Question about Sport & Outdoor - Others
Two problems with Humminbird 788cxi combo marine GPS/sounder- even though I take the auto depth sensor off and set the sonar depth manually, the sounder loses contact with the bottom and reads .7mtrs when I know I am in waters of 12 mtrs, or 35mtrs, it does not make a difference what depth of water I am in. The transducer is a professionally mounted through hull which was bought and installed with new boat by the dealer. When turning sounder on, it prompts to install latest version firmware upgrade from sd card, but I have already granted permission and followed prompts several times already. Each new boot up it prompts again. Should I wipe all info on SD card after backing up to PC and start again? Thanks in advance Brian
4 Suggested Answers
SOURCE: A65 Transducer
jmiller,
Sound like your getting turbulence from the hull or your angle is allowing cavitation under the transducer. Look under the hull where the traducer is mounted and look for a part that has no obstruction including saltwater pickups, hull relieves, etc. The other thing to check is to take a strait edge on the bottom of the transducer to ensure the angle is slightly forward than the hull.
Bob
Posted on Dec 27, 2008
  • 5 Answers
SOURCE: I have a GPS Map 498-depth sounder not working? Ha...
If the transducer is out of the water, you will not get a reading and see the flashing depth. You should hear and feel the clicking in the transducer when out of the water and working properly. Are you getting a temp reading when out of the water?
Posted on Jul 31, 2010
  • 29 Answers
SOURCE: Hi. Just wondering how should
You can take a picture of the transom of your boat and email it to Humminbird and they will email it back to you where the transducer should be mounted at. Our email address is service@humminbird.com.
Joby @ Humminbird
Posted on Dec 27, 2010
Will power up, but won't advance to menu
May require a software update.
register your unit at OnixSeries (this is a link to humminbird)
On your "My humminbird" page you will find free software updates for your particular unit.
download the latest update to an SD card and follow the instructions for the installation process.
Apr 20, 2015 | Humminbird 581I Hd Di Sonar/Gps Combo
Works on down scan but not on sonar
Hummingbird systems have the ability to turn off pages so they will not be displayed. On your main menu look for the "views" tab. Scroll down to the sonar view page and see if it shows visible or hidden by that page. If it says hidden, select visible and you should be all set.
Oct 01, 2014 | Humminbird 1158c Di Fishfinder With...
Why does my fish finder sieze up when i start my boat?
it seizes up because their is a very hi draw on your battery when the motor is turning over, the starter draws so much power from the battery that it drops the voltage down below what the depth finder needs
Aug 11, 2014 | Humminbird 597 Ci Hd Combo Sonar/Gps
When i power it on the screen just shows loading and never boots up
I don't have the same model but the same issue before the cable from the sonar was frade some and so it wasn't sending a good signal to the box so it just said loading I had to replace the sonar and then it worked fine
Sep 23, 2013 | Humminbird 161 Gps Fish Finder Combo
My Humminbird 788 ci screen clutters up and gives crazy depth readings when the trolling motor (mk terrpva80# w/ ipilot and built in td w/mkr-us2-8 cable) is set on mid to high speed settings. It does...
One thing you might try is restoring the defaults in your unit. One other thing is go into the menu under the sonar tab and adjust your Noise Filter. You may have some type of interference going on. You can call our customer service department and they will trouble shoot it for you. Our number is 800-633-1468.
Joby from Humminbird.
Jan 01, 2011 | Humminbird 787c2 Combo GPS Receiver
Furuno 4100 depth sounder shows depth twice what it really is
check your gain setting try auto gain and try manually gaining back to see if it resolves, if yes, send unit in to furuno, if no, ducer is probably at fault.
Aug 01, 2009 | Furuno Ls4100 5" Mono Lcd Fishfinder Temp...
Can I hook up a depth sounder/ /fishfinder transponder to a 755c humminbird gps unit
Hi!
The 755 is only a chartplotter, meaning it is a gps only unit.
Best of luck.
Mike
Jul 08, 2009 | Humminbird 755c GPS Receiver
In water less than 5', my Humminbird 565 reads that it is .6''of water
Hi!
If the sounder works in deeper water then try changing the unit to fresh water instead of salt water (or vise-versa). You'll need to switch to advanced settings first (in the setup menu tab), then switch to the afformentioned salt or fresh water (in the sonar menu tab).
Alternatively, switch back to factory defaults as these settings are made to work "right out of the box".
Best of luck!
Mike
Apr 26, 2009 | Humminbird Fishfinder 565 With Transom...
Hummingbird gps ns25
Hi!
here's a user manual/installation manual for your sounder:
NS25
If the depth sounder portion works, I would suspect the settings are off (check first) or the gps circuit needs repair.
Best of luck!
Mike
Sep 02, 2008 | Hummingbird Humminbird 1155C GPS Receiver
Sport & Outdoor - Others Logo
65 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
