Question about Amana Ovens
Hi how can i clear ;clean fiter; from my amana uhdc5142 display?
  • dias_santos_ Apr 06, 2011
    Hi Daniel my problem is with an microwave and i dont see any of those botons,can you be more specific please.
    Many Thanks
    A. Santos
  • dias_santos_ Apr 07, 2011
    Hi Daniel that is not the problem, the problem is how to clear (CLEAN FILTER) in the digital dispay board?
    Many Thanks
    A.Santos
  • 10,515 Answers
This is a common problem on this model.Many complaints has already been registered for the same. Unfortunately, there is nothing you could do other than replacing the control board assembly. You could try to disconnect the power supply for few minutes, say 15 minutes and then turn it ON.If you still see the same error message, replacement of control board is on the cards.
I wish i could have a better solution.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 07, 2011
  • 4,323 Answers
Hi
To clear this code...press and hold the dispenser lock & auto light buttons on the dispenser at the same time for around 10 seconds until the filter status indicator begins to flash and then release the buttons. If this won't work then you can try the dispenser lock & water buttons at the same time. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 06, 2011
  • Daniel Scott
    Daniel Scott Apr 06, 2011
    Yeah....right...my
    bad missed on the model no. To clean the filter for your microwave look under
    the unit to locate the two metal filters those are on both sides of the unit.
    After this put your finger inside the finger hold or pull the tab on each
    filter, then slide the filter towards the back/rear of microwave. And after
    this pull the filter down & towards the front of the microwave. You can now
    clean this filter with hot water and dish soap let it remain soaked for
    10minutes and then insert it back same way to solve the issue. Hope this
    Daniel
    Yeah....right...my bad missed on the model no. To clean the filter for your microwave look under the unit to locate the two metal filters those are on both sides of the unit. After this put your finger inside the finger hold or pull the tab on each filter, then slide the filter towards the back/rear of microwave. And after this pull the filter down & towards the front of the microwave. You can now clean this filter with hot water and dish soap let it remain soaked for 10minutes and then insert it back same way to solve the issue. Hope this helps...please post back for further assistance.
    Daniel
  • Daniel Scott
    Daniel Scott Apr 07, 2011
    I know it can either be cleaned by cleaning the filter or by replacing it
How do you reset the control panel on an a mana oven model number AOES3030E
The easiest way would be to throw your circuit breaker, wait 10-15 minutes for good measure, to clear capacitance, then flip the breaker back on. If the display is damaged or dim, get the display board re-built.
Sep 30, 2014 | Amana Ovens
Tip
My oven displays error code 5AB
Hi.
I am publishing this tip because of the many users asking me about the code 5AB on Amana, Maytag and other ovens.
Error 5AB in fact does not exist , and what you see written on display isnot 5AB.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Depending on the model, there may also be a beeping sound when you try to operate the oven.
Push and hold the Clock button for about 10 seconds, until the display clears, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
on Mar 05, 2010 | Ovens
My Amana self cleaning oven quit working and display but stove top still works
pull the oven part out and check the connections on top of the oven where all the controls are ,bet it has a burnt or corroded connection here between the supply for the top and the oven
Apr 20, 2012 | Amana Ovens
Amana agds900ww oven does not work in bake mode but does in broil & clean
HI, It could be the control module is bad. have it checked out, and/or replaced. Good luck.
Sep 19, 2011 | Amana Ovens
OVEN WILL NOT COME ON AND IT DISPLAYS F9. WHAT DO YOU DO?
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 02, 2011 | Amana AOCS3040SS Electric Single Oven
I push the bake button for the lower oven and it begins to beep and displays a F9 on the digital display
Hi
Daniel
Aug 01, 2011 | Amana ACB6260A Electric Double Oven
Instructions for Amana Self Clean Oven
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 13, 2010 | Ovens
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
Oven self-clean won't turn off!!
You will need to press the stop/cancel button, this will clear the cleaning cycle, due to the interruption. If this does not clear the display you will need to unplug the stove for five minutes and then plug it back in and this should clear the display.
Nov 14, 2009 | GE Ovens
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
Ovens Logo
56 people viewed this question
Top Amana Ovens Experts
Oloyede Monsuru
Joseph Hoffmann
john mabry
Are you an Amana Oven Expert? Answer questions, earn points and help others
