Question about JVC Televison & Video
Sky new zealand say my hd z70rx5 is unable to recieve hdcp even though the specs say the set is HDMI AND HDCP complient,they say no rear projection is able to receive hd is this true,any help i would be very gratefull
  • 5 more comments
  • jdobson10 Aug 06, 2008
    I HAVE READ THE ARTICLE IT DOES REALLY NOT HELP THE QUESTION IS MY JVC HD Z70RX5 ABLE TO ACCEPT HDMI HDCP VIA SKY SET BOX IN NEW ZEALAND
    Hi have you seen the specs for this tv ,i seem to have bought a lemon
    Regards Mike
    Hi thanks for your help that is the only solid info i have been able to get,are there any projection tv thay can accept hd satelite tv ,there are a lot of people with projection tv,s
    that were bought and been assured by retailers that we would be fine for the next ten years as hdmi was the adopted method
  • jdobson10 Aug 08, 2008
    Hi can any rear projection tv access hd tv through a hdmi interface if it is hdcp complient and has a hdmi input,and is a digital tuner an issue,i have been told it is ,this makes no sense to me as hdmi is i designated input
    Hi again great to talk to someone who has a grasp offf thease issues which are scary to the average person,read your comments carefully ,what i can not get my head around ,is on the back of tv it has digital in admi hdcp input ,i can play my digital films straight from my harddrive to the tv 1080p and on the right hand topside of the picture it says HDMI1080P is this not reevant to my problem
    regards mike
    thank you very much again love my tv hope i dont have to change since i have only had it 3 years
    Hi manufacturer pace
    hardware TDS850NNZ.4.2
    S/V is 23.1.0.5.14
    operatig system version CO2P117
    EPG S/V u 1.0.16.1
    Hope that is usefull
    regards Mike
  • jdobson10 Aug 12, 2008
    Hi thanks for that info, talked to jvc service manager he was very helpfull compared to the sky tech who did not want to know and was not the least bit interested ,the tv works with all devices such as blue ray and shows them in brilliant hd.As far as the jvc company are concerned the tv is compleatly hd and problem is the way sky decoder is configured not being backward reverse able, not quite sure if that is the correct term.all i know is they are not going to change anything to help, if i had another choice of company i would go there, foxtel boxes work as i have seen them with my own eyes,getting very tired of trying to get anyone who gives a damm , As many customers tv sets are over 3 years old it looks like we are not going to get any where i will look carefully into your suggestions and see if they are a possibility
    Regards Mike thanks for your help
  • 3,037 Answers
It should be able to read the signal. I don't know why your sky provider would say such a thing. Did you talk to a salesman or a technician, make sure it is a technician next time.
Anyway the possible fix is to upgrade the firmware in an EEPROM. You can connect your PC to a service port on the back of the tv to the parallel printer port on the computer. The software requires direct access to the parallel port, for Win2K and XP you need to install a special driver that will allow direct access to the port. This is not required under Win98!
The other option is to get a new HDMI board on the tv which should fix the problem. Like you said, this is a lemon and it is the tv that is the problem and so you should contact the manufacturer of the tv not your sky provider.
good luck and let me know if you have any further questions
Posted on Aug 10, 2008
  • Benjamin Patri
    Benjamin Patri Aug 12, 2008
    no problem mike, hope you get it to work
  • 2,071 Answers
Terminals and Connections Dual HDMI digital inputs with HDCP (High Definition Content Protection) offer an uncompressed solution to the transmission and display of high definition video and audio content. All JVC HD-ILA TVs also include dual auto sensing component video inputs, assuring the best possible picture quality whether a viewer is using DTV, D-VHS or DVD, and three S-Video (two rear, one front) inputs and four AV inputs (three rear, one front).
