Question about Electrolux Guardian Bagged Canister Vacuum
You might not believe this but i don't know how to turn it on. I thought it was on the power nozzel but It is just got an orange light on. I know this sounds silly but please help me.
  • 694 Answers
The on/off switch is located on the hose handle. The "O" is for off, "I" is vacuum only, and "II" is for vacuum and power nozzle. The light below the switch indicates there is power to the vacuum.
If your vacuum doesn't run, there are several things that could cause it. Refer to the manual, or take it to an Aerus Electrolux store for help.
If you need a manual, you can download one from the following site, under older models.
http://www.aerusvacuums.com/support/manuals/
Posted on Apr 07, 2011
Brown wire came off where does it go. electrolux guardian power nozzel
send me picture of the wires and connection location, then I'll be able to help
Jun 13, 2012 | Electrolux Guardian Bagged Canister Vacuum
Need help with power nozzel wiring. Two black connectors and a white and a grey connector. How do you arrange them in the power nozzel?
Give me a picture of your wires and connector and I'll tell you how to hook them up...or how they should be connected
Sep 09, 2011 | Electrolux Guardian Bagged Canister Vacuum
My Rainbow Power Nozzel will not **** up things
Check your belt and make sure your brushroll is good.
Oct 20, 2009 | Vacuums
How do i open the roller area to my kenmore canister vacuum
You have to take off the top of the power nozzel that has the light lense. There are two pressure locks,one on each side. Use a screw driver to release. You will see the screws.Take the two screws out and on some models, there are two pressure locks on the back of the nozzel. Again use the screw driver to release. The top should come right off.Hope this helps.
Oct 18, 2009 | Kenmore 25512/ 25513 Progressive Canister...
My vacuum hose won't power on but the vacuum in the attic powers on
I guess you are talking about the power nozzel not working. Try pushing the reset button on the top of the power nozzel first. Make sure you have the switch on the hose handle is in the right possition. If it still dosen't work, you could have a bad switch or a broken wire in the hose itself. If this is the case, you'll have to take it to the shop. All you need to take is the hose and the power nozzel.
Oct 18, 2009 | Electrolux Central Vacuum
I can't seem to get the belt cover off of my Kenmore Progressive 400. There are two buttons that say above "belt and bulb change" but the buttons do not move. Do you know how I can remove so I can put a...
Oct 18, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Just bought new power head electrolux guardian and
Did you get new wands with the power nozzel? The wires that power the nozzel run through the wands from the hose to the nozzel.The connectors at the end of the wires are fomous for getting too big and making a bad connection. This causes the on/off problem. This will only get worse if you continued use. The wires in the hose handle, the hose and the power nozzel elbow can all be changed out. You will not have to replace the hose handle or the wands unless the plactic has been burned. (A loose electrical connection causes heat). Take your hose,wands and nozzel to the shop for repair. Don't let the sales/service manager tell you that you need new parts until you can see the parts are bad. I think they saw you comming when they sold you the new nozzel.(just my opinion)
Oct 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
Water will not shoot out of unit in order to suction up the dirt
Hot water in the soap well and kept using the trigger to flush out the old soap that had dried near the nozzels.
Aug 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Electrolux powernozzle not working
mine was the power head neck itself the handle got twisted to far and broke the wire a new neck cost 37 bucks online and i installed it myself wires get attached color to color and screw the head back together. it worked just like new!
Mar 18, 2009 | Electrolux Centralux Vacuum
Electrolux Guardian Bagged Canister Vacuum Logo
76 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
