Question about Samsung Office Equipment & Supplies
Have a Samsung Inkjet FAX SF-370. Changed ink cartridge with a refill one, couldn't read the document that I copied. I thought it was the refill cartridge so I bought a brand new one. Same Problem - when I copy a document I am unable to read it. Tried cleaning the head. What else can I do? or is my machine of just over 1year old broken forever?
  • 132 Answers
First off when you replace the cartridge you have to press cartridge button and replace the cartridge and then press 1 for new cartridge then let the machine print out a alignement page press the correct button and then press start button if you have done it try the following
unplug the machine hold down the clear/stop button while you plug the machine in when you see your country name in the display press start button that will revert the machine back to factory defaults that should do the trick if not the head could be faulty
Posted on Apr 06, 2011
How to cahange ink, samsung powerful 3-in-1 inkjet fax sf-350
there is a button on the front pannel. change ink. press it. open the front pannel. take cartride out and put new one in. close front panel. printer will ask if it is a new or old cartridge. 1 for new 2 for old.
Sep 12, 2011 | Samsung SF-330 Plain Paper Inkjet Fax
How do you change the ink cartridge on samsung sf31oo
Hi
It's very easy to remove the ink cartridges of Samsung printers. I have provided you the link to download and see the manual of the printer you are using, please go through the weblink and you can easily remove the ink cartridges.
Here is the weblink
http://www.samsung.com/in/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=06011300&prd_mdl_cd=SF-371P%2fXIP&prd_mdl_name=SF-371P
Jan 28, 2010 | Office Equipment & Supplies
Replaced Ink on Samsung SF-330 and still says install ink
There is something wrong with the cartrige head. First try to take out the cartrige and in the head there is contact points. You can try and clean it with a dry cloth.
Aug 18, 2009 | Samsung SF-330 Plain Paper Inkjet Fax
Samung Sf-330 fax.
probably you did not fix properly the ink cartridge.check the cartridge for proper seating.
Jun 02, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Samsung SF560.
Check if there is a fuse in place (usually fitted to the front edge of the cartridge) and always replace when refilling.
Aug 31, 2007 | Samsung SF-560 Plain Paper Laser Fax
Receiving faxes
tHE INK SEEMS TO HAVE FINISHED, DOES THE DISPLAY SHOWS,-INK LOW OR EMPTY, REPLENISH THE CARTRIDGE AND THE FAXES WILL BE PRINTED FROM MEMORY.. HAPPY FAXING OMNIPRESENT
Aug 24, 2007 | Samsung SF-4700 Plain Paper Inkjet Fax
Nothing prints on the paper for incoming faxes or copying a document.
i suspect you are correct in cleaning the unit.inkjets if not used often enough the ink will clog the print head. usually the easiest solution is to keep cleaning unit it works again. other wise to clean the print head manually requires the unit to be completely dissambled. it takes a long time to fix it this way. or if replacement costs are acceptable you can replace it. i would just give it a dozen or so more cleanings.
Aug 23, 2006 | Samsung SF-335T Plain Paper Inkjet Fax
728 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