Sky new zealand say my - hdmi.gif High Definition Multimedia Interface
HDMI is a new standard digital connection between A/V devices, such as a set-top box, DVD player or A/V receiver, and a digital television. HDMI offers exceptional video and audio quality with a single quick-disconnect connector. It supports multi-channel digital audio transmissions and component video color spacing for true rendering of HD video.
We carry a full line of high-performance HDMI cables. See them here...
Audio Features The JVC BBE High Definition audio system with Advanced HyperSurround and Active Hyper Bass includes two direct-drive speakers mounted underneath the screen for rich, expansive sound that fills your home theater or TV room.
Posted on Aug 09, 2008
    Brigadier General:
  • 3,614 Answers
I would like to what is the model of the cable box you are using...?
Let me know
Thanks
Posted on Aug 08, 2008
    Genius:
  • 1,665 Answers
Have a look at your SPECS
Make sure you have correct cable connections
See also Key Features of the JVC HD61FH96
  • 61" JVC HD-ILA Rear Projection Television
  • New 3-Chip D-ILA Rear Projection System, 1920 x 1080p resolution
  • D.I.S.T. 1080p (Digital Image Scaling Technology)
  • Flicker Free High Resolution Picture
  • Digital 4 Point Color Management
  • Widescreen Aspect Ratio
  • Natural Cinema (3-2 Pulldown) and Progressive Line Doubling
  • Panorama, Cinema, Full and Regular Aspect Modes
  • Video Noise Reduction
  • Digital Noise Clear Circuitry
  • 3D Y/C Comb Filter
  • Single Tuner PIP with Split, Index and Freeze
  • 20-Watt BBE High Definition Audio w/ Hyper Surround Sound
  • V-Chip Parental Control
  • Energy Star Compliant
  • Inputs:
    • 2 HDMI/HDCP Digital Inputs
    • 2 HD Component Video Inputs
    • 3 S-Video Inputs (1 Front, 3 Rear
    • 4 AV Inputs (1 Front, 3 Rear)
    • RF Input
    • CableCARD Compatible ATSC tuner
  • 1,183 Answers
Hate to say this, but you would not able to watch HDMI content using a setup box. The High definition in your TV means that you can connect the something like a HD- DVDplayer or XBOX, or Playstation on your TV and watch HD content.
This is the only downside to this beautiful peace of equipment,because it doesnot have a HD Tv tuner and has only a regular analog TV tuner.
What you cable company is saying is correct for most projection TV available in the market.
Thanks
Proton
Posted on Aug 06, 2008
  • Mandeep  Singh
    Mandeep Singh Aug 08, 2008
    Hi Mike,
    Here is some additional info to help you understand what i wrote earlier about the High definition tuner which is not built into the projection TV.
    What Consumers Considering the Purchase of a TV Set Should Know
    When buying television sets and other TV equipment such as DVD players, consumers should know whether or not the equipment includes a digital tuner. (TV equipment that includes a digital tuner is sometimes referred to as a "digital receiver.") Consumers who want to continue to receive their local full-power broadcast television stations after February 17, 2009 must either purchase a TV set equipped with a digital tuner or purchase a digital-to-analog converter box that will convert those over-the-air digital signals into analog so that they can be displayed on an analog device. Analog-only TVs should continue to work as before with cable and satellite TV services.
    Digital-to-Analog Converter Box Coupon Program
    Between January 1, 2008, and March 31, 2009, all U.S. households will be eligible to request up to two coupons, worth $40 each, to be used toward the purchase of digital-to-analog converter boxes. As described above, these converter boxes are designed to make over-the-air digital television signals viewable on analog-only TVs, and thus are not intended for analog-only TVs hooked up to cable or satellite service. The National Telecommunications and Information Administration (NTIA) is running the coupon program. For more information, visit the NTIA Web Site at www.dtv2009.gov .
