Question about Sport & Outdoor - Others
I have a Treadmill JL401 Made in China.The unit problem is speed not consistence,some time fast so time slow...I found it's a IC control the speed having problem.IC no is SyncMOS SM8958AC25P. there is a unit selling in EBAY but it's a blank unit need to program,I don't know how to program.....
    President:
  • 1,961 Answers
There are 4 companies that offers reprogramming of this ic, three of them are based in taiwan and one is from china.
Below are the contacts:
1. Advantech - 7F, No.98, Ming-Chung Rd., Shin-Tien City, Taipei, Taiwan, ROC
http://www.aec.com.tw
Tel:02-22182325
Fax:02-22182435
E-mail:
aecwebmaster@advantech.com.tw
2. Hi-Lo - 4F, No. 20, 22, LN, 76, Rui Guang Rd., Nei Hu, Taipei, Taiwan, ROC.
http://www.hilosystems.com.tw
Tel:02-87923301
Fax:02-87923285
E-mail:
support@hilosystems.com.tw
3. Leap - 6th F1-4, Lane 609, Chunghsin Rd., Sec. 5, Sanchung, Taipei Hsien, Taiwan, ROC
http://www.leap.com.tw
Tel:02-29991860
Fax:02-29990015
E-mail:
service@leap.com.tw
4. Xeltek Electronic Co., Ltd - 338 Hongwu Road, Nanjing, China 210002
http://www.xeltek-cn.com
Tel:+86-25-84408399, 84543153-206
E-mail:
xelclw@jlonline.com,
xelgbw@jlonline.com
I hope this information will help you...
Posted on Apr 06, 2011
  • Danilo Baraquiel
    Danilo Baraquiel Apr 06, 2011
    I must inform you, programming of IC can not be done if you don't have the copy of the program and the machine that will be used to program the IC..
Treadmill speed is going fast when I have it at 2.5
Your variable resistor (speed adjustment switch) is going out
Mar 23, 2016 | Sole Fitness F63 Treadmill
How can I slow down a Sportcraft TX 320 treadmill?
Hi There, hmmm.... am I hearing that the treadmill starts too fast? At over 1mph? Most US treads will start at 1MPH and some will allow selection of .5MPH in the maintenance mode settings maybe. Otherwise, this could be attacked by a technical crew, like jatinah electronics possibly. If the treadmill would be set at one speed only that could be accomplished by reducing the drive signal at the component-level. It is certainly workable, but I would need to know what the current speed is that is too fast for her, and her ideal speed. ;o)
Jan 15, 2015 | Sportcraft Exercise & Fitness
Technofit ts500I treadmill When its running the treadmill starts and runs fine. However when I get on it, it the speed becomes jerky running slow fast slow fast making it impossible to use.
If someone spilled a drink on the belt, it will become sticky as it dries. The belt will try to stick to the bed of the treadmill. Loosen belt, wipe clean the bed, underside of belt, and end rollers.
Apr 24, 2014 | Exercise & Fitness
Inconsistent Speeds and Motor Smell
A new treadmill is in order! It sounds like the motor is either old, or it has a factory default. Definitely do not use the treadmill if it produces burning smells this is in fact the wires in the motor heating up and melting this could cause a fire.
Jan 23, 2014 | Advanced Fitness Group AFG 1.0 AT Folding...
I have a Proform 1026 EXP treadmill that began running at full speed whenever it is turned on. The incline controls function normally but the belt speed is incredibly high. When set to 1.5 MPH (the slowest...
please run the Software calibration see the instruction.
GOD BLESS you
The Steps for Newer Style Console Calibration
1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10. Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Sep 18, 2013 | Proform 1026 Exp Treadmill Motor Control...
I need the I.C number on a Lifegear Walkease Motorized Treadmill # 97295, found out the ic was burnt on the control panel whicl always display E2 code
Dear Sir:
1)In electronics, you must need to get the number of IC.
2)If you get some information like as the number of the Control Panel, will be more easy to find, the I.C.
