Question about Canon PIXMA MX870 Wireless Office All-in-One InkJet Printer
When printer selects paper from rear tray the centre rubber creases paper causing it to jam
  • Canon Master
  • 17,130 Answers
It seems to be fault in the transport of the paper in the rollers which can be bad or has some sticky substance .If you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Posted on Apr 06, 2011
How can I clear a paper jam on Kodak all in one printer?
www.kodak.com/go/aiosupport
Getting help on the Web
For more troubleshooting information:
Paper jam
• Check for paper in the rear-access cleanout area.
• Open the printer access door and gently remove any paper from inside the printer.
• Make sure the paper in the tray is free of tears or creases.
• Make sure you do not overload the paper tray.
For more information, go to
www.kodak.com/go/stepbystep
Jan 03, 2015 | Kodak ESP Office Equipment & Supplies
Why does paper keep creasing up
can I get a little more info what do you mean creases is it jamming or just coming out crinkled if it makes it through the machine check the guides and the paper type the tray is programmed for if it stops around the fuser and folds like an accordion replace the fuser
Aug 05, 2014 | Kyocera Office Equipment & Supplies
On Oki 330 have error 380 still showing after paper jam was cleared
Make sure everything is clean. Please refer to your manual for cleaning instructions; or download a new manual at http://www.okidata.com/ .
Below are how to clear a jam instructions:
How to remove jammed paper 28/07/2013
Paper handling is key to Ensure trouble-free printing. However, paper jams sometime Occur.
You can improve feeding and Avoid paper jams in your OKI printer, by following these simple steps:
Loading the Paper: When loading paper, fan the stack of paper before placing it in the tray. This will shake out any paper dust and reduce any static in the paper, two major causes of paper mis-feeds.
- Place the paper in the tray under the tabs.
- Do not fill above the "PAPER FULL" mark.
- Guides Adjust the tray for the correct paper size.
Recommended Media: Use paper specified for the printer
When printing on heavy / thick types of paper, it is best to use the manual feed tray at the front of the printer.This will Provide a straighter paper path to Prevent potential paper jams.
Cleaning: Periodically wipe the rubber rollers inside the area That holds the paper tray with a soft cloth.
dust Paper and simple wear may cause these rubber rollers to slip and not feed the paper properly.
Nov 29, 2013 | OKI C3400n Laser Printer
Dell 966 aio printer....paper jam and I cannot release paper from roller. Is there a way to release roller?
Have you read the Manual on paper removal? It mentions a rear panel that can be removed. That might free up the rollers:
If the paper jam is near the paper input tray:
1. Remove the paper tray.
2. Pull firmly on the paper to remove it.
3. Replace the paper tray.
4. Press the Select button .
5. Resend your print job to print any missing pages.
If the paper jam is not visible:
1. Turn off the printer.
2. Lift the printer unit.
3. Firmly grasp the paper, and gently pull it from the printer.
4. Close the printer unit.
5. Turn on the printer, and print the document again.
If the jam is located in the duplex unit or near the rear access door:
1. If you have a duplex unit, remove it.
2. Open the rear access door.
4. Close the rear access door.
5. Re-install the duplex unit.
6. Press the Select button to continue printing.
If the paper jam occurs near the ADF:
1. Lift the ADF cover located to the left of the ADF input tray.
2. Firmly grasp the paper, and then gently pull it from the printer.
3. Close the ADF cover.
Aug 28, 2013 | Dell 966 All-In-One InkJet Printer
Image Clas 6530 paper jam: turns blank paper into accordian!! This opier has been a life saver for my small business, but today of all days has caused much stress with this problem.I clean out rollers...
Does it make the accordions just before the fuser, or as it draws the paper? If it's the latter, just make super-sure your paper tray is not bent in anyplace, or bits sharpened s.t. as a rubber roller picks things up, they're encouraged to crease. Just go over the emptied thing with a rag! Sometimes too a plastic guide will unguide when debris is pushing it the wrong way. Usually fiddling with roller tack or unbending trays gets you sorted....
Aug 11, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
Printer jams frequently. Jam is in the paper tray. It appears to try to pick up a sheet of paper and can't. When you open the paper tray the sheet of paper has been lifted up, but not enough to pull it...
Locate the paper lifter and the initial rollers and clean these with isopropil alcohol and a Q tip. These items become hard and polished and will not grip the paper properly, causing the jam.
Jan 20, 2011 | Brother MFC-9440CN Laser Printer
Printer jammed from top tray
How do you do. The Fault of your printer depends on his(its) period of the usages. It is Difficult to render aid, on stated by you reason. However, in jffen events this occurs the paper by reason of wear-out of the rubber roller of the presenting. In this case, I recommend you carefully to wipe the first rubber roller, which seizes the paper since kase or with hands, wipe the roller by facility for leaving for rubber or facility for cleaning of the polluted surfaces, plastic arts, glass so that rubber became springy. In the second, comes to wear-out platform for presenting the paper, which is under this first roller podachi. her(its) it is necessary to change or arouse to wipe. See, no in node of the presenting the paper stranger subject or breaches to wholeness of the brake platform.Before installing the paper in armor her(its) follows to crease that sheets did not cohere.The Photo paper better to insert on one sheet with hands and little her(its) hold...try , beside you are got. Good luck
Sep 28, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
When paper is feeding into the printer it takes to many pieces
If the printer is picking up multiple sheets of paper, follow the recommendations below:
  • Keep more than 10 sheets in the In tray.
  • Ensure media is not loaded too far and extending past the In tray.
  • Store all media in a dry, cool place. Humid climates will see this issue more often.
  • Do not print on media that has already been printed on. The dampness of the ink will cause pages to stick together.
If the printer continues to pick up multiple sheets of paper, follow the following troubleshooting steps below:
  1. Remove the media from the In tray.
  2. Fan the edges, re-square the media, and reload the media properly into the In tray.
  3. Slide the paper width guide to the right until it stops at the edge of the media, then push the paper length guide towards the paper until it stops.
  4. NOTE: Not all HP Deskjet printers have rear access doors. Skip this step if your printer does not have a rear-access door. Remove the rear-access door (if applicable) and clean the internal rubber rollers with a soft lintfree cloth moistened with distilled water. Wait until the rubber rollers dry and replace the rear access door.
  5. Verify that the correct media size and type is selected in the printer settings along with the appropriate quality.
  6. If this issue still persists, try a different type of paper.
Aug 26, 2009 | HP Deskjet D1455 InkJet Printer
Paper jamming in printer. Pulling one side before the other causing it to jam... Brand new, bought Sunday
Answer:
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
1.Turn off the printer.
2.Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
3.Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
4.Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
5.Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
•If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
•Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
•Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
•Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
•Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
Jun 24, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam error message but there is no jam
usual problem is a paper sensor (most likely a small lever) has gotten stuck.. find the paper sensors and reposition them
Jun 10, 2009 | HP J4680 Office Jet All-In-One Printer
Canon PIXMA MX870 Wireless Office All-in-One InkJet Printer Logo
201 people viewed this question
old marine
old marine
