Question about Electric Drills
I own a corded electric drill Sears and Roebuck 3/8 inch drill. The model #315.10411 which has ball and roller bearings. It was my first electric drill and has been a true workhorse. I just love this drill and wonder if it can be repaired. Problem is the motor runs but the chuck will not turn when held. The drill makes a grinding sound and the chuck seems as if it isn't connected to anything as the motor runs. Any suggestions as to what might be broken? Thanks kindly--Harry
  • Electric Master
  • 10,896 Answers
Might just need new motor brushes
Posted on Jun 02, 2017
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: chuck removal
First open the chuck jaws and remove the LH chuck retaining screw. After that find a bent handle allen wrench about the size of the chuck. Put the shorter end in the chuck and clamp down on it. Put chuck on a block of wood or workbench with the long end at about a 30 degree angle so you can hit it counterclockwise with a hammer. It might take a couple hits but it will come off.
Posted on Jan 08, 2009
  • 86 Answers
SOURCE: motor turns but not the chuck
Not usually, the parts and labor come very close to the replacement cost. If you own an older model and have a lot of money invested into spare batteries, many of which are new, and the batteries won't fit a newer model; then you owe it to yourself to contact a service center and get a quote.
This is not true if the drill is under warranty. The cost in that case is the shipping and handling if required by the manufacturer.
Posted on Mar 15, 2009
frcs68
  • 1605 Answers
SOURCE: keyless chuck. start drilling.the head stop, but
either you have low battery or the gear is stripped. the drill should have enough torque to break your hand.
Posted on Jun 05, 2009
mtatham
  • 13 Answers
SOURCE: Drill is running but chuck is not turning.
This drill must have a morse taper shank on the drill itself and has to be tapped on w/ a soft face hammer to seat it on the morse tapered shaft on the drill. clean the taper really well on the drill end and the taper inside the drill chuck and tap together.
Mike
Posted on Oct 19, 2009
Removing chuck from a sears & roebuck model 113.24611 drill press
It is a morris taper wedge fit, so just tap it out.
Dec 29, 2016 | Sears Drills
I need information on a Sears and Roebuck outboard
sorry but you need to contact sears and roebuck.
Sep 28, 2014 | Boating
Where can I find an owners manual?
may be there change the number try checking thro serial number
May 28, 2014 | Craftsman 3/8" Corded Drill
How to repair a lower ball joint on the passenger side
Hi.
1. Raise and support vehicle.
2. Remove tire and wheel assembly, then install modified outer seal protector No. J34754, or equivalent, Fig.3 .
3. Remove lower ball joint cotter pin and nut, then loosen ball joint from steering knuckle using tool No. J-29330, or equivalent.
4. Position a suitable pry bar between suspension support and lower control arm and separate lower ball joint from steering knuckle. On some models, it may be necessary to remove nut attaching link to stabilizer shaft.
5. Locate center of rivet body and mark with a center punch.
6. Using a 1/8 inch drill, drill pilot holes completely through rivets. Using a 1/2 inch drill, drill final holes through rivets to ensure fitting of new ball joint.
7. Remove ball joint from lower control arm.
8. Assemble new ball joint to lower control arm with bolts provided in service package, Fig.9 . Tighten bolts to specifications.
9. Insert ball joint stud into steering knuckle and tighten nut to specifications, then install cotter pin.
10. Install wheel and tire and check front wheel alignment.
I hope this helps you.
Thanks.
Nov 28, 2010 | 1994 Pontiac Grand Prix
Craftsman Model #315.271690 3/8 Professional Electric Drill (corded). What are the specifications (dia, threads per inch, etc.) of the left hand thread machine screw that holds the chuck on. The Sears...
How do you remove the chuck from a Craftsman Model #315.11441 3/8 vsr corded drill? Am trying to remove the chuck but I believe there is some type of a set screw or locking mechanism that needs to be undone. I can see a slotted screw head in the chuck Looking straight down on it but it is very tight and I don't want to break it or a screwdriver forcing it. Thanks for input. Bob
Sep 06, 2010 | Craftsman Drills
I have an old corded 3/8" corded Craftsman reversible variable speed electric drill (1051). It squeals when I use it. Wondering if it needs to be oiled.
Yes, the bushings are dry, and it is screaming for oil. But, it doesn't like oil, it likes grease better, but it is hard to get in there to grease it. (sometimes), you might get it apart and both ends exposed. Then get the bushing off the end, you won't be able to get it off the front, either squish some grease in there or get the oil can out and try it. Good luck.
Apr 25, 2010 | Craftsman 3/8" Corded Drill
How to replace the chuck on a hilti te10
The complete chuck is not easily replaced. It you stick an SDS+ bit in the chuck and it seems to fit tight without much wiggle then the chuck can be replaced without taking the tool apart. The rubber cap on the end will just pull off. Next the locking collar with the annular spring will come off with the out side sleeve. Underneath is the guide tube with two enlongated rollers. The locking collar should have a ball bearing underneath it that locks the sleeve in place. Usually the roller bearings or ball bearing are missing.
Mar 14, 2010 | Hilti Drills
Electric Window motor not operating
One of two problems. Window motor or window regulator. Began by removing the door panel. Peel down the vapor barrier. This will expose the motor, you will see three star screws, remove these and then remove the motor. Remove the plate and inspect the plastic plugs in the motor, if defective replace with plugs or ball bearings, pack with wheel bearing grease. If the motor is ok. Then remove the window regulator. Using a punch punchout the rivits using a 1/4 inch drill drill out the aluminum holding in the regulator and the glass. Replacw with 1/4 inch bolts and nuts.
Jul 11, 2009 | 1996 Buick Century
Drills Logo
76 people viewed this question
Top Electric Drills Experts
Are you an Electric Drill Expert? Answer questions, earn points and help others
