?
this is known as hard-resetting the handset.
if its under warrenty you might be able to get the screen swapped out.
Jul 14, 2009 | RIM BlackBerry Pearl Smartphone
Timer light blinks constantly
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Ipad is not working
If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
Jul 07, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Sceptre DCL20A 20 in. LCD TV Logo
184 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
