Question about Raymarine ST70 Autopilot Control Head E12196
My ST70 Raymarine autopilot sometimes does not respond to +/- 1 or 10 degrees command. The button itself works as I can hear the beep. If, for instance, I push the button 5 times the autopilot just receive one or two. I disconnected the refrigerator, switched on or off the engine but everything is the same. Sometimes it happen, sometimes it doesn't.
  • 3 Answers
SOURCE: Installing a Raymarine 8002/6001 on my 2005 Sea Ray 270
If you have a basic knowledge of electronics and can follow instructions. It's easy the hardest part is connecting the pump and bleeding the system.
Posted on Jun 25, 2009
  • 43 Answers
SOURCE: Display control unit frozen, display just reads standby
The reason is because the housingin is a little bit broken or throw the keypad water came inside yuor Display and after this the oxidation ha destroyed a part of the printid circuit or the switch of the keypad
Posted on Oct 13, 2009
SOURCE: Autopilot shows "no rudref"
how do connect my autopilot
Posted on Mar 17, 2010
  • 16 Answers
SOURCE: raymarine autopilot swings hard over immediatly i select auto
CHECK RUDDER REFERENCE UNIT FOR CONTINUITY(IT IS A POTMETER) CHECK IF MOTOR IS RUNNING IN THE CORRECT DIRECTION ,CHECK CONNECTION OF RUDDER REF UNIT.
Posted on Apr 22, 2010
  • 64 Answers
SOURCE: Clutch failure of Raymarine M81130 linear drive
Try putting 12 vdc directly to the clutch circuit. You should hear the clutch engage. If this is operating properly, then the course computer circuit has failed. If this is not working then the linear drive needs to be rebuilt.
Posted on Jun 14, 2010
How to repair St40 autopilot. Works intermittently.
The autopilot draws a good amount of current. make sure that all connections are good and tight starting with the connection at the fuse or breaker all the way through to the unit. make sure the connection at the autopilot is clean and tight. If the problem persists, it may be internal to the unit.
Aug 24, 2014 | Raymarine St4000mk2 Marine Autopilot Wheel...
I would like to connect my garmin gps72 via the garmin supplied four line plug to the nmea ports in back of my raymarine st6002 autopilot controller. The st6002 controller is plugged into a smartpilot x5...
I connected my Garmin gpsmap76 to a Raymarine autopilot using the NEMA output from the GPS. The autopilot was also on the seatalk bus. It work fine. The GPS provided navigational guidance to the autopilot
Dec 21, 2009 | Garmin GPS 72 GPS Receiver
Oct 03, 2009 | Raymarine Boating
The rudder sensor works like a light dimmer, so you get 5V and ground on the outside two connections and a varying voltage between about 1 and 4 volts depending on rudder position
847-746-0100 www.technicalmarine.com
Jul 07, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
ST6000 autopilot kicks out
I have exactly the same problem, It is very unpleasant, all the time we have to be close from the helm. if you founded the solution, I am very interrested. I will try some test. If I find something, I will post it.
Jun 10, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
Problems talking to autopilot
I think you use the NMEA output to the autopilot .
The plotter shows you only when you have a seatalkconection with a Raymarine autopilot on you Plotter
Apr 06, 2009 | Raymarine E120 Multifunction GPS Receiver
Raymarine smart pilot st6002 backlight is too dim
Get a new backlight, inverter is probably ok.
The way to check that the inverter is ok:
disconnect the backlight and if you hear a high pitched noise, the inverter is still good.
replacement backlight is available from a company called Being Seen Technologies.
there website is www.beingseen.com
Mar 12, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
Feb 19, 2009 | Raymarine St8002 Smartpilot Autopilot...
Raymarine ST70 Autopilot Control Head E12196 Logo
50 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
