Question about Measuring Tools & Sensors
I need to test the element in my fan oven i cannot remember how to use my multi meter can you help alan
  • 17,129 Answers
Remove the power connection of the Oven., Now turn the selector of the multimeter to the OHMS range. Select the lowest range and on shorting of two leads - positive an negative- you will get a deflection in an analogue meter and a -000 - in a digital meter.
Now hold the two probes to the either ends of the coils and if is shows a deflection or reading the coil is good, if there is no action the coil is OPEN.
You can thus check the continuity of the power cord wire from the plug to the oven.
Posted on Apr 06, 2011
I Have a whirlpool gold accurate system microwave /oven combo Self cleaning and broiler is not working . Regular oven works . There are no error messages . What is causing this
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
Dec 30, 2015 | Whirlpool Ovens
The bottom oven is not functioning properly. When turned to fan oven the fan works intermittently and the element intermittently glows red hot
1.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
May 04, 2015 | De Dietrich Ovens
Why is the oven base element not working on kenmore range model c880
First step is to test the element itself, using a multi-meter. Next switch is to test the switch, also using a multi-meter. This is not really a job for someone who needs to ask such questions so I suggest you find someone who already owns a meter. Electricity kills.
Aug 30, 2014 | Kitchen Ranges
How much would it costs to replace heating element on Whirlpool gas oven.
I would not replace the elements just yet it may be ur oven safety valve, u can test the elements with a multi meter for continuity and ohms..
THINGS TO CHECK:
the broil element
The bake element
I offer free advice bcuz God is so good!
Jul 15, 2014 | Whirlpool Ovens
Replaced oven element still not heating up
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
Feb 15, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Oven is not heating up
The bake element
Surface burners
The infinite switch
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Feb 10, 2014 | Kenmore Ovens
FAN IN OVEN WORKING,BUT NO HEAT.HOW DO I TEST TO C IF ELEMENT AT FAULT
Turn off power to oven and double check power is off...remove rear panel and take a multi-meter on ohms scale and check elements. if your unsure of how to do this..the voltage can be checked at element. BUT, its 220 so be extremly careful
Jan 18, 2011 | Ovens
My oven DOP340 wont heat up and the fan doesnt
THINGS TO CHECK:
the broil element
The bake element
Oct 05, 2009 | De Dietrich DOP390 Pyrolytic Electric...
The fan and oven light in bottom oven works but not heat.
The heating element is the likely culprit as they burn out and go open
circuit..(ie ...disconnected and will not heat up )
If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
Aug 30, 2009 | Neff U1721 Double circotherm Electric Oven
Neff cooker not heating up
Hi, it feels like your oven element has gone.
switch it off from the mains, open the door and remove the screws fixing the back panel. You will find a round two turn element. Unscrew the element fixings and check the element for burnt marks, corrosion. If you have a multi meter, turn it to buzzer and use the meter leads to test the element connections. If it doesn't buzz, it's dead. Just needs replacing.
Cheers
Feb 15, 2009 | Neff U1721 Double circotherm Electric Oven
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
