Question about LG Televison & Video
I have an 52lg52 tv and the tv only goes off on the power cord, it dosent goes off, if i press the remote control or on the tv. i have to take the power cord off the outlet.
Did you ever get the problem fixed? If yes, how did it get fixed? I have the same issue
Posted on Apr 27, 2011
How to i get a power cord and a rmote control
Look at the rear of the TV. Go look at Ebay and find a matching power cord. The square block goes in the square hole. The round block goes in the round hole. The triangle block goes in to the triangle hole.
Remote: read the model number off the back of the TV. Go do a Google search for a replacement remote control.
Remember, breathe in, breathe out, breathe in, breathe out... continue doing this or you'll die.
Sep 05, 2014 | Televison & Video
Volume pegs to max. Turns itself on. Goes to menu. Intermittent
This is becoz your Internal Remote control response program chip needs to be replaced! You need it to get repaired at nearest service station. Or it may be due to Your keys pressed continously from remote control. Check both the causes! then decide. It will help you!
Dec 23, 2007 | RCA F38310 38" TV
One for all remote codes don't work URC-3920
Hi keep teaching should come up with more if still dosent work try one for all web site or phone them very helpful
Aug 04, 2012 | Televison & Video
I have had several technicians at my parents house they have a sanyo pdp42xr9da with remote rcj17oa the remote dosent talk to tv we have had the tv for two years it did work but now dosent please suggest...
Most of the fault in this kind of symptoms is the remote control itself.
To confirm it, aim directly the remote control to your cellphone camera and press any button key at the remote control. While pressing the button key, you will be able to see the flash of the infrared indicating that the remote control is working fine. If you can't see the flash of the infrared this is an indication that the remote control is already faulty.
Remote control
If you've confirmed that the remote control is working fine, then the fault came from the infrared receiver(sensor) of your tv. It needs to check by the qualified technician to isolate the problem.
Feel free to ask question of you need further assistance.
mjsazon
Oct 04, 2011 | Televison & Video
Remote control work very slowly and sometime do not work
Please follow the troubleshooting steps:
  1. Remove the batteries from the remote control.
  2. Press each button on the remote control twice.
  3. Make sure none of the buttons on the remote control are jammed.
  4. Install fresh batteries into the remote control.
  5. Make sure nothing is blocking the Infrared (IR) sensor on the TV.
  6. On the remote control, press the TV FUNCTION button.
  7. Press the POWER button and other buttons to test the operation.
  8. Try using the remote control at varying distances from the TV.
  9. Power reset the TV by follow the steps:
  • Unplug the television power cord from the electrical outlet.
  • Let the television remain without power for 60 seconds.
  • Plug the power cord back into the electrical outlet.
Jan 09, 2011 | Philips 32PF9964 32 in. Television
Remote want work on tv
Make sure that you're using the supplied Remote (RMY-906) to control the TV. If so, perform the steps given below to resolve the issue.
  • Make sure that you're using batteries which are having enough charge. Try using fresh alkaline batteries.
  • Do not use rechargeable batteries in the Remote.
  • Ensure that the batteries are inserted correctly with the correct terminals by checking the + and - symbol in the battery compartment.
  • Make sure that the Remote is set to operate with the correct functions. On the remote control, press the TV FUNCTION button to re-check this.
  • Press the POWER button and other buttons to test the operation.
  • Make sure that none of the buttons are jammed in the remote control.
  • Ensure that the remote control is being used no closer than 3 feet and no further than 10 feet away from the unit. Try using the remote control at varying distances from the TV.
  • When using the remote control, be sure to point it directly at the remote sensor on the device.
  • Remove any obstacles that may be in the path between the remote control and the device.
  • Ensure the remote sensor of the device is not exposed to direct sunlight or bright florescent lights, as this can interfere with the sensors ability to receive signals from the remote control.
  • Try resetting the Remote. To reset the Remote. remove the batteries from the remote control, press every button twice, and then reinstall the batteries.
  • Try resetting the TV also to check the operation. To reset the TV, disconnect the power cord for a short period of time (approximately 1 minute), then reconnect the power cord and power on the television.
If the remote control is able to operate other devices (such as cable box, DVD Player or satellite receiver), then the issue may be with the IR sensor on the TV. If this is the case then the TV that will require service. Otherwise, the remote control may need replaced.
Good Luck!
KenSolutions
Nov 23, 2010 | Sony KP-61S75 TV
Will someone tell me the correct steps to program the rca 3 device remote
Turn TV on, Press the CODE SEARCH button, press TV, enter the three digit code, press POWER until the TV goes off, press Enter.......hope this was helpful....
Apr 22, 2010 | RCA Universal Remote 3 Device Remote...
Having problem with my Panasonic TV.
hello Plug the power cord back into a properly grounded wall outlet. Then press the POWER button on the projection display or the
remote control to turn the power on
While pressing the VOL- button on the projection display,
hold down the PIP or SPLIT button on the remote control
simultaneously for more than 5 seconds
When the lamp time reset procedure is complete, the
above screen will appear. (This screen may be different from
the actual screen
Note:
When the lamp time reset is complete, the LAMP
indicator goes out.
regards
shaun
Jan 18, 2010 | Panasonic PT-50LC13 50" Rear Projection...
What remote code is used with RCA remote for a
why dont you use rca's code search feature,Hold code search button untill lighted,press tv button on remote,then slowly momentorally press the power button on remote untill tv goes off,then press enter right after the tv goes off,there are abouy 200 codes on the rca remote control,so be patient.
Nov 24, 2009 | Sharp Televison & Video
Sky remote code
You will need to go to Sky's website and order a new remote if this doesn't work.
Press tv on the remote
press and hold Select and red until the remote LED blinks twice
type in 0 0 6 0
press power button on the remote, if the tv goes off press select and it should control all the tv functions.
if the tv does not go off press tv then power buttons on the remote and keep doing this until the tv goes off, then press select once the tv goes off.
Like I said earlier, if this doesn't work you will need to order a new/replacement remote via Sky's website then put the code listed above in.
Jul 18, 2008 | RCA RCR660 Remote Control
Televison & Video Logo
Computer Repairing
Computer Repairing
