Question about LG GH22NS50 22X DVDRW SATA Drive OEM DVD-RAM Burner
When i use writer of writing dvd my writer got me follwing msg. The target device might have some problem.Please try again or reboot. (5213)
  • LG Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 06, 2011
How DO i Fix DVD Writer Works As CD ROM Only. Not Detecting any DVD.
There are 2 assemblies inside it.
One works to read/write CD media.
One works to read/write DVD media.
So, your device is "half-broken".
Replace it.
Apr 02, 2015 | Computers & Internet
I have a problem with my LG Super Multi DVD Rewriter GH22. When I try to burn a disc, the writing process will start (mostly), but at some point the drive will get stuck so that the writing process never...
The issue seems not related to the LG Burners, possible the disc in which you are trying to burn may be issue.
Can you try with the different brand disk.
Oct 12, 2010 | LG Computers & Internet
Hi my DVD writer only read and write cd only but when I insert DVD nothing hapeens.System shows DVD-RW. Plz give me solution Dijay
Without further Detailed information it's impossible to tell whats going on but I doubt it's a motherboard problem.
I offer this as just a guess to your problem - I have to ask is it a DVD mismatch? For instance are you using DVD-R and should be using DVD+R with your DVD writer. - it used to make a difference?
also what you could try is deleting your Optical devices from windows device manager and rebooting and rediscovering them.
Aug 24, 2010 | Computers & Internet
Unable to write on DVD-R using DVD/CD-ROM
Yes, if you have a DVD writer installed, you should be able to write to DVDs. What happens when you try? If you look at the DVD writer in the Device Manager, does it have any sort of error or warning? Do you have the correct driver installed for the DVD writer?
May 29, 2010 | Computers & Internet
My lite-on DVD writer is not reading any dvd's as well not writing any DVD's while it is good for CD's..... What is the problem?? How can i correct my DVD writer
Hi Please try and use a different brand of DVD discs. DVD disc quality is sometimes an issue with lite-on drives Also check that you have updated drivers and your media burning software is installed correctly. Again if your using NERO this can be a problem. Try using any other burning software One other thing to try when recording DVDs set the recording speed to lowest Many Thanks Andy
Apr 27, 2009 | Computers & Internet
DVD Writers can read but can not write
update their drivers: they're indicating readers, not writer devices..
Mar 25, 2017 | LG GMA-4082N DVD±RW Burner
Regarding the Dvd Writer Problem--Urgent
Ok.I got your point.Now I want you to try this first
1.Go up to device Manager
2.Under CDROM/DVD remove your DVD(Uninstall it)
3.Restart your Windows
4.after login your windows,wait for a minute,Windows should be able to detect your DVD back
5.Check your DVD in Device Manager again that its been detected back
6.Now try your DVD again.
Goodluck...takecare
Apr 19, 2008 | Acer Aspire 5500 5570-2609 Laptop
DVD WRITER NOT WORKING
It sounds like you don't have the proper driver installed for that device. Without the appropriate driver your software will not be able communicate with the device properly.
Nov 25, 2007 | LG GSA-H22N DVD±RW Dual Layer Burner
Blank DVD Causes PC Reboot
if the pc reboots, then a driver or hardware fault is the cause, try uninstaling the dvd drive in device manager, then restart pc to install it again, or if you are able connect the dvd drive to another ide cable connector incase its a fault from the motherboards ide channel.
Aug 09, 2007 | Samsung SH-S182D DVD RW Dual Layer Burner
I am having a LG DVD writer GSA-4167B currently stops reading or writing disks after few runs
as with all writers eventually they fault at the lens and it gets out of line and cannot read discs, you can try the usual thing of checking LG for any firmware updates, but first:- Go to my computer>right click>hardware tab>device manager, then down list to cd/dvd drives and click '+' sign and highlight your writer, right click on it and select uninstall. Restart PC and it will be automatically re installed, try again and if no change you will need to replace the drive as they are cheaper nowadays.
Jun 19, 2007 | LG (GSA-4167B) DVD RW Dual Layer Burner
LG GH22NS50 22X DVDRW SATA Drive OEM DVD-RAM Burner Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
