Question about Lexmark X2600 InkJet Printer
Lexmark x2600 reads (new) ink cartriges as empty
  • Lexmark Master
  • 17,130 Answers
If the cartridges were replaced while it was empty and not using the maintenance the software will not detect . so to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Posted on Apr 06, 2011
Im trying to print a black and white document but it wont let me print because my color cartridge is missing
The Lexmark X2600 requires both cartridges to have ink in them to continue printing, even if your printing in "black and white". To print true black, you actually use some of the color ink. , Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality issues.
Sep 22, 2011 | Lexmark X2600 InkJet Printer
I have put new ink cartriges in my printer but it still says they need replacing so will not let me print
Hello
first of all you need original replacement of cartridge then you clean the contacts of cartridge at printer side then place it again.
good luck
Mar 03, 2011 | Lexmark X2600 InkJet Printer
Empty ink
According to your problem it seems your cartridge has been damaged or choked so change your cartridge. Because some times when we use refilled cartridge, Ink goes dry and printer's sensor can not sense the ink.
Regards
Ashly
Feb 23, 2010 | Lexmark X2600 InkJet Printer
Bars across the paper dark with ink
Must Be The ink cartrige leaking replase ASAP
Feb 05, 2010 | Lexmark X2600 InkJet Printer
Need to reset ink levels on printer (lexmark 2600)
Hi
It is the chips on the inks that make it shore empty nothing you can do about it.
But I have found this bit of read up on the internet forum Gave it a go may work if it works come back let us know so I can pass it on to others Thanks.
1 Take a small pice of clear tape. Try covering one of the outside vertical row of contacts at thr front of the cartridge. Re-insert it and it shoudl "fool" the printer into thinking it is a new cartridge. It works for my Lexmark 2600 series all in one.
2 Use clear tape over left hand row of sensors on front of cartridge and re-insert. ink now shows with question mark but reads as full and prints fine.
3 I had fully covered the contacts because it was the full length of my Scotch tape. It did not work. I went back and re-read thread, wiped the contacts the computer was telling me, took off the strip and put on just a sliver covering the left vertical side of the contact only. It worked! Yippee! Thanks a million!
Go to this website to see all
You can go to this link to see all the read up about it.
http://www.fixyourownprinter.com/forums/inkjet/35235
I not have this printer myself so I not can say if it works or not.
All The Best Hope it works for you
Jan 30, 2010 | Lexmark X2600 InkJet Printer
Ink cartridge installed backwards
use a non magnetized screwdriver and take the top cover off then unscrew the screws holding the guide bar in and gently pull the ink cartrige out you may reuse the cartrige but not recommended.
May 26, 2009 | Lexmark X2600 InkJet Printer
Problem with replacing color ink cart. #5
Is it the right Cartridge you are trying to install please check and then check if the sensors are working.
Mar 31, 2009 | Lexmark X2600 InkJet Printer
Lexmark X2600 refill problem
many printer manufacturers put something (a chip?) in the circuit of the cartridge to prevent refilled ones from being recognized by the printer....when the "factory" cartridge is empty, the only way for the printer to see a full cartridge again is by using a "new" factory one, ...i guess it's the big name brands way of making sure you buy "their" ink and not use refulls.
Oct 22, 2008 | Nukote Nu-kote RF196 Black Refill Kit
Help me
the older lexmark cartriges have a chip that will not let you refill but the newer ones don't have the chip. also if you wait until the cartrige is totally empty it will not work properly
Sep 28, 2008 | Nukote Nu-kote RF196 Black Refill Kit
Lexmark X2600 InkJet Printer Logo
398 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
