Question about Frigidaire Refrigerators
FDR252RBB1 FREIDGEAIRE DISHWASHER WONT DRAIN,PLEASE INFORM ME
Frigidare dishwasher wont drain, can hear pump motor start
Hi Mark, this is AP and I'm happy to assist you!
I understand you are having trouble with your dishwasher not draining and making odd noises. I would suggest checking the drain hose to ensure it has not become twisted or kinked. Even if the hose is not kinked make sure it has not fallen behind the dishwasher either as this can prevent draining. Additionally, you could check the filter at the bottom of the tub to make sure no debris has clogged the filter or disposal. Other than that the drain pump could be the culprit. If so, I would recommend a local authorized technician to come out and properly diagnose the dishwasher. I hope this information helps.
Mar 15, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher wont drain!
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 22, 2011 | Kenmore Dishwashers
Doesn't drain after washing dishes
Thank you for contacting fixya.com.
There are various factors when a dishwasher wont drain water completely.Such as clogged drain hose,worn belt,pump assembly,bad motor,defective timer,drain valve etc.Please check the bellow links to read the article thoroughly to troubleshoot your problem:-
http://www.partselect.com/dishwasher+water-wont-drain+repair.htm
http://www.repairclinic.com/Dishwasher-Troubleshooting?red=Dishwasher-Repair-Help#thewaterdoesntdrainfromthemachine
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | Roper 24 in. RUD3000 Built-in Dishwasher
Water is not drain completely after wash.
Jun 01, 2011 | Miele 24 in. G870 Built-in Dishwasher
Wont drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
Apr 17, 2011 | Whirlpool GU2800XTVS Builtin Dishwasher
Water wont drain
Hi
Daniel
Mar 18, 2011 | Dishwashers
It wont drain
Hi
Feb 20, 2011 | Dishwashers
My portable GE dishwasher is clogged and wont drain
Hi
Feb 13, 2011 | GE Profile 24 in. Built-In Dishwasher...
Water wont drain from dishwasher
Hi
Daniel
Jan 01, 2011 | Dishwashers
Dishwasher wont drain even after running rince cycle is there steps to reset system ;ready to overflow
Hi
Daniel
Oct 26, 2010 | GE 24 in. GLD5860LSS Stainless Still...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
