Question about Sewing Machines
Id like to buy lover looper for brothe lock546
    Genius:
  • 1,788 Answers
I think that you could check out www.sewingpartsonline.com, and you will see one for about $22., you can then have an idea what they cost and try other sites. I have used them before and was happy to receive my parts on time. But there are other sites too that are good.
Posted on Apr 06, 2011
Can I buy a lower looper for my 334Ds overlockers and can I instal it myself
You probably can. Search for:
Make Model lower looper
or
Make Model parts
However, if the lower looper was damaged, it's possible the machine was also knocked out of time that may very well require a professional to repair.
May 10, 2017 | Sewing Machines
If I break the lower looper how can I found the lower looper
Are you looking for a replacement looper? Typically, this is a "take it to the shop" repair because there's some finicky adjustments needed when replacing a looper, but if you have a spare looper and a lot of patience, some people can do it. Because breaking a looper can do a lot of damage, I tend to be of the "take it to the shop" persuasion, but try entering a search for the machine make and model plus the phrase "lower looper" in something like the google shopping search. E.g.: here's the lower looper for a machine I own: http://www.sewingpartsonline.com/juki-mo655de-serger-machine-parts.aspx
Apr 28, 2014 | Sewing Machines
Elna overlocke L1 brocken lover lopper
if the lower looper is broken, then I need the model number of
the overlocker and I will check to see if I can find one.
Dec 21, 2012 | Elna Sewing Machines
I have a Huskylock 936 Serger and used it last week, no problem. I changed the threads for a new product and one thread came out and had to rethread. I know you have to thread the upper looper first then...
Recommend you remove all the threads and rethread from the beginning. ALWAYS RAISE THE PRESSER FOOT when threading and thread the upper looper first, the lower looper second. Sergers sometimes are temperamental about threading. When in doubt, start over from the beginning.
Jun 14, 2017 | Husqvarna Huskylock Computerized 936
I have a bernina overlocker and whenever I use it the lower looper (marked in red) thread breaks. How can I fix this? It was serviced yesterday and when other people used it before me it worked fine!
Then it's one of two things. First try setting your lower looper tension on 3 and see if that works. If not set it back on 4 and cut ALL your threads and re-thread the machine STARTING with the UPPER looper, then the lower looper, then the right needle, last the left needle if you're sewing a 4 thread overlock stitch. Make sure the threads aren't twisted in the thread guide. Make sure the lower looper thread is OVER the elbow on the upper looper and over the upper looper thread. Let me know if this works. We'll work until we get it fixed!
Sep 14, 2010 | Sewing Machines
Where is the upper looper on Baby Lock Eclipse model DX
This is what an upper looper looks like http://www.tradekey.com/selloffer_view/id/3755146.htm
It is the one in the back and point toward the needles.
The looper in the front is the lower looper and points away from the needles.
Open both doors on the front of the serger and you will see the loopers to the left of the thread ports.
Mar 28, 2010 | Baby Lock Eclipse Serger
Juki 6700 looper number
lower looper part no.: 119-99307
upper looper for 3 thread and 5 thread : 118-88104
upper looper for 4 thread : 121-76004
Sep 28, 2009 | Juki Sewing Machines
Easy Lock Serger Broken Lower Looper
You will need to buy a new looper from a dealer with a spare parts account for this brand.
It is tricky to set up the loopers without a service manual, so best suggest you also have them install and service the machine at the same time or you risk breaking the new one if it is even slightly out of alignment.
You may also find that parts availability at this time of year will be restricted as many businesses and suppliers close for several weeks.
Dec 26, 2008 | Sewing Machines
Threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
My 1034D serger has a broken part that holds the lower looper.
call brothers hot line 1-901-373-6256 tell them your problem and part no, if you know it if not they should be able to help you
Aug 16, 2007 | Brother 1034D Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