    Some Sets Being Sold May Have Analog Tuners Only - Look for the Label
    Although, by law, the import or interstate shipment of any TV device containing an analog tuner is now prohibited, unless it also contains a digital tuner , some stores may still have in their inventory TV equipment with only analog tuners. A television set or other TV equipment with only an analog tuner will not receive over-the-air local full-power broadcast TV station programming after February 17, 2009, unless it is connected to a digital-to-analog converter box .
    The Commission has required that retailers fully inform consumers by prominently displaying the following text if they are selling TV equipment with only an analog tuner:
    This television receiver has only an analog broadcast tuner and will require a converter box after February 17, 2009, to receive over-the-air-broadcasts with an antenna because of the Nation's transition to digital broadcasting. Analog-only TVs should continue to work as before with cable and satellite TV services, gaming consoles, VCRs, DVD players, and similar products. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission's digital television website at: www.dtv2009.gov.
    Consumers are urged to look for this label when shopping for a new TV set or other TV equipment and to take into consideration the limitations of analog-only TVs when making purchasing decisions. For more information about the DTV transition, go to www.dtv.gov or contact the FCC's Consumer Center by e-mailing dtvinfo@fcc.gov; calling 1-888-CALL-FCC (1-888-225-5322) voice or 1-888-TELL-FCC (1-888-835-5322) TTY; faxing 1-866-418-0232; or writing to:
    Consumer & Governmental Affairs Bureau
    Consumer Inquiries and Complaints Division
    445 12th Street, SW
    Washington, DC 20554.
    The up side to your problem, is there a Digital to analog TV tuner conversion box that can be installed at your place , so that you can watch high def content on your projection TV, however the quality may not be at par with a High definition Tuner factory fitted on the projection TV
    Eg Sony Bravia V4500 is a TV that HD tuner builtin .
    Read the Faq below
    http://www.dtv.gov/consumercorner.html
    Best of luck mate ...I learnt interesting facts too while researching for your problem.
    Thanks
    Proton.
  • 659 Answers
Yes there are rear projection tvs with HD
here is a little article on the 4 types of rear projections with hd
http://www.cnet.com/4520-7874_1-5108443-3.html
    Scholar:
  • 133 Answers
My ps3 wont hook up trough hdmi
You may have a fault in the HDMI cable. Swap it out first.
Jun 14, 2014 | JVC HD-70G886 70" Rear Projection HDTV
Please, my projection t.v is not working with the SKY HD + BOX. so i dont want where the problem lies.
Try using the component cables instead of the HDMI cable because sometimes devices may not be HDCP which is why you get no picture.
Mar 13, 2011 | Toshiba 42H81 42" Rear Projection...
Upgraded Sky+ to Sky +HD, but I now have a messages saying this display does not support HDCP?
Yes your tv is hdcp compliant.
This may not help but often when this message comes up it is the hdmi cable you are using. I do not know whether or not you are using an hdmi to dvi cable or an adaptor or and hdmi to hdmi connection. The cables available for purchase at beachaudio.com are not expensive but they usually work when you need to try another hdmi cable because of this particular message.
Mar 03, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Through Sky+ HD when selecting the HDMI connection I get the following statement through Sky "This diplay does not support HDCP....." Any help please Rob
hi,
try to connect the set top box in any other HDMI input of ur tv. reason is bellow read it carefully.
p { margin-bottom: 0.21cm; } HDCP stands for High-Bandwidth Digital Content Protection and was developed by ----------. It's nothing more than a security feature requiring compatibility between the sender and receiver, like HD cable set-top box and the TV. By compatibility, mean HDCP technology built into both devices.
Think of HDCP as a security license key like you would input when installing a computer program. Only this security key is invisible to you and me but not your TV.
It works by encrypting a digital signal with a key that requires authentication from the transmitting and receiving product. If authentication fails then the signal fails, which means no picture on the TV screen.
Buy a HDTV that has HDCP capabilities. Most will have this in at least one HDMI input but be sure to verify this before buying the TV.