3) You must shure the why the I.C. was burn? . Normally this problem can occur a) failure for some short of some component around the I.C. b) Power supply +5 or 12 Vdc or Low or Higher( Indicating that power supply is Not Good).
4) Would you please tell the exactly Model, Mark, Serial from your Treadmill? In that way I can help you more, and try to get the Schematic Diagram from your Fitness Treadmill.
Sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 24, 2011 | Exercise & Fitness
I have a Reebok 9500 Es Model: rbtl14506.0 this unit once you turn it on and hit the up speed it speed up to the max speed and no controll will respond to slowing down and all controll stop working and...
hi,
You have to check the Driver circuit board for the motor. There is motor control IGBT Insulated Gate Bipolar Transistor) in this board .If the IGBT is short then the treadmill will try to run without setting any value or witout pressing the start button. You have to check the OHMS between the seocnd and third of lead of the IGBT. If it shows less than 100 Ohms then the IGBT is short and you have to replace the same. Also you have to check the connection to the control pannel. Is there is any loose conatct. Remove the connection in the motor control board which go to the control pannel and reconnect it. Also check the speed sensor. In most of the treadmill you can find the speed sensor near the motor pully. Remove the speed sensor and clean it and the refix it. Remember one thing remove the power of the treadmill and leave it for 30 minutes then only oppen the treadmill. Because there is high voltage storage capacitors in the motor control board which will hold charge for some time even after the power is disconnected. i ahve added the picture of IGBT for your refference
ok
Aug 13, 2011 | Exercise & Fitness
My treadmill is a proform 345s crosswalk. It doesn't keep a constant rate. This just began this morning. It speeds up then slows down and it's impossible to exercise with the variance. What's going on?
You may have a belt and deck problem. Test by the following procedure: without the power on stand on the walking belt, push the belt in the direction it normally turns, if the belt is very difficult to turn (on most treadmill) this means that you have high belt/deck friction. Apply silicone lubricant between belt and deck beginning laterally at the motor shroud to end of the rear roller on each side
The deck should be smooth without any grooves, pits, or exposed wood. The belt should have a consistent ridged feel from one side of the belt to the other (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Visually look at the underside of the belt. It should have a consistent look. Black streaks in the belt are a sign of bottom-layer wear through. Very worn belts will feel smooth in the areas you normally walk- you would think smooth is good but not in belts because the smoother the belt, the more contact area. On occasion, you may have already damaged the DC board if you have high belt/deck friction. If the belt walks freely, you have a different problem. 2. If it passes the belt/deck checks, you may have a DC board output problem. If the belt tests ok and you have a speed variation, try this test:
Set the speed to 2.5 MPH. Let the treadmill run without anyone on the belt. Check to see if the speed is constant or if there is a variation.
If there is no variation, step on the belt. If the speed slows down or speeds up, you may have an output problem on the DC board. This is the board that connects directly to the motor.
You may have a short in the motor. If you turn the machine on and have erratic speed, you could have a problem in the DC board or the motor or both. With a simple multi-meter, you can test on the continuity scale to see if you have a closed circuit between either DC motor lead and the common earth ground. You should always have an open circuit.
You may have a speed signal problem. Your controls on the upper panel send a signal to the lower electronics to help them set the appropriate speed. If there is a problem in the signal generator, the communication links, or in the feedback links, you will have erratic speed operation.
Communications test- Look on the board for a flashing signal as you increase speed on the treadmill. Most boards have a signal feedback test light. If a LED flashes, your communication is ok.
Feedback test- If your unit is equipped with an optical feedback (disk inside a sensor) you can swap the feedback unit with the incline (it is the same part on many Icon machines). If it tests ok, you don’t have a problem here. If it is a magnetic feedback unit, you can test continuity with a multi meter or replace with a new part to test. Many times passing a kitchen magnet in front of the signal will make a speed display on the console if the magnetic sensor is good.
Signal Generator- If you have a problem with the signal generator, your speed will be erratic with either a person on the machine or without a person on the machine. You may even get a speed error code from the unit.
Jun 15, 2010 | Proform CrossTrainer Treadmill
Sport & Outdoor - Others Logo
26 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
