I need a tachometer wiring diagram from coil to meter for a 1991 nissian pintara Ti
    Brigadier General:
  • 6,277 Answers
Sorry but I think you will have GREAT difficulty obtaining an answer from this WASHING MACHINE Forum ;-0(
Better luck when you post to the appropriate forum ;-0)
Cheers,
John C
Posted on Apr 06, 2011
1991 vw cabriolet fuse diagram
Hi, i need the cluster wiring diagram of the golf mk2 , these clouster is whit analogue tachometer and digita clock.
I will apreciated tour help
Jul 18, 2012 | 1991 Volkswagen Cabriolet
I recently bought a tachometer and lost the diagram i know the black wire is negative and the red is positive and the white is lighting but what wire do i connect the green one to
http://www.offroaders.com/tech/Autogage-Tachometer.htm
HERE IS A LINK TO A WIRE DIAGRAM! THE GREEN GOES TO THE NEGATIVE SIDE OF THE COIL. GOOD LUCK!
Dec 11, 2010 | Equus 6086 Black Tachometer Measures 2 12...
2005 fxstbi- installing a tachometer tachometer, but no pink wire to get a rpm on tachometer. do have to go to negative side of coil? thanks.
yeah, that's what I was talking about. No pink wire on the later models but I'm sure they've got a wire for the tach on some the models that come with them. If you had a wiring diagram for one of those it would tell you what color they use now. But, if you only have one wire coming off the coil, that means there isn't another wire for a tach, Uhh. I wonder if the later models get the trigger off the crank sensor or maybe out of the ignition unit rather than the coil.
Jul 31, 2010 | 2005 Harley Davidson FXSTB - FXSTBI Night...
How ti install a tachometer
It depends on the tachometer. Some tachometers operate off the ignition unit and others get their trigger from the coil. Also, since a Harley fires both plugs at the same time and every time the pistons come to top center. Therefore, the tachometer must be set up for this, just like for a two stroke engine or you'll get a erronous reading. Any tachometer that you buy should have wiring instructions with it.
I hope this helps
Good Luck
Steve
Jul 29, 2010 | 2000 Harley Davidson FXST Softail Standard
Not all spark plugs firen
You check the right firing order?
1991 Ford Mustang 2.3 liter SOHC L4
1991 Ford Mustang 5.0 liter V-8 HO
Also, need check the PCM for someone short; sometimes this is the reason it wasn't sending a signal to the coil. You have constant power at the coil but the ground signal doesn't fluctuate from on to off while the engine is cranking. If the hall effects switch in the distributor is bad it won't tell the PCM when to fire the coil and the hall effect switch also operates the tachometer. So if this switch is bad the tach and the coil would not work.
Good luck.
Feb 09, 2010 | 1991 Ford Mustang
Need brake circuit diagram for 1991 chrysler new yorker
1991 Chrysler New Yorker Auto Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): Red and Pink
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Yellow
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Dark Blue
Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Black/Orange
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Black/Yellow
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Positive Wire (+): Orange/White Or Orange/Violet
Power Door Lock Positive Wire Location: In Drivers Kick Panel
Power Door Unlock Positive Wire (+): Pink/Violet
Power Door Unlock Positive Wire Location: In Drivers Kick Panel
Door Trigger Negative Wire (-): Yellow
Door Trigger Negative Wire Location: In Drivers Kick Panel
Dome light Supervision Wire: Use Door Trigger (Requires Relay)
Dome light Supervision Wire Location: N/A
Trunk Release Positive Wire (+): Black/White (Requires Relay)
Trunk Release Positive Wire Location: At Trunk Release Switch
Horn Negative Wire (-): Black/Red
Horn Negative Wire Location: At Relay In Fuse box
Tachometer Wire Negative Wire (-): Black/Gray
Tachometer Wire Negative Wire Location: At Ignition Coil
Brake Light Positive Wire (+): White
Brake Light Positive Wire Location: At Switch above Brake Pedal
Factory Alarm Disarm Wire (-): Light Green/Orange
Factory Alarm Disarm Wire Location: In Drivers Kick Panel
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Thank You for contacting Fixya.com
Aug 03, 2009 | 1991 Chrysler New Yorker
2003 E350 tach pickup wire??
Tachometer Wire Negative Wire (-): Any Wire That Is Note Red/Light Green. The diesel tach wire is a green/white wire, located in a 5-pin harness held up with tape behind the parking brake release.
Tachometer Wire Negative Wire Location: At Igniton Coils
According to wiring diagrams online... good luck with this.
KEn
May 04, 2009 | Ford E-350 Super Duty Cars & Trucks
Wiring a tachometer to the coil
It should be a white or purple wire at the coil, or you can get it at the ecm plug on the passenger side of the firewall.
Jan 12, 2009 | 1991 GMC C1500
Nissan pintara 1991 hatch
so does mine! eventually they will stay on, it means your alternator is starting to die
Aug 03, 2008 | 1991 Nissan Sentra 2 Door
Nissan pintara ti 91 u12
Your blend door in your car isn't functioning properly. The blend door is a part of the box that your heater core is in.
Jun 09, 2008 | 1991 Nissan Sentra 2 Door
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
