Question about Meade ETX-70 (240 x 70mm) Telescope
Hi, Original focus knob fell off my atx 70 and now the 'focus rod' goes inside the telescope instead of moving front part. Is there any way to fix it?
  • alinoee Apr 15, 2011
    Thanks Joe. I have seen the screw but my problem was not the knob (it is very uncomfortable to use and i've replaced it already) but the 'focus rod' . I took telescope apart and now I know what the problem is. I have to go to well stocked hardware store anyway : )! thanks again.
  • 3,186 Answers
The knob had a tiny set screw on the side of it-- that tightened down on the shaft.
See if you can tighten it back up. If it is missing take it to a well stocked hard ware store and see if you can find a replacement Allen style set-screw.
Posted on Apr 07, 2011
    Thanks Joe. I've seen screw but problem was with the 'focus rod'. (I have replaced original knob already since its not very comfortable). I took scope apart and sorted problem out but still need to visit well stocked hardware shop. Thanks again.
Anyone know where to find a replacement VERTICAL LOCK KNOB for a Meade ETX-70? Or what fix might work instead?
Look at the link below for a FIX for a broken Dec knob. This is a common problem so once it is fixed do NOT overtighten.
See this:
http://www.schlatter.org/Dad/Astronomy/etx90decknb.htm
Aug 06, 2015 | Meade ETX-70 (240 x 70mm) Telescope
I have a Leica Televid 77 with a 20x - 60x zoom ocular. The scope fell over and now the zooming knob is difficult to turn. The zoom does still work, it is just much harder to turn than before. The...
Yes you bent the shaft on the knob or the gears inside the focuser. Order another complete focuser from Leica.
www.telescopeman.org
www.telescopeman.info
www.telescopeman.us
Aug 01, 2011 | Leica Televid 77 (60 x 77mm) Telescope
When I turn the focuser, the image never comes to focus. When I get to what I suspect is the end of the focus range, the tension on the knob firms up a little, but does not stop turning.
There is a rod inside that the focuser attaches too.
It may be broken inside or has come loose from the rod. Locate a local Astronomy club the members will help you figure it out.
Nov 22, 2010 | Celestron C-14 A Telescopes w/ FREE UPS
HI, Just purchased a nextstar 8 and when I tried to view thru the main eye-piece, nothing. Even tried to look at the full moon, nothing again. Yes, all the lens caps are off but it seems like the focas...
Check the focus knob and make sure the small "set-screw" is tight and the knob is just not spinning around on the shaft.
DID you turn the knob enough to focus? Sometimes it may take 10 - 20 full turns.
Finally the focuser is attached to a "rod" inside the tube that moves the mirror back and forth to focus the scope. It could have come loose from the rod?
Instructions for disassembly are here:
http://www.celestron.com/c3/support3/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=2220
and here:
http://www.sciencecenter.net/hutech/misc/focuslk/index.htm this just shows how it works.
Oct 24, 2010 | Celestron NexStar 8i (600 x 203mm)...
My focus knob does not work correctly, is this easy to fix?
There is a tiny set screw on the side of the knob. Make sure this is tight, and the knob is not just spinning around and around.
There is also a small rod inside -- that the focuser attaches to. If tightening the setscrew does not fix it, you will need to remove the focuser and see if it is detached from the rod. Make sure the scope is tilted BACK with the front of the scope UP a little or the mirror will slide to the front and possibly break.
This web site has lots of repair pictures--
http://www.weasner.com/etx/menu.html
Aug 09, 2010 | Meade ETX-125EC (500 x 127mm) Telescope
My NexStar 8 SE doesn't focus. When the focuser knob is rotated either direction it moves the image up or down.
The knob could have come loose from the mirror. This would require a return to Celestron for repair or a complete disassembly of the rear of the scope,
You can remove the focuser, and MAYBE it is just detached from the rod inside that moves the mirror back and forth.
Celestron support:
http://www.celestron.com/c3/page.php?PageID=37
Aug 01, 2010 | Celestron Optics
Need a focus knob for a MEADE ETX-70 TELESCOPE
You can try calling Meade here:
http://www.meade.com/support/index.html
Apr 15, 2010 | Meade ETX-70 (240 x 70mm) Telescope
Turning the focus knob on my Meade LX50 Schmidt-Cassegrain Telescope does not change the focus; does not move the primary mirror. I need an exploded diagram and/or step by step instructions on how to...
The focuser has probably come loose from the "rod" on the mirror.
Here is the focuser disassemble instructions:
http://www.petealbrecht.com/Installing%20Digifocus.pdf
and this shows how to disassemble the main tube-
http://www.astromart.com/articles/article.asp?article_id=594
Jan 03, 2010 | Meade LX50 (8105003) (500 x 203mm)...
LX10 won't come into focus. I'm not talking about blurry stars-it won't focus at all.
The focus knob connects to a small "rod" attached to the mirror housing. The rod may have slipped out of the small hole in the end of the focuser (inside).
Remove the focuser and reattach the "rod".
Jul 12, 2009 | Meade Optics
Telescope knob
Still not enough information, but taking a stab at it, I'll assume you mean the pinion rod that goes between the focus knobs, and engages a gear rack on the focuser. There are locations where they can be purchased, and you would need to provide the OD and pitch (teeth per radian) to match.
Try: http://www.pinionrod.com/ as a source.
Jun 13, 2008 | Optics
Meade ETX-70 (240 x 70mm) Telescope Logo
130 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
