Question about JBL PRX612M 12 Inch Two Way Self Powered Monitor Speaker 1000 Watt Portable and Flyable
I have just bought a PRX612M. When I play my digital piano through it at low volume there is a buzz which is most noticable as the notes volume dies down. Loud it sounds great but i would love to know what is happening here. I know it has a 1000W amplifier inside so asking it to perform well at 10W is a big ask but it would be nice to have that capability too. The buzz sounds digital and is very similar to the speaker coil scraping. The piano is a yamaha P120 which sounds fine through my other amp.
  • JBL Master
  • 5,603 Answers
1000 Watts? Well, those are peak values. !000 watts RMS into a 12 inch speaker and it would smoke... this is some of our inflated advertising. But that is beside rhe point... now on to your problem: What you are having is a ground loop. You may have to do more than one thing to correct this here is the things to do in the order to do them to solve the problem:
1. Connect the piano and the speaker to the SAME power source or receptacle, even if you have to run an extension cord, three wire of course. Plug all of this ONLY into a grounded outlet, if your house has only two wire plugs, then you need to get an electrician to install a grounded receptacle.
2. Use Balanced lines. This means XLR or TRS balanced cables between the piano and the speaker. Use the 1/4 inch jacks output, not the RCA ones.
3. Since the AUX outputs do not support balanced lines, the next step require you use DI box. They are about $20 from Guitar Center and others. With very short 1/4 inch mono cable connect the piano to the DI box from the L/R mono piano to the high impedance input port of the DI and set the ground lift switch to "LIFT". Use an XLR to XLR cable from the DI box to the speaker. This last step if needed is the last thing in our bag of tricks to break the ground loop that can cause the buzz. Dirty power, if you have lamp dimmers can be a source of the noise.
Posted on Apr 06, 2011
  • 2 more comments
  • arling_tree Apr 06, 2011
    A big thank you. Your response arrived about an hour after i posted my problem and your first suggestion has now fixed the problem. All smiles again and i thought i was going to have to do a 2hr trip back to the shop with it.
    I'm in Australia and we have 3 pin power here. The wall outlets were about 6m apart. Does this mean that they're not earthed correctly?
    A big thank you again.
    steve, perth
  • Fred Yearian Apr 06, 2011
    In regard to your question about earthing... This is a little bit of engineering theory... EVERY piece of wire is an inductor and a resistor and noise can rattle the grounds AND the other wires relative to those at another receptacle. An even bigger problem is a receptacle that shares different feeds from the breaker box and has OTHER loads on that feed. It can bounce all over the place. Our audio equipment can tolerate about 15 volts before being damaged, but long before we get to that voltage we will likely notice hum and buzz in our equipment. Print my suggestions for future reference should you run into trouble again. Thank you for letting me know the outcome...
  • arling_tree Apr 11, 2011
    After having a bit more time to play with the prx612M I have found that the problem was from using a 20 ft unbalanced lead. With a 10 ft unbalanced lead all works perfectly but with a 20ft lead it was picking up noise from the fixed mains wiring under the floor-boards. I thought that plugging the keyboard and amp into the same outlet had fixed the problem but it hadn't - unless the signal cable was kept away from all mains cables. I have oredered a passive di box for longer cable runs. steve in perth.
  • Fred Yearian Apr 11, 2011
    Yes, use balanced line XLR to the speaker with a DI near the keyboard and a short (few feet at most cable from the keyboard to the DI box. Put the DI box on "Ground Lift" to avoid a power ground loop on the balanced cable. Use HIGHER gain OUT of the keyboard (say at 70% setting) and LESSER gain at the speaker to improve signal-to-noise ratio.
Some buzzing in left speaker when low notes played
A couple of possibilities
One the speaker broke loose, typically there is lock tight on the threads that hold the speaker in place, lower frequencies can also cause buzzing noise,
I have fixed this problem in the past with a hot glue gun, running a small bead carefully around the edges of the speaker, bonding it to the unit,
Another possibility is the speaker is blown or worn out, over time speakers can weaken from constant use and coil movement, in this case the speaker should be replaced...
Hope this helps?
Mar 13, 2015 | Yamaha P-105 Digital Piano, Black
I have a digital piano and the sound is distorted when playing notes on the left hand (.i.e notes lower than the middle c)side of the keyboard note?
Sounds like either there is a problem with a low frequency driver or perhaps an eq setting.
If you have an external (line) output, you can try sending the signl through another amp. If you have headphones, then try them also. If the headphones sound distorted as well,then see if you have the eq to high on the bass.
Other than that, it could be a filter capacitor in the power supply. You would need some experience fixing that.
Jan 05, 2015 | Williams Overture 88 Key Digital Piano
Some notes on keyboard leave a horrible piercing static noise when volume is turned three quarters up.
Sounds like feedback from your monitors, the speakers can't be pointing in the direction of the mic.
Sep 09, 2017 | Yamaha Piaggero NP11 61 Key Digital Piano
Volume keyboard
Go into function and look for the volume setting for your main voice - could be R1. This will give a numeric value of 127 or less. It sounds like you need to increase it, try 100 as that is usually sufficient.
Dec 27, 2013 | Yamaha DGX230 - Digital Piano
Yamana DGX 630 E keys make strange sound
Perhaps the performance assistant technology is turned on.
Press the [PERFORMANCE ASSISTANT] button to turn it off.
Jan 12, 2013 | Yamaha DGX630 - Digital Piano
Playing certain 3 or 4 notes at a time causing sound of one or more extra notes.is there a quick fix?
Have a professional tune it for you. It may be that some strings have loosened/tightened.
Sep 06, 2012 | Yamaha P95 Digital Piano
Volume on the piano is less than half the volume it should be. Demo and play along songs play at full volume but keyboard wont no matter how hard the key is pressed, Is there a fix for this...
Pianos do NOT respond to keys pressed hard... they respond to FAST presses. If you have an issue with the piano, first go on record to activate your warranty. Most of these electronics DO have a setting that adjusts the "feel" which affects the loudness versus key velocity... Now here is a secret??? Shh... The manufacturers turn up the demos just like the advertisers turn up the commercials on the TV... I would suggest looking for the adjustment of feel, and if that doesn't get satisfactory results, find another and compare yours to another... if yours is still underperforming, exercise your warranty for repair or replacement.
Jun 11, 2011 | Williams Encore Digital Piano
My Korg c15s has a lot of grating staticky noises when played ....I'm told it cannot be repaired as Korg no longer makes parts for this model?
I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
I hope this info helps a bit.
Aug 18, 2010 | Yamaha Full-Size Keyboard
JBL PRX612M 12 Inch Two Way Self Powered Monitor Speaker 1000 Watt Portable and Flyable Logo
310 people viewed this question
Top JBL Music Experts
Michial Gueffroy
William Covington
Level 1 Expert
Richard Enyeart
Richard Enyeart
Are you a JBL Music Expert? Answer questions, earn points and help others
