Question about Samsung SyncMaster 912N 19" Flat Panel LCD Monitor
How to get rid of MagicBright? What is the solution for a Magicbright screen mode on a samsung moniter (SyncMaster 933SN) which is cycling through all the modes without any control, causing the screen to change brightness every couple of seconds.
SOURCE: Samsung SyncMaster 193V magicbright
hold the menu button down until the menu disapears again
Posted on Sep 07, 2008
  • 35 Answers
SOURCE: Power button
There may be two chances , I have the experience but it was resolved by the first one
1. You should full scan your PC with any good and Updated antivirus.
2. Also you should try to re-install your monitor drivers but check with the first one, the problem will get resolved definately.
Posted on Sep 20, 2008
digritz
  • 530 Answers
SOURCE: I have a Samsung SyncMaster 933SN 18.5 monitor. Just goes black
I can not say for sure but the most likely culprit is one or more bad capacitors. This is a known issue with other Samsung monitors. My 930B recently had the same problem.
The only way to be sure is to disassemble the monitor and inspect the pcb (printed circuit board).
You are looking for caps with bulging tops.
Although it is not a difficult repair it does require experience repairing electronics.
I would wait until you can no longer use the monitor before attempting any repairs. At that point you have nothing to loss.
If you decide to try this repair and you wish for any help please let me know. I also included a link that provides some info on repair an LCD monitor.
Hope this helps and good luck.
http://www.aplusperfect.com/articles/lcd_capacitor_repair
Posted on Jun 21, 2010
SOURCE: magicbright keeps flashing on. how
Solution: Unplug your monitor for a couple minutes, plug it in and magic, it is fixed.
Posted on Feb 17, 2011
  • 332 Answers
SOURCE: i am trying to connect
Your resolution is set to high for the monitor to accept it. Go into control panel and click on Display then click on display setting and lower your resolution keep going lower until your monitor accepts the resolution size and your monitor should work for you.
I hope this helps you out any positive feedback to me would be greatly appreciated.Thank you
Posted on Apr 09, 2011
Won't stop cycling through brightness settings
sounds like it might need a cleaning. are the buttons hard to push or are any of them giving you a different feeling then the rest?
Aug 13, 2017 | Samsung SyncMaster 2233SW Monitor
I want to remove MagicBright from my screen, it is blocking bottom left of screen and has been for days, I want it out of the system, I don't know how it got into the computer.
unplug then open the case then remove the little white plug from rear of switches job done no power light or buttons but picture is fine ; )
Jul 19, 2011 | Samsung SyncMaster 720N Monitor
Our samsung syncmaster 2493hm fades to black when on websites with dark color backgrounds. How Come? Is there a fix?
Its probibly the MagicBright settings, press the button next to the menu button (its down arrow) and change the settings to something else, i changed mine from "Dynamic Contrast" to "Game" and everything is as they should be now.
Jul 13, 2011 | Samsung SyncMaster 2493HM Monitor
Magicbright keeps flashing on. how do i disable it
Jan 05, 2011 | Samsung SyncMaster 720N Monitor
I have samsung syncmaster 933 monitor. It keeps blinking on and off. We have rebooted, unplugged and replugged all connects from pc to monitor and still it keeps blinking on and off. Not able to...
It may have unstable DC voltages due to failing DC filter caps which is very common problem to all LCD monitors as shown in my albums.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 20, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Want to unlock my monitor
This is the function that locks the OSD in order to keep the current states of
settings or prevent others from adjusting the current settings.
1. Lock : Hold down the menu button for more than five seconds to activate
the OSD adjustment lock function.
2. Unlock : Hold down the menu button for more than five seconds to
deactivate the OSD adjustment lock function.
Though the OSD adjustment lock function is activated, you can still
adjust the brightness and contrast, and adjust MagicBright ( )
using the Direct button.
Found at: http://www.retrevo.com/support/Samsung-713BM-PLUS-Monitors-manual/id/2994ag905/t/2/
Hope this helps and please remeber to give me a rating, thanks!
OpenSource13
Apr 06, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
Problem with Samsung SyncMaster 226BW
Click the top button on the side of the monitor to open the monitor's settings. In the "Picture" Settings, scroll down to "MagicBright" and open those settings. Chances are you have it set to "Dynamic Contrast". Switch that up to any of the other settings and then it won't try to adjust the gamma based on what is on the screen.
Hope this helps, I struggled with the same problem for quite a while until I found this setting.
Feb 19, 2009 | Samsung 226BW Monitor
Power button
I found this tread on another forum. I found it may help you to read it for you monitor problem. It makes sense to me so I'm passing it on.
http://www.daniweb.com/forums/thread17104.html
Sep 20, 2008 | Samsung SyncMaster 216BW Monitor
Mar 11, 2007 | Samsung SyncMaster 193V 19" Flat Panel LCD...
Samsung SyncMaster 912N 19" Flat Panel LCD Monitor Logo
716 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
