Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
TENGO PROBLEMA AL DESCARGARLO EN EL ORDENADOR
  • Kingston Master
  • 27,725 Answers
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver
click start click on computer to open you should see your drives C: and your other drives cd dvd and your usb drive E: or F: from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to usb drive then drop them example on how to safe data/files to a usb drive
click start all programs accessories open windows explorer navigate to your data
right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope this helps you
Posted on Jan 05, 2012
Tengo problemas con mi HHR la luz del T/C no se apaga y cada vez que pongo el cambio en Reverse o Drive hace un golpe en el motor, como puedo solucionar el problema?
Hola, Tengo Una HHR Y Cada Vez Que Me Aparece El T/C Me Empieza A Dar Golpeteos En La Caja Cada Vez Que Meto Drive Y Al Avanzar Da El Golpeteo De 1 A 2 Despues De Esto Tambien Me Aparece El Check y Al Aparecer Esto Ya no Enciende Desde El Control Remoto Yme Gasta Un Poco Mas De Gasolina Me Han Dicho Varias Personas Que Son Los celenoides Y Tengo Esa Duda
Apr 13, 2012 | Chevrolet HHR Cars & Trucks
Tengo problemas con los frenos, se me enciende la luz indicativa del ABS, y el problema es que cuando freno, al momento en que casi se detiene el vehiculo jala hacia la derecha, como si solo frenara ese la...
evidentemente la luz se enciende por un fallo, revise que el caliper o compensador del lado derecho no este muy ajustado y tambien purgue el sistema por posibilidad de aire en el sistema
Jun 08, 2017 | 1993 Toyota Previa
Hola buenos dias: En mi ordenador, tengo una placa gigabyte GA-8S648, y desde hace una semana me aparece el siguiente mensaje al encender el ordenador: "Scanning Bios Image in Hard Drive" Le llevé...
Buenas tardes, si tu computador esta mostrando ese error es por que no logra encontrar el bios. si sabes el bios es el software que hace posible que hardware y software se comuniquen el bios funciona a nivel de i/o para poder inicializar cada uno de los componetes del computador, sin el, son solo piezas separadas;lamentablemete tu placa no tiene un back up rom y si ya lo reseteaste y limpiaste el cmos (removiendo la bateria cmos)lo cual supongo ya hiciste no queda mas que cambiar la motherboard.
Aug 31, 2010 | Gigabyte GA-8S648FX Motherboard
Tengo problemas con el aire acondicionado esta tirando aire muy caliente aunque este en aire acondicionado.
Ok tienes que revisar si el compresor trabaja cuando activas el interruptor del aire si el compresor no se activa podria ser que le falte freon 134a al sitema,que tengas algun problema electrico.puedes comprobar el nivel de freon con un manometro si este esta bien tienes que revisar la parte electrica. Gracias
May 03, 2010 | 2002 Kia Sedona
Problemas para captar señal satelital
Tienes mal la antena o lo conectas dentro de un edificio. Si el problema te lo da en campo abierto, tienes que enviarlo a reparar.
Mar 17, 2010 | Garmin GPSMAP 60CSx GPS Receiver
Imac g5 linea blanca vertical en la parte derecha
éstos son algunos procedimientos que se pueden tratar de resolver este problema con la línea blanca de la pantalla. Pero, por favor tenga en cuenta: si estos 2 procedimientos no ayudan, te recomendaría tener en tu Mac en el servicio de Apple en un centro de servicio autorizado
éstos son algunos pasos que usted puede tratar de resolver el problema:
Opción # 1
-PRAM reset -
• En primer lugar, sostiene en su botón de encendido durante aproximadamente 10 segundos para hacer una parada difícil, si no se ha cumplido ya su Mac apagado.
• Una vez que tu Mac está apagado, usted tendrá que realizar lo que se denomina un restablecimiento PRAM (RAM de parámetros)
• Busque las siguientes teclas en el teclado: Comando, Opción, P y R. Es necesario mantener estos teclas simultáneamente.
• Encienda el ordenador.
• Mantenga pulsado el Comando + Opción + P-R llaves. Debe pulsar esta combinación de teclas antes de la pantalla gris.
• Ahora, presionando las teclas hasta que el equipo se reinicia y se oye el sonido de inicio por tercera vez.
• Suelta las teclas y permitir que el MacBook a poner en marcha.
Opción # 2
-Restablecer la PMU -
El administrador de energía es un circuito integrado (chip de ordenador) que suele ser en la placa lógica de su ordenador Mac.
Es responsable de la gestión de energía de la computadora. Controla la retroiluminación, giro del disco duro, el sueño y la activación, algunos aspectos de la carga, control de trackpad y algunas entradas y salidas en relación con el reposo del ordenador.
• Si el ordenador está encendido, apágalo.
• Desconecte todas las conexiones de entrar en el Mac, excepto para el cable de alimentación.
• Una vez que todas las conexiones se han desconectado, quite el cable de alimentación de la Mac.
• Espere 20 segundos.
• Vuelva a conectar el teclado, el ratón y el cable de alimentación en el equipo.
• Presione el botón de encendido para reiniciar el equipo Mac.
Espero que esto haya ayudado a resolver el problema de la línea blanca.
Recuerdos,
-Mactechtrainer
Jan 29, 2010 | Apple iMac G4 Desktop
Al cambiar s. o.vista (antes xp) no puedo escanear
Hay muchos escáneres que no funcionen con Vista. No solamente de Canon, pero también de HP.
Si existe el driver para tu canoscan en Vista, puedes descargarlo de canon.es y hp.com.
Si no hay, probablemente necesitas comprar otro escáner.
May 06, 2009 | HP PSC 1315 All-In-One InkJet Printer
Problemas con el cdroom y con el abanico
Hola. Soy Alex y estoy aqui para intentar a ayudarte con vuestro problema informatico
Me parece que los drivers (los controladores) de los CD rom ya no estan en tu PC se no parecen los iconos en MIPC. Que lo puedes hacer, si tienes XP es, ejecutar windows XP desde el cd cuando arrancar el ordenador y reparar la instalación de windows.
Espero que este es vuestro solucion
Un saludo!
Oct 12, 2008 | Computers & Internet
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
22 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Computer Links
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
