Question about Refrigerators
SMELL COMING FROM LARDER FRIDGE,FOUND THE PROBLEM AT BACK WHITE TRAY ON TOP OF MOTOR A BUILD UP OF SLIME , FINDING A PROBLEM TO CLEAN TRAY,
  • 17,130 Answers
This is the defrost water that collects on the collection tray - white tray on top of motor. Normally over a period of time the water evaporates off but if there is collection of dirt it can smell. So you need to PULL out the tray - use a screw driver to release the lock and the tray will come out which can be cleaned using a water jet and detergent.
Posted on Apr 06, 2011
Why is my thread turning black from oil?
Thread? Typo?
* If it's real oil and not slime (yeast) then the motor will stop working and the fridge will be warm. Motor possibly hums and trips out breaker or has a burn smell. Call for service.
* Oil comes from the refrigerant line which is in a sealed system.
* Hopefully if your refrigerator is running okay and you still hear the motor quietly running with no straining sounds then it's likely someone spilt something oily (Italian dressing?) in the fridge and it got into the drainage system (which drains to the defrost pan at the bottom.)
* It's a good idea to check and clean the defrost drip tray and clear the dust from the coils (if it's on the bottom. Some coils are located in the back.)
* If it turns out to be slime (yeast) then check with your MFR for a recommended defrost line cleanser or flusher. It's to clean and sanitize the line to prevent yeast and mold build up. You may find home remedies on line that may help. (about 5-8 drops of bleach with a cup of water works.)
* You will find that frequent (every 3 months of less) clean out and wipe down of the inside of the refrigerator will take care of this problem.
* Final, Check your warranty and call for service. Ask for annual service if available. (they check everything.)
Aloha, ukeboy57
Feb 21, 2018 | Refrigerators
How can i stop my larder fridge from producing lots of ice?
If your fridge is built into the furniture, pull it out by releasing all the retaining screw, clean the condenser and the areas behind your fridge. Dust and fluffs reduce the efficiency of the fridge. Also turn the dial to three, if it is higher, older fridge do not need to be cranked to higher numbers. If no joy call an engineer, the level of refrigerant in your system may need topping up. Will cost you anything from sixty pounds for a qualified engineer to do this.
Aug 15, 2014 | Refrigerators
ARL100/B-K/1 Larder fridge collects water at the bottom under the two detachable trays. Could you please tell me what is .
Your auto defrost drain line is clogged.You will need to locate it and clean it out. Try to trace the water back to where it is coming from. Also you may try pulling the refrig out from the wall to check.Hope you found this helpful and thanks for using Fix ya
Jun 23, 2011 | Whirlpool Refrigerators
How do I remove the plastic drip tray from behind my Wesitnghouse Aurora Fridge Freezer.
we had a really bad smell coming from the back of our westinghouse aurora. and yes found it to be emanating from drip tray at the back. To remove this we had to undo 4 clips at the base of black motor thingy, that the plastic drip box sits on. Then we were able to lift whole thing a bit ,(10mm up and 50mm out, approx) so we could tilt everything forward and sweeze and wiggle tray out. then cleaned with bleach. also we unblocked hole inside fridge that allows water to drip into drip tray at back.
Jun 01, 2011 | Westinghouse Refrigerators
Bad smell from motor
You need to remove any spoiled food from the refrigerator and clean the interiors with hot water added with baking soda. You need to clean the door seals and remove the breaker strips. Also check for unusual wet insulation.
Hope this work
Jul 28, 2010 | Amana ABB1927DE Bottom Freezer...
Fridge smell
It sounds as if you may have had a spillage at some stage in the fridge unit and this has gone onto the tray at the rear of the unit at the bottom on top of the motor.There may be some other explanation when you do pull out the fridge to access this tray.It may be easier to clean the tray in position as they can gat damaged if you try to remove them.If so get some soapy water and a sponge then clean out and dry,also some spray dissinfectant in the tray after cleaning will help.
May 03, 2010 | Zanussi ZEBF277W Bottom Freezer...
We have a Meile fridge freezer and the smell seems to be coming from the back (no smell inside)It has been a constant smell but occasionaly gets worse. It has taken us a week to find out that its coming...
Self de-frosting tray at the back of the fridge was full of old stagnent water. Removed tray cleaned out, flushed out the pipe from the inside of the fridge to the drip tray. No more smell.
Nov 02, 2009 | Refrigerators
Nasty smell in garage.....think its coming from refrigerator
It's either the drip tray which is removeable from the front, or, mice are playing in the drip tray under the compressor. Soak in up, rinse with some ammonia water & repeat a few times. Rinse well when done. Line up some sticky traps behind the fridge. The mice found a playground amd they will return.
Mar 07, 2009 | Frigidaire FRT15B3A Top Freezer...
I have a larder fridge that seems to collect too much water in the tray at the back, it seems to be temperamental with cooling. It only works part time. How affected are they by not being completely level?...
this water should be evaporated by the motor heat.however, i have found with larger larder fridges of several makes that too much water is formed for it all to go.
worth while checking the door seals as well as if seal is leaking, more ice forms on the evaporator and hence more water
Aug 31, 2008 | Frigidaire Refrigerators
Fan blows out a smell from underneath fridge could it be leaking gas.
call the repairman back and say forget it ,on the motor youll see a flat pan ,like a cookie sheet on top ,the excess water from the freezer drains into a tube and into that pan as the motor gets hot it evaporates the water,just clean the pan,shut down fridge,unplug and let motor cool,clean the pan and tell hubby not to waste good beer lol
Apr 30, 2008 | Frigidaire FRT18B4A Top Freezer...
Refrigerators Logo
191 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
