Question about Toshiba Satellite A200-1DA Notebook
Toshiba satellite hangs when adaptor is pluged in
  • Toshiba Master
  • 17,130 Answers
If the laptop works fine with the battery but fails when the adapter is plugged , the there are transient voltages from the adapters SMPS. You will need to remove and check for failure of capacitors, possible the main tank capacitor is leaking or under value.
open and confirm but do not connect to laptop unless this is checked as you can damage the mother board.
Posted on Apr 06, 2011
Hi. I have a Toshiba laptop a205 s5812. The problem is when I start it with AC adaptor connected it wont start. If I start it without connecting the adaptor it works fine, but once on if I connect the...
Although this may only be a temporary solution, try connecting the adapter but taking the battery out. Now try turning on the laptop. It should work. Unfortunately, this means that you will need to always connect the laptop to the wall when you want to use it.
Mar 21, 2011 | Toshiba Satellite A205-S4777 Notebook
Toshiba satellite L300 freeze when adaptor plug in.
This is a middle pin issue, you will find the laptop doesn't charge either but will power the unit, if the power is connected, the laptop will hang and use reserve resources, if you unplug it, the machines performance will dramatically increase.
replace your power adaptor and all will be fine, i have had the same issue.
Sep 02, 2010 | Toshiba Satellite Pro L300 Notebook
The charging light flashes on my toshiba l30 but computer doesn't start
could be anything from a bad adaptor to a bad battery , how ever sometimes the fan is pluged with dust ,blow on the fan and see if you get the fan started ,the computer wont start without the cooling fan on to protect the processor
Apr 10, 2009 | Toshiba Satellite L305D-S5904 Laptop
Toshiba wont charge
Sound like you may have the wrong power cord for your unit. The original power adaptor for the A105 is 75W (15V x5A) Auto sensing 100-240V/50-60MHz frequency input. If you got a replacement adaptor, I would reccomend a 75W or higher adaptor. (A new opposed to a used one.) Good Luck.
Feb 02, 2009 | Toshiba Satellite A105 Notebook
Need an adaptor for a toshiba satellite
YOU CAN USE 15V 6A ADAPTOR FOR YOUR LAPTOP
YOU CAN USE 90W INSTEED OF 75 WATTS CAPACITY
Jan 23, 2009 | Toshiba Satellite 15" Flat Panel LCD...
Toshiba Satellite A105-S4064; can't get battery to charge
If you put strain on the jack (e.g. hang power adaptor from it whilst using or charging) then the socket on the mainboard can get hot due to poor contact and melt.
There is no way to fix this except to completely dismantle the laptop and fit a new socket - most likely a repair centre will charge you for a new mainboard.
Try another adaptor to see if that is the problem (broken wire in cord) - otherwise look closely at the socket in the notebook.
Aug 08, 2008 | Toshiba Satellite A105 Notebook
Laptop doesnt start
there must be a problem with the voltage output of the adaptor... because many modern laptops react by shutting down when they encounter voltage ranges that they r not supposed to...
Feb 01, 2008 | Toshiba Satellite A45-S151 Notebook
My toshiba satellite a135-s2276 won't turn on
A coworker used to work for Toshiba and said that this is common for the Satellite A135 models and under warranty the fix was a motherboard swap for a newer/updated motherboard. Otherwise the unit is unusable.
Dana
Jan 24, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A200-1DA Notebook Logo
187 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
