Question about Sanyo PLC-XT25 LCD Projector
Instructions on changing bulb - Sanyo PLC-XT25 LCD Projector
  • 442 Answers
Turn off the projector, unplug the AC power cord, let it cool for 45 minutes.
remove the screw that holds the lamp cover on.
remove the 2 screws that hold the lamp in. lift the lamp out by the handle.
replace with new lamp and do the reverse.
reset the lamp counter.
press the menu button.
go to setting menu, then to lamp counter, press select button, select reset, select YES. then YES aqain.
Posted on Apr 07, 2011
Why is the bulb light shows to change and it has new bulb?
I dont know if you skipped this step but you should reset the lamp usage time by selecting "Yes" for
Lamp Reset in the OSD Lamp tab. Page 48 on the instruction manual.
Sep 02, 2014 | Dell 1210S Projector
How do you change light bulb on Singer 7444 portable sewing machine?
Instructions regarding changing the light bulb are in your user's manual. If you don't have it, you can download a .pdf copy free from the Singer site, and here's the link. Instruction Manuals
Jul 11, 2014 | Singer 7444 Mechanical Sewing Machine
Check engine light bulb is out how do i replace
The easiest is to get instructions for a gauge overlay and follow the instructions on removing the cluster to get to the bulbs.
The bulbs are 1/4 bulb holders from the back.
Here is a thread on changing the bulbs to LEDs :
http://www.f150online.com/forums/articles-how-tos/372987-how-change-your-cluster-color-97-03-a.html
Dec 12, 2010 | 1998 Ford F150 Regular Cab
Changing bulb
Changing bulb in Sony KDF-60XBR950 is easy.
Click Sony Support to download lamp replacement instruction manual for your TV.
Please buy Sony original lamp/ bulb for your TV safety.
Thanks.
Dec 29, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I have read the owners manual word for word and followed it, but I cannot change the low beam bulb on my 2002 chrysler 300m
hi it not to hard there a couple of 10 mm bolts to take the headlights out then change the the bulb &reinstall headlight assy
Jul 10, 2009 | 2002 Chrysler 300M
I need clearer instruction on replace back window light bulb
In the trunk look at the bottom of the fixture. There will tabs to push and release the fixture. Go back inside and remove bulb and put new 921 in.
May 19, 2009 | 2000 Toyota Avalon
Should I change the bulb?
Hi MovieJunkie9,
I would first recommend having a diagnosis done by a Toshiba authorized technician. Bulbs for projection televisions are typically a costly part, so I would not advise replacing it if you are not sure it is needed.
Second, make sure that your product's manual lists the bulb as a user-serviceable part and gives specific instructions for you to change the bulb to make sure you do not do any damage to your unit.
So long as your manual gives you instructions for changing your bulb and the Toshiba authorized technician diagnoses that the bulb is the issue, you should be able to go ahead and change the bulb yourself.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 04, 2008 | Televison & Video
915P043010 have the bulb
Pull the panel off where the speakers are the entire plastic lover comes off. Next, make sure the tv is unplugged and has been off for at least 15 min, preferably longer. See the box with 4 screws take those out... it should have a set of instructions or some sign saying it contains the bulb. Anyway.. after that door comes off, peer inside and you'll see the bulb about 6-8" back and has set screws which must be unscrewed completely before it can come out. Be careful, don't yank the bulb out. Then place the new bulb in, reverse the process I told you, plug the tv in and reset the bulb when it askes if you changed the bulb.
It is really easy on mitsubishi tv's to change them... post back if I can be of further assistance.
bob
Mar 10, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Fan instructions to disassemble unit to allow changing upper globe bulbs
should be a set of screws around the outer edge, loosen while holding the globe, some globes if there are no screws twist off, be very careful.
Dec 03, 2007 | Dryers
Sanyo PLC-XT25 LCD Projector Logo
102 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
