Question about Technics SUV500 2-Channel Amplifier
Hi, My amp is a technics sua900mk2 when i have my volume at around the 10 o clock position, the amp cuts out and I have to turn it off and back on. it seems to be a common fault on this amp looking at the posts. Is there anything that might cause this that I can check myself. thanks
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
This amp isn't a real powerhouse. Perhaps you're overdriving it. Exceeding it
Posted on Apr 06, 2011
Testimonial: "very helpful, as you said, I have since found a loose post at the speaker connection. problem solved, thank you very much"
  • 1 more comment
  • brassic Apr 06, 2011
    im not sure how it will complete a circuit with no speakers conected,, the amp runs fine to a fairly loud level and will run all day until i just crank it that little bit more and its always the same place on the dial exactly. its not getting hot cos ive got the back off it andf its a fairl bit of power for its age, its 100 din per channel. i have 2 sets of speakers and its the same on each set and i have low loss wire so i know the cables fine. i will try what you say though as anythings worth a try, thanks,,,,Andy
    Ive sorted it,, not quite sure what the problem was but im guesing resistance building up in the wires. All I did was take the speakers out to try what you said then put them back but tidied the wires up. The only difference is that the wires are not intertwined and tangled up now. Thanks again
  • David Dunn
    David Dunn Apr 06, 2011
    It may have been a loose wire, too. Vibration would cause its connection to vary and theapparent load to fluctuate. I think your amp is rated for 4-ohms but I wouldn't force the issue at its power limits.
Unit cuts off. I turn it back on and it turns itself back off. Confused...Please help
Sounds like a speaker wire is shorting out, check there are no breaks and/or positive and negative terminals on the amp and speakers are the right way around
Aug 07, 2013 | Yamaha RX-V2600 Receiver
How to install clock spring
Not recomended for untrained people as airbags can be very dangerous. That said you need to. 1) disconect battry 2) remove SRS (Airbag fuse) 3) remove shroud around steering colum 4) wait ten minutes. 5) remove horn pad (airbag houseing) usualy held in by tamper proof bits from back of steering wheel. 6) unplug wires to airbag & horn 7) undo steering wheel bolt & mark position of steering wheel to colum splines. 8) remove steering wheel with suitable puller (NOT a hammer) 9) unclip clock spring & replace 10) reverse procedure
Sep 22, 2012 | Cars & Trucks
I seem to always get a static sound out of my Line 6 Spider Iii below 9 o'clock on the volume knob. Not only is it staticy, but the volume jumps all around and goes from whisper quite 1 second to house...
It sounds like you have a dirty pot (the volume control). Unfortunately the only way to clean the pot is to open the amp up and try to spray some Servisol Super 10 in through the small opening in the pot case.
WARNING: Tube amps contain lethal voltages even when unplugged! If you are not an experienced service engineer then take it to someone who is! It is a pretty common task in guitar amps so shouldn't cost too much.
Sep 10, 2011 | Line 6 Bogner Spider Iii Valve Tube Combo...
Hi Strange problem with Marantz pm7001 When ever I turn the volume upto around 1/3 and 1/2 of the way, the amp cuts out and reset it self down to minimum volume. It seems like the amp ins't enough power...
What's probably happening is that the amplifier is shutting down or cutting back the volume as protection from damage. You may have a partial short in the speaker wiring that is not a problem at lower levels, but at higher ones causes the amp to see too low a load. There may a problem with a speaker or crossover component that is breaking down at higher volumes. Or something in the amp's output stage is unable to handle the load.
Test the system with a known good speaker system and length of wire and see if the trouble continues. If it does, you'll know it's the amplifier that needs to be checked. If the test speakers can reach normal volume, you can start checking the wiring and other speakers for the source of the trouble.
Mar 13, 2011 | Marantz Audio Players & Recorders
Technics SA-DV290 Amp. Sound cuts out as volume is increased
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
regards
shaun
Apr 04, 2010 | Technics SC-DV290 System
My technics hi fi cuts out at high volume the only way to restart is to turn it off then back on again any ideas
suspect iffy speaker wiring,are there any joins? Has the amp got adequate ventilation
Jan 03, 2010 | Audio Players & Recorders
Alpine PDX1.600 amp cuts off
Make sure there's no missmatched impedance. If your sub running 2 ohms then your amp has to be 2 ohms stable. Does the amp blow fuses or get really hot? If it does it can be a fire hazard and I would recommend taking it out of your car. It could be that you don't have sufficient grounding. The grounding needs to be very close to the amp and the paint needs to be thoroughly scratched off. Otherwise could be a blown transistor within the amplifier, you can check this by opening up the amp, running a multimeter and testing the transistors for resistance.
Aug 04, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Is my amp getting burnt out, it keeps blowing fuses
sound like you have a a bad spkr connect the spk one by one to amp and play the system and you will know and make sure the spk can handle the load from the amp too''
Jun 19, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Technics su z2 amp shuts off sound
hello. we cant help if we dont know what music source you are using.
Apr 13, 2009 | Technics SA-AX530 Receiver
Technics SUV500 2-Channel Amplifier Logo
361 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
