Question about Microwave Ovens
Kitchenaid hot water dispenser installed (model KHWC160PSS) it was not plugged in till tank was filled, yet no hot water?
  • 126 Answers
Check the thermostat on the tank and see if its turned up u might have to adjust
Posted on Apr 06, 2011
Kitchenaid installation instructions
You can download Kitchenaid, Whirlpool, and Maytag owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 27, 2012 | KitchenAid Microwave Ovens
How do you clean a Tim Hortons home coffee maker. This model has the heated water reservoir with a pot of hot water always ready
UNPLUG IT FIRST, SAFTY FIRST
LET IT COOL OFF,
EMPTY THE WATER AS MUCH AS POSSIBLE
THEN CLEAN WITH 409, OR MR CLEAN, OR WINDEX WITH
A LITTLE BIT OF VINEGAR ADDED ( ABOUT 3 ~ 4 TABLESPOONS )
TO HELP IN CUTTING THE GREASE
THEN BEFORE YOU PLUG IT IN, ADD SOME WATER TO THE TANK,
PLUG IT IN, RESET YOUR CLOCK { IF YOURS HAS A CLOCK }
AND ENJOY !! dd
Feb 05, 2011 | Microwave Ovens
Have Kenmore sid-by-side refrigerator: 7909621940B - Just changed water filter. Now, no water or ice dispenses. Ice maker is making ice - filled the bin over a few days. But, when I push to dispense...
We also have a kenmore side by side refrig and had the same problem,,,
FIRST, CHECK THE CONNECTION BETWEEN NEW FILTER AND ATTACHMENT POINT,,
IF THE RUBBER GASKET CAME LOSE DURING THE CHANGE, IT MAY BLOCK THE PATHWAY FOR WATER TO FLOW
NEXT, CHECK THE WATER/ICECUBES/CRUSH LEVER SWITCH TO MAKE SURE IT IS NOT PART WAY BETWEEN ONE OF THE SETTINGS,
NEXT,CHECK TO SEE IF YOUR UNIT HAS A RESET BUTTON,
THE RESET BUTTON IS USUALLY IMMEDIATELY INSIDE THE OPENING WHERE THE WATER/ICE DISPENSES AND UP, YOU WOULD NEED TO PLACE YOUR FINGER RIGHT DIRECTLY UP BEHIND THE FRONT PLASTIC COVER, AND IT'S GOING TO BE A VERY SMALL BUTTON, I AM NOT SURE WHICH SIDE ON YOUR UNIT R OR L, BUT DIRECTLY UP IN THE CORNER,,
I HOPE ONE OF THESE HELPS !! angi
Dishes are not getting clean particularly in the upper rack. The soap dispenser opens properly but the soap was still there. The washer seems to fill properly and it sounds normal. The dishwasher goes...
Make and model?Is the water hot enough? Is this a new problem? Is all of the detergent still in the dispenser or do you use detergent both in the washer and the dispenser? Please reply to this inquiry for more help. Do you have the manual?
Jan 07, 2011 | Microwave Ovens
Inserted K cup and closed machine. Says Brewing but coffee machine only dispenses a few tablespoons of water...tried turning machine off and off, but same amount of water is dispensed each time, no matter...
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Jan 01, 2011 | Microwave Ovens
I am unable to use the Bellagio water cooler now as the cold water dispenser is leaking. There is a constant drip so I had to remove the water bottle, then drain all the water from the reservoir. I have...
Go to www.super-electric.com and send them a message about your problem. They have parts. I can't tell you if they will help you or not, I have just emailed them today as well. I have both sides of my 1 year old water cooler leaking, model W074DRF11BQD. (from Zellers) I have hardwood floors and I would rather throw this unit away than risk water damage. If anyone is reading this and thinking of purchasing one of these Bellagio water coolers, spend your money elsewhere - THEY LEAK!. My husband is very handy and has just spent 2 hours on it with NO success. The parts are defective - this unit is NOT full of complex working parts. One plastic part causes pressure on the valve and causes a leak(s). After light usage and nothing damaging it, 8 months old one side went and the other side has been leaking for a couple of days and we are just coming up to a year. If anyone else had this problem and fixed it, I would love to hear the solution.
Dec 26, 2010 | Microwave Ovens
LG refrigerator model #LRFD25850TT water dispenser no longer working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. Or use a hairdryer on the inside of the door below the dispenser.
My KitchenAid microwave oven's model number is KCMS185JSS-4. Manufacture date is July 2005. It's been working fine until today, with an occasional glitch in the digital readout... sometimes the letters...
Either your high voltage rectifier or magnetron (or both) has failed.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
Sep 30, 2010 | KitchenAid Microwave Ovens
After the soap dispenses, there is a buzzing noise but no water seems to be spraing
sounds like the water valve . ck it for rust of hard water build up as if the water can't get through it it will not fill . water should be up to the element . or about 2 1/2 gal .. if water is not in tank add some and se if it works then ck the float to make sure its ok. the buzzing could be the motor hum . **** hope these hepled to find the problem .. **** .
Jan 04, 2010 | Westpoint TV-201 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
