Question about Marshall Amplification Marshall MG15CD 2-Channel 15-Watt Guitar Amp
Both the gain and volume pots on the overdrive channel have poor connections and crackle and cut out a lot when turning. They also cut the sound intermittantly when playing and require a jiggle or a tap to restore sound. How do I go about fixing this?
  • 5 Answers
Dirty contacts inside the potentiometers (variable resistor knobs) cause this.
The cheap quick way to help this is to work the pots back and fourth a bunch of times, this will scrape away some of the oxidation and dust on the contacts.
The mid term way to fix this is to use a electrical contact cleaner like Deoxit. This must be able to get inside the pots so some disassembly of the device may be necessary to get to the back of the pots and spray or pour the cleaner into the pots and then work them back and fourth.
A long term way to fix is to actually desolder and replace the pots with new ones of the same size, value and taper.
Posted on Mar 05, 2015
  • 3,400 Answers
Stop by Guitar Center and they carry spray product(s) made for cleaning "pots" IE: Blue magic, etc...
Posted on Apr 06, 2011
Left speaker not working, system crackles if left side is active, alright when left side shut down.
Get a meter and check the resistance on the speaker. Looks like a speaker may be blown but with the description of the crackle noise from the slide controls you might have a bad pot in the unit or the pot has come loose from the board. This could explain why the speaker blew out
Jul 30, 2015 | Behringer Europort EPA150 Ultra-Compact...
Why does the left channel of mixer randomly crackle, distort, and/or cut-out?
left channel control pot dirty most likely. is there a slider type pot on channel? this would have to be cleaned with dustoff spray.
May 06, 2012 | Behringer Music
Extreme differences on overdrive channel
Please, take it to a tech in your area, or look for a good one to ship it to. An 2007 amp is not old at all.
Jul 24, 2017 | Marshall Mg100dfx 100-Watt Combo Guitar...
My peavy kb300 produces a crackling noise & cuts off intermitently when I raise the volume on all 3 chanels.
Low Voltage power supply regulation issue, particularly with +15V and -15V.
Dec 23, 2011 | Peavey Music
No sound when on overdrive
I am guessing that an IC is at fault. You don't really mean something like "no sound when switching to channel two" do you? If that's the case it could be a defect in a pot such as the volume pot. I have worked on hundreds of Marshall amps over the years. You can email me at computerlen@hotmail.com anytime for help if you want.
Jun 17, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
I have the LR baggs Element Active VTC in my Seagull. It works fine, except when I plug it into the PA system at church. There is a windy, rumbling-type sound that happens whenever the volume knob is...
In the first place you CANNOT connect your guitar directely to the snake ! You must use a DI box to convert the unbalanced output of the Baggs to balanced (differential) drive to the snake using either XLR or TRS cable. The DI should be driven as a HIGH impedance in and using "ground lift".
If the pots are noisy, lube sparingly with CRC 226 available in the electrical dept of Home Depot in a spray can with spout for about $2.70. Spray using the spout into the side where the leads go into the pot.
The volume pot is overly sensitive because you are overdriving the mixer at the other end. The trim on that channel of the mixer probably has to be reduced as well.
Dec 23, 2010 | L R Baggs Eas Element Active Acoustic...
On clean channel when 'channel volume' is adjusted, the sound cuts out, goes completely dead. I have to switch to another channel and back again or switch off and back on. The amp seems to get confused!
When it is working, wiggle the channel volume control WITHOUT rotating. If the sound cuts out, likely the soldering of the pot leads is broken where it attaches to the board. Try resoldering the connections.
SOMETIMES the control is damaged in which case it must be replaced.
Aug 30, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Marshall MG50 DFX, the volume knob OD channel crackles
Either the control is damaged (happens if they get hit) or it is possible the circuit board it is mounted on has broken solder OR worse, a crack near the control. The unit will require servicing. Parts are readily available.
Jan 28, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Problems with certain channels and there gain pots
I assume you are talking about an audio mixer, here's what i think:
I'm not sure about channels 12 and 16, but channels 6 and 9 seem like having some loose solder contacts, which usually occur with long term use - you need to remove the problematic channel strips and check the solder contacts on any of the pots / switches / connectors that protrude through the top panel - resolder any loose or bad solder contacts (i usually resolder ALL pins on ALL connectors, pots and switches just to be sure).
As for the lower gain on CH12 - see if the mixing slider is connected via wires, if so, compare it to the connections on other channels, see if there is a loose wire or if the wires are connected in a wrong way (i had a "lower gain" issue with a mixer once that turned out to be a wrongly connected mixing slider - i obviously wasn't the first person to repair that mixer...)
Channel 16: check input preamp IC, could be a bad electrolytic filter capacitor or other components, possibly a faulty IC.
Hope some of this helps...
regards
3rq8 (Triarcuate)
Sep 06, 2009 | Music
Marshall Amplification Marshall MG15CD 2-Channel 15-Watt Guitar Amp Logo
271 people viewed this question
Top Marshall Amplification Music Experts
Michial Gueffroy
Vito Vacirca Jr.
matt martin
matt martin
Are you a Marshall Amplification Music Expert? Answer questions, earn points and help others
