Question about Whirlpool Refrigerators
No lights in refrigator compartment bulb is good light is on in frezzer
  • 5,370 Answers
The bulb, if checked good, then other possibility for bulb not getting ON is faulty light switch or the short in wirings from bulb connector to light switch.In most of the cases its faulty light switch.It has to be checked and replaced.----------This should help.Thanks.Helpmech.
Posted on Apr 06, 2011
Replace bulb in refrig compartment of model TFX25JRYF_WW
Hello Brenda;
My name is Peter. I am a retired field service refrigeration technician.
First, This is a special bulb. You can obtain the bulb in your local supermarket. They are a little more expensive than household bulbs.
To remove your light bulb shield, pull down on the bottom of the shield, pull towards you and lift up.
Dec 02, 2014 | GE Refrigerators
Lights in refrigerator compartment flickering
You have a bad electronic control board . This part is mounted on the back of the refrig , at the lower left corner , inside a plastic holder . The part number is W10135090 . It costs about $ 100.00 . This board , also controls the 2 control knob lighting .
Apr 21, 2010 | Refrigerators
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
The refrigerator temp lights are flashing on and off and its making a clicking noise..ge profile refrig with freezer on bottom. I unplugged for 5 minutes and replugged with no help
your main-board/motherboard is bad,a telltale sign is,if just recently had light bulbs burn out in the refrige compartment and now they strobe dimly and the digital temp readout is also out and you sometimes hear relays clicking back there, the board took a voltage surge and ruined the circuit trace,replacement is simple,unplug 3 harnesses and snap in new board and plug in new board and youre good to go
Feb 22, 2010 | Refrigerators
My side by side Model GSH22KGRE BB freezer is
there is one of 2 possibilities,either the damper door between the refrige and freezer compartments is frozen shut due to ice build up and needs thaw out,the cold control that controls this door is bad or the mother board on the lower rear apron behind a cover panel is defective,if you have had light bulbs go out in the refrige compartment and now the refrige part does not cool and the temp light readout is dark this is a good indication its the motherboard,also if the lights are strobing and you can hear a relay clicking
Jan 17, 2010 | Refrigerators
I have a GSS25KGMD fridge. I opened the Fridge compartment top part was very warm and the bottom was cooler. Upon investigating more I noticed that the fridge bulb was very hot. So I pushed the fridge...
Your refrig light switch does control the freezer fan and the refrig light bulb . Replace the refrig light switch .
Open the refrig door , freezer fan goes off and the refrig light comes on .
Nov 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
How do you turn off freezer,refrig. is a side by side with a lower freezer that pulls out. Recently moved and freezer door broke and need to use just the refrig.
I don't believe you can turn off the frezzer section because most if not all frezzer/fridge units use the frezzer section to cool the fridge side!!!! that's just how they are designed.
Sep 21, 2009 | Refrigerators
I have a Jenn Air refrig JCD 2389GES....the frezzer is working fine, the the fridg is warm.....what should I do? I took the ice maker out and cleaned the slots behind it....the fridg side is still not...
Check the circulation fan in the freezer compartment that circulates the cold to the fresh food compartment. If its not running, and no ice is on it to bind uo the blades, replace the motor.
Aug 04, 2009 | Jenn-Air JCD2389G Side by Side...
Ice/water dispenser not working but ice is being made
lighs in the refrig or frezzer not working either???id check your outlet and or circuit braker. at very least yout lights should be on!
Feb 24, 2008 | GE Profile PSS26NGS Side by Side...
Refrigerators Logo
101 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
