Question about Cabela's Grilling
I have a stainless steel smoker grill and I need to buy a replacement water pan for it, Where can I find one? It is 15 Inches across and 3 inches deep
    Genius:
  • 1,739 Answers
Recommend you first try contacting Cabela's to see if this is available as a replacement part. You will likely need the model name or number of your smoker grill:
Contact by e-mail using their webform:
https://cabelas.custhelp.com/cgi-bin/cabelas.cfg/php/enduser/ask.php
Telephone Numbers:
http://www.cabelas.com/custserv/custserv.jsp?pageName=CallUs
Posted on Apr 06, 2011
How do I change the burners on a Nexgrill Model 720-0108? Thanks for any info for less than handy woman!
That same model number has several different burners. One is a straight burner (three each); a couple are loop types and several have a flat surface with gas outlets.
Part Number
Description
Shopping
Cart
10361
Stainless Steel
Tube Burner
10361.jpgThis stainless steel tube burner is a replacement burner for numerous gas grills produced by Nexgrill, some of which are sold under the Charmglow brand name. This burner is 16 & 13/16 inches long. Please use our Nexgrill drop down model list, together with the illustration and sizes, to select the correct burner for your grill. Most of these grills use three to five burners. If you wish to benefit from quantity pricing on the 10361 burner, see the order entries below for three-pak and five-pak quantities.
This is the easy one - Just pick up the flutted end and slide out from the gas line. No screws or bolts
$12.79 each
Quantity:
Jun 05, 2011 | Grilling
How high is the cabinet under the grill with a 1
The finish height should be 36" from the ground. So you need 34and 1/2 inches then you need to put 3/4" concrete. Then the granite that should be 3/4". You can fudge a little with in 3/8 inch if you need.
Apr 30, 2010 | Fire Magic Aurora A540i-2E1N Stainless...
I have an older Genesis grill with a leaking regulator
You can get a replacement regulator at just about any home improvement store (Home Depot, Lowe's, etc.) There haven't been changes in the size of the ports or thread patterns on regulators or propane tanks in the last 15 years.
Oct 07, 2009 | Thermos Stainless Steel Gas Grill
New grille for a Meco Swinger II Smoker Grill charcoal barbecue
Try http://www.shop.allinone.co.uk/eCommerce/product.aspx?cat=193&prod=6229
Jonathan
Jun 14, 2009 | Meco 4400 Swinger II
Parts for New Braunfels Black Diamond Smoker
i need replacement grilling grates for my black diamond smoker can someone help?
Apr 09, 2009 | New Braunfels Black Diamond Smoker...
BRINKMANN MODEL 810 7080 k
Hope you found your water pan. If not, I'm sure Brinkman can supply one or you might try checking at Sam's Club in the restaurant supply area (over by the food - not the fancy cookware section) for a mixing bowl that has the same diameter as the inside of your smoker. I saw some there today and while I'm not sure they had any large enough, they had some that were pretty large. Alternatively, put your second grill on the brackets for the water pan (if you didn't end up with a second grill, try Academy for an inexpensive replacement grill) then sit a large foil roasting pan with a couple of inches of water in it on the grill. Voila! Instant water pan!
Pat
Aug 05, 2008 | Brinkmann Smoke' n Grill Electric Double...
Brinkmann upright smoker not hot enough!
I have a very similar smoker to this and this is what I have to solve the problem.
First drill some holes in the fire pan. This gives more air to the charcoal to get a hotter burn. I went with about 6 or so holes around the sides of the pan with a 1/2" bit. You could also get a grill basket from Home Depot. It is a square pan with holes throughout and made out of stainless steel. I bought one, but switched back because you can't hold as much charcoal/wood.
Second, get some play sand and fill the water pan with it. You will need to cover it with some heavy duty foil to keep drippings off it. Also, add some water to it once in a while to keep it moist. This should not only help in raising the temps, but give you a more consistent temperature as well.
Third, invest in a good grill/smoker thermometer to make sure the one on the front isn't wrong. My smoker is the hottest in the back (not sure why) and the thermometers on these brinkman's probably aren't the most accurate.
Jul 14, 2008 | Grilling
Brinkman electric smoker
The pan for the wood chips is a round shallow (1/2 or so high) pan, about 8 inches in diameter, that sits right on top of the heating element. The element doesn't get too terribly hot, so you could probably substitute a foil pie plate or even a double wrapped package of aluminum foil with some holes punched in the top. When you see the smoke - its time for the meat!
Good eats!
Pat
Jun 29, 2008 | Brinkmann Smoke' n Grill Electric Double...
Pulse ignition wiring
could it be a ground wire come lose?
Mar 29, 2008 | Char-Broil Commercial Stainless Steel...
Grilling Logo
104 people viewed this question
Top Cabela's Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Cabela's Grilling Expert? Answer questions, earn points and help others
