Question about Whirlpool WTW5500ST Top-Load Washer
I have a problem with my nikai topload washing machine, during the operation the unit stop and there is an E4 indicated in the display board, can you help me and reminds me the probable cause of this error code,
  • 183 Answers
SOURCE: f24
heater or drain fault Regards Engineer
Posted on Jul 30, 2007
Master_Tech
  • 770 Answers
SOURCE: 5L error code
I will pull the book and get back to you today
Posted on Jan 27, 2008
taran_2005
  • 10515 Answers
SOURCE: F35 error code constantly causes washing machine
Both of these indicate that there is a Problem with Pressure Switch.On Most of the Whirlpool Washer's ( Duet ), if you Open the top panel, then there would be 3 Screws. After that you would have an access to Pressure Switch.With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after doing this, you will likely need to replace the pressure switch.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Mar 02, 2010
jsrock516
  • 5911 Answers
SOURCE: Error Codes"5ud" and "02" and "F"
The two error codes together indicate you have something restricting the drainage system. "F02"is a Long Drain error code, "SUDS" occurs when too much air is sensed in the drainage system. In most cases, the drain pump reservoir needs to be cleaned out. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you check the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, first and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage this small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Mar 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: Washing machine displays an LF error code.
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 07, 2010
Testimonial: "We followed your suggestion and disconnected the hoses and they had "gunk" in them. We flushed them out, reconnected and everything seems to be fine."
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
Dishwasher is beeping and showing code E4
There really isn't a standard for dishwasher error codes. Need to know the manufacturer and model number to proceed. This could be a fault with the float in the fill or overflow sensing that there's too much water. You might try removing the water and letting the machine dry out. Could be too much suds from combo cheap detergent and rinse agent.
Feb 27, 2015 | Washing Machines
What is e4 indication
What is the make and model number of your unit?
Nov 01, 2012 | Washing Machines
E4 error cade my whirlpool ww1307
my washing machine doesnt have a display in the control panel..sometimes it works sometimes no..anybody can help me...whirlpool ww 1307
Jun 16, 2012 | Whirlpool Washing Machines
I GET A ERROR MESSAGE E4???? After restarting the machine everything seems to be fine. Can somebody explain me what this is supposued to mean? Thanks
E4 indicates an unbalanced condition.
Stop the unit, re-arrange the load and procede normal cycle.
http://www.avantiproducts.com/manual/w757.pdf
Your manual for your washer is in the above link.
Hope this helps...
Jul 23, 2011 | Avanti Top Load Washer W797
I have a GE Profile top loading washer mdl # WPGT9150 and I have a question about a problem I am having with it. The washer stops halfway through the wash cycle and the electronic board flashes E4, and I...
E4 is an error code indicating a problem with the water inlet valve or the electronics that control the inlet valve. Error codes do not necessarily indicate the problem directly.
Here is the service manual (with diagnostic procedures) for your machine:
http://www.geservicenet.com/cc/trngprog/ProfileWasherWPGT9150.pdf
Good luck.
Mar 01, 2011 | GE Washing Machines
User guide washing machine nikai
I have nikai top loading washing machine6.5 kg, machine showing error code E8 , what is the problem, i have no manual booklet , so please tell the problem to solve.
Jan 28, 2011 | Washing Machines
Unit operates for a couple of minutes then beeps consistently and the compressor then stops and shortly after the fan stops screen indicates E4
E-4 ..........short of asor no gas/E4 is an "Abnormality of Outdoor Unit."Please call repairman to check gas leak and then arrest the same by brazing. Then vacumizing and gas charging.
Dec 16, 2010 | Heating & Cooling
My Kenwood dishwasher keeps displaying error message E4 but there is no mention of this in the user manual. Can you explain what this means
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
Hope this help?
Thanks.
Nov 02, 2010 | Kenwood KDW243A Builtin Dishwasher
Whirlpool WTW5500ST Top-Load Washer Logo
67 people viewed this question
Dan Webster
Dan Webster
Sal De
