Question about Kodak Cameras
My lens won't come out won't turn on and I been trying to calling that 1800 number so what can I do
  • Kodak Master
  • 17,130 Answers
The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre.
get estimate before you decide. It will be good to have it checked at the Kodak service as you do not have to run around for spares.
Posted on Apr 06, 2011
I need a 1800 free phone number for Netflix
Hi Evelyn.
If I'm reading your note, Australian law says first call to manufacturer. The number from the website is 1-866-579-7172
I verified that this is a toll-free number, though I don't know if that applies to international calls.
I also found this listing for help numbers in Australia
http://australia.customerservice1800.com/netflix-customer-service-phone-number-support-australia It lists 1800 071 578 and 1800 071 578 as numbers to call that I dare say aren't US based ones (or at least should transfer the call on their dime) The second number is explicitly called out as Customer Service.
Good Luck!
D
Nov 24, 2015 | Computers & Internet
When I send a fax to a 1800 number I get the
I wasnt aware that anyone could list a 1800 number as a fax These are supposed to be voice only.
usually the freecall lists 1800 to call and fax numbers as the usual 02,03 xxxxxx etc
May 08, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Camera won't turn on, lens will not retract
For this problem try the following:
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Use the camera w/o the memory card
If problem still persist call the Tech Number
1800 235 6325 op 12 op 2
Hope this will help
Thanks
Byron
Oct 29, 2009 | Kodak EASYSHARE M1063 Digital Camera
Lens won't close camera shuts down
Hope this will help
Thanks
Byron
Oct 29, 2009 | Kodak EASYSHARE Z1285 Digital Camera
It quickly turns off when turned on, the lens wont go in when off
First I would check the battery, and make sure it is either fully charged, or has new batteries.
If you can get the menus, set all to factory default.
If none works, then it needs repair.
Oct 07, 2009 | Kodak EasyShare V1073 Digital Camera
I am able to transfer images to my computer, but when I try to turn the M893 camera on when it's not connected to my laptop, the screen comes on for a second or two, lens comes out, green light is on and...
It has problem on the lens. Lens doesn't extend when transferring pictures that's why it works. Kodak cameras are designed to automatically shut-off when the lens is struggling to go in or out.
Follow step-by-step solution and repair on www.kodak.com/go/stepbystep if the guide did not resolve the issue proceed processing the camera for repair under the same website if it is still under in-warranty otherwise call Kodak @ 1800-235-6325 extn 1-12-2
1-English
12-Camera Dept.
2-Hardware and service dept.
Lester
Kodak Technical Support
Oct 04, 2009 | Kodak Easyshare M893 Digital Camera
Camera lens stay out don,t respond to on/off button,does not need to be recharged.
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 28, 2009 | Kodak EASYSHARE M1063 Digital Camera
My camera lens is stuck in the closed position. When I turn the camera on, the motor runs, but nothing happens. I accidentally picked the z740 camera when posting the proplem originally, but the z700 is...
If you've dropped the camera you may have damaged the lens housing - which will require professional repair, but the problem you describe is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Aug 31, 2009 | Kodak EasyShare Z700 Digital Camera
Kodak V610 Camera error #45
hi...
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Aug 18, 2009 | Kodak EasyShare V705 Digital Camera
Panasonic KX-T7630 cannot ring 1800 or 1300 numbers. Telstra can ring 1800 & 1300 numbers by-passing the PABX and plugging straight into the ISDN NT1. Suspected programming problem with system. Please...
Not knowing your complete dialing plan makes it difficult to figure out why you can't "ring" a certain number. What do you get? Can you call local? Is 1800 or 1300 a local or "free" call or is it long distance or premium? And, do you get bounced with a display that says something after you dial 1800 or do you have to dial a complete number.
These are all installer questions. It would be well beyond the scope of a public forum to do someone's restriction tables.
Carl
Sep 04, 2008 | Panasonic KX-T7630 Corded Phone
Cameras Logo
52 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
