Question about Laguna Pressure Flo Uvc Filter 11w Replacement Bulb (Pf700 and 1400)
Can't change citroen xantia dashboard bulb - Laguna Pressure Flo Uvc Filter 11w Replacement Bulb (Pf700 and 1400)
Where's hood release lever on 1998 Citroen xantia 3 litre
left hand side .if this is a RHD vehicle they still fit the lever for a LHD model
Jan 16, 2015 | 1998 Citroen Xantia
Citroen xantia forum
Find the central locking box and remove wire connected to Remote alarm box.
Aug 06, 2014 | 1998 Citroen Xantia
Citroen Xantia AUTO 2.0 alert lights cold (sport and snow lights)
The S light is also used like a 'check engine' light for auto transmission. There maybe some error in the transmission control system. You transmission has a computer that controls a lot of valves and solenoids in it. Check your transmission fluid level and it's integrity. If you have not changed the fluid for the last 50000kms then it's due for a change. Use only Peugeot recommended fluid. Other fluids will damage it. Mention your transmission type when buying. It's either AL4 or 4HP20. Best to buy it from authorized dealer. Garages that have a Lexia 3 scanner can scan for error codes for the transmission.
Aug 20, 2012 | 1998 Citroen Xantia
Citroen audio manual
botton 1 is the first digit, button 2 is the 2nd and so on after all 4 done press 6
Oct 12, 2009 | Car Audio & Video
Citroen xantia fuel pump relay
If the pressure is up the pump will not cut in anyway! slacken off a fuel line to the injectors a little and drain a few cc of fuel out (it will evaporate fast) then try again, if the pump runs for a couple of seconds then look at the spark, if it doesnot the relay is above the fuses.
Feb 27, 2009 | 1987 Peugeot Liberte
If you have enough fuel pressure the pumpl will not allways run anyway, carefully slacken a fuel line on the pressure side and see if fuel weeps. Get someone to try and start and see if you can hear the injectors clicking, also check spark (up to this year the fuel injection was a part function of the ignition, if the module in the distriputor goes down you get no fuel either.
Feb 27, 2009 | Remida Automatic Citrus Remuk4 Juicer
Citroen xantia car radio
I have a problem with a citroen xantia radio I can not enter the 4 digit code
system radio Audio 3030RDS
Feb 16, 2008 | Car Audio & Video
Laguna Pressure Flo Uvc Filter 11w Replacement Bulb (Pf700 and 1400) Logo
159 people viewed this question
Top Laguna Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Laguna Garden Expert? Answer questions, earn points and help others