Notice that "in at least one port." Not every HDMI port on the TV will be HDCP compliant so be sure to read your TV user manual if you plan on connecting a HDMI cable to your TV.
ok
Jan 13, 2011 | Toshiba 32WL56 32 in. HDTV-Ready LCD...
Hdcp error mesage when connected to my freeview hd box.
What is a HDCP error? Here is a real life situation that happened that could happen to you. You just bought a Blu-ray Disc Player and connected it to your older HDTV with a HDMI cable. When you tried playing a Blu-ray disc a HDCP error was shown on the screen. The movie wouldn't play.
This is a known issue with HDCP, and it's one of the biggest hassles consumers will have to deal with when utilizing a HDMI cable on their HDTV. You will get a HDCP error if you try watching HDCP encoded content when using a HDMI cable.
The problem is that if HDCP exists anywhere in the video stream then all devices and cables accessing this content must be HDCP compliant. If one device or cable isn't HDCP compliant then you get a HDCP error.
The only solution is to either replace the HDMI cable with a non-digital cable or replace the HDCP-less device. This could mean buying a new HDTV. In fact, I worked with a reader last year troubleshooting a HDCP error on his TV. What happened is that he bought a Blu-ray Disc Player and connected everything properly only to get a HDCP error. After a few emails back and forth we discovered that his HDTV wasn't HDCP compatible, which is why he got the HDCP error.
The reader ended up buying a newer HDTV with HDCP, and his Blu-ray Disc Player worked perfectly with HDMI cables.
Nov 22, 2010 | Televison & Video
I cannot view HD channels (from freeview HD box) through my Sony str-dh810. I've narrowed the problem down to something called HDCP. When HDCP is on, I cannot view anything from my freeview box. Turning...
This piece of information should solve your problem:
High-bandwidth Digital Content Protection (HDCP) is a form of Digital Rights Management (DRM).
There is a licensing body that issues licenses for HDCP devices. Each HDCP-compliant device, like your Blu-ray player or Xbox, has a license and the ability to talk to the receiving device on the other end of the HDMI cable. The outputting device says "Hey display! Are you HDCP compliant? Here is my license, show me your license!" The display (or other HDCP compliant device) returns with "Why yes, I am legit! Here is my license!" When that process works, it happens within a thousandth of a second and you, the consumer, never even notice. You power on your Blu-ray player or DVR, it makes nice with your HDTV, and you live a happy life never knowing what HDCP even is.
if you have an older HDTV set that is not HDCP compliant then you cannot watch any HDCP compliant content on it. If you plug in your HDCP-compliant device to a non-compliant device, you'll either see a blank screen or an error message like "ERROR: NON-HDCP OUTPUT," "HDCP unauthorised," or simply "HDCP ERROR."
Short of buying a new television or giving up on your video game project the only way to deal with your HDCP compliance problem is to buy a cheap HDMI splitter that ignores HDCP requests.
Sep 25, 2017 | Sony STRDH810
Is there HDCP chip in Sony KF-E42A10?
HD programing 1080i,if tv it can get that mode.No part change in tv to get HD it can or not, that it.
Jan 13, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blu-ray player won't play through hdmi with yamaha reciever
The problem is some intermediate connections do not allow the HDCP signal to reach the telivison. Electronic HDMI switches have this issue. I have one HDMI port on my Telivision and I have a Blu-ray player & HD satellite reciever. I had purchased a two in one electronic switch and found that the satellite reciever signal would make it to the tv and was working but the blu-ray player was not. I had to by a passive push button switch and it allows the HDCP signal thru. The funny thing is the electronic switch was supposed to be HDCP compliant and it still did not work.
Sep 06, 2009 | Yamaha Audio Players & Recorders
On my PT-50DL54 the HDMI HDCP stopped working
Try unplugging the television for 10 or 15 minutes and try again.
Apr 30, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Unable to use Sky HD Due to an HDCP
Try calling samsung they might have a firmware update they can send you
Dec 06, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Televison & Video Logo
323 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
