Its lock..and the lock button sign is blinking we cant do our laundry ..how to unlock it.? thanks hope u can help us
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 06, 2011
Frigidaire FFLE2022MW washer dryer combo beeps twice and stops during all washing cycles after it fills with water and lid is still locked. Does anyone know how to correct this? Thanks
Thank you for your inquiry, Criss Ard!
From my understanding you are having issues with your Frigidaire laundry center not starting a cycle. You stated that the washer fills with water then locks. It sounds like your timer is not advancing and that could be due to a faulty timer or wiring harness. You may want to perform a reset on your laundry center and you can do that by disconnecting the power cord for roughly ten minutes. If this troubleshooting step does not help resolve your issue you may want to consult with a professional technician for proper repairs. I hope this information is helpful. -Matt
Feb 20, 2015 | Frigidaire White Electric Washer And Dryer...
Kenmore dish washer lock button blinks and doesn't run
Hi
Thanks for using FixYa. To unlock the controls Press and hold Air Dry/No Heat Dry for 5 seconds or until the light turns off. Please revert back for more help.
Rylee
Dec 23, 2011 | Dishwashers
My dryer is locked and I have a tub full of wet clothes. Sorry, can't find the manual how to fix.
If it's your washer that is locked, the manual suggests you press the START/PAUSE/UNLOCK button. It says the lid will unlock once the washer movement stops and it might take several minutes if it was spinning at a high speed. You can resume the cycle by pushing the Start/pause/unlock button again.
I really hope this is the answer you need. There is nothing more frustrating than a load of wet laundry. If this helps, please come back to Fixya and rate my advice. Thanks and good luck!
Jul 29, 2011 | Whirlpool Dryers
I have a whirlpool washing machine, M 31062, WTW4950XW0. I am attempting to use it for the first time and the Sensing Light is coming on when I press START. The Lid locks and there is a noise like the...
I have a Whirlpool model WTW4950XW0. Once i push the start button.
The lid locks, sensing lite on, machine goes through its cycle, than lid unlocks
monents later.What wrong. I was doing laundry and notice the machine making some noise on the spin cycle. I push the pause button and remove some clothes.
thats when the sensing lite keeps blinking.
thanks
Rich
Jan 01, 2011 | Whirlpool Washing Machines
Philips freeview digi box dtr1500
thanks my daughter solved the problem to unlock parental lock or parental pin number she tried four zero digets 0000 no success then she put in four numbers one 1111 and it unlocked the parental lock .hope it can maybe help someone - margaret
Oct 01, 2009 | Philips Universal PH301S Remote Control
Message blinking at the centre of monitor
OSD Unlock : Press and hold the [1] and [▼] buttons again for 5 seconds. The message “OSD UNLOCK” will then display briefly, indicating that the OSD image settings are now unlocked.
You will find that and other information in the manual located here. The above information is found on page 7.
Hope this helps. Please remember to rate this information.
Thanks
May 13, 2009 | ViewSonic E70fb 17" CRT Monitor
Help with ipod 8gb nano
Reset your Ipod using the following procedure:
Turn hold on (lock)
Turn hold off (unlock)
Hold in Menu button and middle button until Ipod shuts down and starts up again.
This should remove the lock on the Ipod.
Mar 08, 2008 | Apple iPod nano
Kenmore Elite HE4t Washer - "Control Locked"
I had the same problem. If you will hold the "Drain & Spin button" in for approximately 4 to 5 seconds it unlocks the " Control Locked" issue.
Dec 18, 2007 | Kenmore Elite 45986 Front Load Washer
I need help
un plug your machine for an hour if you can open the door open it and then put the machine plug back in with the door open keep it open till the machine comes on then put the program to what you want and then shut the door it then should be ok its called a reset try it hope this solves your problem
Aug 26, 2007 | LG WM2077CW Laundry XL Front Load...
I pressed and held drain/spin and it unlocked the controls... try it and let me know.
Nov 25, 2006 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
