Question about Cycling
I have put radio code 7 times wrongly, now I got right code but I can not put in the code, because it say 7 error. Please could you help me.
  • 456 Answers
Hi.
some radios will lock out permanently after a certain number of incorrect codes.
most will have a time lock on them so after so many incorrect tries, you have to wait a certin time before you can input any more codes. this can be anywhere from 30 mins up to 24 hours depending on the radio.
wait for a few hours before trying any more codes.
if you can give the make and model of the radio, i may be able to find out more information on the lockout
Posted on Apr 06, 2011
Hi i have put the wrong code in radio for renault megane and it is coming up with error and I have took the battery of left it over night but still say error
For Renault radio codes and instructions on how to enter it, contact this link: https://www.gumtree.com/p/in-car-audio-gps/car-radio-codes./1210678039
Jan 16, 2017 | Renault Megane Cars & Trucks
Battery was diconneted when tried to put code it come up 7 SFFE its a 520 blaupunkt radio cd
you would be surprised how many error code you can find by putting the word error code followed by the actual code into google
Dec 16, 2014 | Blaupunkt Car Audio & Video
Put wrong code in radio now cant clear the error display
try hold number 2 & 5 while radio off while holding switch radio on this should go to factory settings
Aug 31, 2014 | 2003 Renault Megane
Put wrong code in renault car radio now got error message . How do i clear this message to put correct code in ?
If you take the earth lead off the car battery and leave for about 2 0minits then reconect the battery it should reset the radio so that you
can put in the right code.I hope this was helpful and done the trick.
Nov 19, 2012 | 2004 Renault Megane 1.6
Please i need help with 2001 montero sports radio
if you put in wrong code 3 times the radio will shut down for a few hours will not let you do anything try again the next day
Mar 31, 2010 | 2001 Mitsubishi Montero
Hi I have a blaupunkt cassette/radio in my car. I
ERROR 3 usually means that you have entered at least 7 wrong codes ...so make sure you have the correct code
To reset from ERROR3 leave it SWITCHED ON....UNDISTURBED until it automatically resets itself.
This can take several hours as the waiting time doubles after each wrong code
If you require help with the correct code then read below
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here  for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST A BRAND NEW  QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
Also quote the MAKE of CAR
note: Unfortunately not all radios can be decoded using the Serial Number
Otherwise try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Nov 30, 2009 | Blaupunkt Car Audio & Video
2001 mitsubsi eclipse enter car radio wrong code 3 times
Put the key in the ignition and set it to "accessory" setting and leave it there for about 45 minutes.
After that remove the key and put it back in and you should be able to enter the code again.
May 04, 2009 | 2001 Mitsubishi Eclipse
Cycling Logo
46 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
