Question about HP Computers & Internet
Hi, I am having HP G60-549DX for the past 14 months. For the past 3 months i am facing problem when switch ON my laptop. It gives some loud noise for around 5-10 mins. after that windows will load. Also sometimes it dont switch On itself. I Will be trying to remove battery and plug in the charger without battery and then switch it on. Then it will swich on. Third problem is after my system is properly loaded, sometimes whatever the application i open, the screen will not be loaded. It will show as screen is hanged. Then i cannot even have any control on my laptop. I need to remove battery and switch it on. Do you have some solutions for this?
  • 639 Answers
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the last month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Click on Next and System Restore will start and windows will take a reboot.
After reboot most of your problems should be resolved.
Posted on Apr 06, 2011
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
Sony Vaio fan making noise
Hi:
Not sure of a user cause for the fan to run full speed, unless you are using the laptop in a high heat environment, or setting it on a bed or other area where it is not getting adequet cooling air. If it does it right away, when you turn it on , cold, then there might be a laptop hardware problem. If you leave your laptop on all the time, then you might be inducing the problem. I had a HP high performance laptop, that the fans would not turn on at all till it ran an hour or so, then they would stay on loud for 10 or 15 minutes, then shut off, then cycle.
Nov 10, 2009 | Sony VAIO VGN-N130G/W Notebook
Hi, the problem is that when the HP Pavillion is switched on thereis a very loud beeping sound. One long and two short beep together. It renders the unit useless because it does not switch on for sometimes...
i think its an motherboard releted problem the beep sounds you told hear is produced by motherboard when it is facing any complaints in side it ask a certified HP technichian
Oct 19, 2009 | HP Pavilion dv9000z Notebook
Loud Noise from HP Pavillion dv9500
it could be a worn speaker wire shorting out
Jul 01, 2009 | Computers & Internet
Loud Fan on my Laptop
Here is one for $28 plus shipping.
http://cgi.ebay.com/Compaq-Presario-C500-CPU-Cooling-Fan-409073-001_W0QQitemZ290267492182QQcmdZViewItem?_trksid=p3286.m20.l1116
Oct 16, 2008 | HP Compaq Presario C500t Notebook
Getting noise in HP dv2700t 14" laptop
I wonder if the controller board on the motherboard is bad. I'd report it to HP again and see if they can fix it for you. Obviously they switch vendors for getting hard drives.
Jul 31, 2008 | HP Pavilion dv9000z Notebook
3 factory installed hard drives in 8 months
what exactly ur facing ??? 3hdd ??replaced anyt error codes??
pls give full info
May 19, 2008 | Computers & Internet
Beep from computer
My lap is also dv6000 and i have no symptoms like that.
it seems some thing is going wrong inside. As your lap is under warranty you should contact your service centre, it will be free.
Thanks
Iqbal
Apr 06, 2008 | Acer Aspire One PC Notebook
Problem to install drivers of compaq presario 6409 tu
You did not mention what type of problem you facing during driver installation.
Any way, if you don't have proper driver for your laptop, you should go to HP website
or copy and paste this link to your Internet Browser http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
and put your product service tag code which you can found on the back side (bottom) of your laptop. and press enter.
Then you can found the appropriate driver for your lap top and you can easily install it directly from the web site or download the deriver and make installation as per your requirement and use.
Thanks.
iqbal_delphidev@yahoo.com
Mar 05, 2008 | Compaq Presario V2404US 14" Notebook PC...
Hearing noise while switching on/off
Monitor clicks, pops, or makes other noises. Noise when turned on or off. It is normal for standard computer CRT .
How can I make my computer quieter? If your power supply has a power switch on it, you can easily determine how much noise your power supply generates by disconnecting it from the motherboard.
Good Luck, Read and follow instructions/Please dont for get to Vote/Thank You.
Dec 26, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
118 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
