Question about Toshiba TDP-S8 Multimedia Projector
Lamp life how do I know if my lamp life is running out?
  • 446 Answers
It usually runs on luminance hour by the thousand, by indicator the light becomes dim a bit and gradually loosing the brightness, to the extend it will no longer lit.
usually 5 thousand hour
Posted on Aug 06, 2008
SOURCE:
Tv on my samsung p4663w/hl does not turn on. lamp light flashes on front of tv picture does not work. no sound , bulb has no marks on it to show that it is bad
Tv projection lamp have a life span like any other bulbs light sources.Tipically life spans of these tvs projection lamps are around 20,000 hrs of useages.That average out like about 1 1/2 or 2 years and around 4 or 5 hours of the tv is on and watching it everyday.Now the front tv bazel frame of the tv.The word "LAMP" LED light indication is on or flashing are indication of the tv projection lamp life span are over and the tv must have it projection lamp to be replacement to another tv projection lamp.Projection Lamp fillerments tipically dies out when it reaches it life span.Mark or burns on the projection Lamp,will not show or be there,if the tv projection lamp run it natural life span cycles.
Aug 03, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Lamp life
This lamp life is about right if the TV is getting constant use. Please check that the cooling fan is running at the correct speed and the vents are unobstructed.
Oct 06, 2007 | Mitsubishi WD-52725 52". Rear Projection...
The projector came on for about 10 minutes and then shut off
Welcome to FixYa.
The projector could be overheating or the lamp has reached its end of life.
Solution:
1. Clean or replace the air filter. 2. Check the lamp run time. If the lamp time has reached its end of life, replace the lamp.
Use the manual to do the above steps. Keep me posted.
Jas247
Aug 03, 2011 | Radio Shack Cinego D-1000 Multimedia...
I have had my television for 3 years and apparently the bulb is supposed to last 5 years but every year we have had to replace the bulb, So tell me where the problem would be, what a great...
I have a very good suggestion for you. If the set is working go into the customer menu and look for something called "quick start".
If this set has this feature it is default---means unless you change it that will be the way it is. It was a stupid idea----what happens is if it is there and engaged when you shut the set off the lamp will dim down about 60% but it and the fan will be one 7/24 which tends to shorten the lamp life.
Average lamp life should be at least 2,000 hours.
If you have the set off and turn it on and instantly get a picture, it is engaged----the "idea" was the customer would not have to wait for the set to slowly bring the lamp up to full brightness (about 15-20 seconds from start to finish).
If you turn the set on and get a normal bright picture in under 7 seconds your set has this feature.
The way this works if it is not engaged is when you shut the set off the lamp will turn off completely and the lamp fan will run for a few minutes until the temperature of the lamp drops below a specific level.
Not to mention vastly shortening the life of the lamp, it also is eating power 7/24.
Please let me know what you find and if you have any questions let me know by posting a "comment" here.
Regards, SD TECH
Aug 05, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
How to check the backlight life of my hp l1706
Claimed life for the lamp is 50,000 Hours, but in real life, no way to tell. You can look here what is failed in the backlight lamps, it can be from worn out (blacken ends is one sign of bad lamps, same as home fluorescent lamp), poor soldering works on the lamps. see pictures here: http://s807.photobucket.com/home/budm/allalbums
What is the problem with your monitor anyway?
Mar 30, 2010 | HP L1706 17" LCD Monitor
What is the lamp life on a sanyo plv-z2 bulb and how to read the bulb life there are 3 numbers that come up when i check it
If I remember correctly, you hold down either the power or the menu button for 30 seconds... I believe it is the power button, and it will briefly display it on the screen, but this assumes it was reset at the time the lamp was installed. The counter counts up on this model, and the lamp replace light will come on at 3000 hours. I have 2 of these units, and I have gotten at least 5000 hours out of each lamp. Toward the end of the lamp life, it may start getting dim and/or have difficulty starting, but I probably wouldn't replace it until you either notice the dimming or the lamp fails, although I've heard some say they can damage the projector when they fail, I have not had any problems.
Dec 03, 2009 | Sanyo PLV-Z2 Multimedia Projector
Need to know what size bulb goes in dome light
For 1991 TOYOTA Pickup replacement bulbs, review the list and check it in other brand with this model:
High & low beam headlamp
H6054
H6054ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H6054XV XtraVision Halogen - The Brighter Light
H6054CB Cool Blue Halogen - The Whiter Light
H6054LL Long Life Halogen Upgrade: Lasts 6x longer
Parking light
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
1156
1156ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear turn signal
1156
Tail light
1157
1157LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
1157
License plate
194
89
Back up light
1156
Front sidemarker
194
Glove box
161
161LL Long Life Upgrade: Up to twice the life of the standard lamp
Step/Courtesy light
DE3022
DE3175
DE3175LL Long Life Upgrade: Up to twice the life of the standard lamp
7443LL Long Life Upgrade: Up to twice the life of the standard lamp
Hope helped with this (remember rated this help). Good luck.
Nov 11, 2009 | 1991 Toyota Pickup
Panasonic PT-AE900u no image
may i know now what is the age of your projector. have you done replacing the lamp of the unit before.
Lamp life varies by manufacturer and projector type. Lamp life also depends on the projector's environment: air flow, clean air, and also on the level of usage. Check the user's manual or specification pages for your projector to determine the exact lamp life.
Nov 04, 2008 | Panasonic PT-AE900U Multimedia Projector
Sony full definition lcd model 1080
Yes you have a bad lamp. Unfortunately, I have noted that many dealers either "forget" to tell the customer that the lamp will require replacement, or they overstate the expected life of the lamp. The usual life of a lamp, as stated by Sony is 4000 to 8000 hours. There are 3 factors that effect lamp life:
1) the number of times the TV is turned on and off. Every turn on works the lamp very hard, so to make the lamp last longer, limit the number of turn on/turn off cycles. My rule of thumb is this: If you will be back to the TV within 30 minutes, leave it on.
2) Proper ventilation. In general the TV should have at least 6 inches of space on all sides to properly cool.
3) Power loss. If you have frequent power outages, buy a small UPS for the TV. The TV requires a "cool-down" cycle where the fans run to properly cool the set. If the cooling cycle is interrupted, it can effect lamp life.
Replace the lamp with and original Sony lamp and vacuum any openings you can see that are dusty and you should be good to go. Be sure to rate this solution. Thanks!
Oct 30, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Toshiba TDP-S8 Multimedia Projector Logo
66 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
