Question about Bosch Dishwasher Micro Filter 428216
I have a Bosch dishwasher (SHV4303UC/U11). Can you tell me how to get the microfilter apart so that I can clean it. David Miller, Syracuse, NY.
COXY
  • 76 Answers
SOURCE: Bosch Dishwasher
The reason it is doing this is because the anti flood valve is either stuck or you have a leak in the bottom of the dishwasher. if you tip it back slightly does water come out? if so you have a leak, If not take the front panel of and you will see a round polistorin disc, make sure this is not jammed etc, make sure you unplug machine first.
Posted on Nov 18, 2007
  • 33 Answers
SOURCE: dishwasher repair
make certain that there is water coming into the d/w if so and you are sure that the solenoid on the water valve energizes then its possible that the strainer on the water valve might be clogged if so its going to take a bit of work to remove and clean the strainer and reasemble it are you confident .
Posted on Dec 31, 2007
  • 250 Answers
SOURCE: dishwasher finis tone
  • Open door, push and hold Delicate/Econo button, then turn the dishwasher on while holding Delicate/Econo button.
  • Release Delicate/Econo button.
  • If module beeps, then end of cycle tone is on. PressDelicate/Econo button to disable tone.
  • If module doesn’t beep after button is pressed, then tone is disabled.
  • Turn off dishwasher to save selection.
Posted on Jan 27, 2009
jumptrout51
  • 3361 Answers
SOURCE: Bottom of my Bosch dishwasher not cleaning dishes,
Carefully inspect the lower spray arm for a crack or separation.
Also inspect the holes in the spray arm that may be stopped up with debris.
Remove and clean the filter in the front center of the tub.
Set the spray arm at the 12 o'clock position and start the washer. After 30 seconds open the door and check the position of the spray arm. Do thi several times to confirm the spray arm is rotating.
Posted on Feb 26, 2010
Macmarkus
  • 2605 Answers
SOURCE: I Have a Bosch SHU5312/u11 that is showing 2H on
To answer your first question, in a word Yes. To address the second question, Yes. The control module is easy to replace but the better news is it is also repairable, ( you can make an educated decision when I'm through on whether to replace or repair, that is obviously up to you ) but I'd like to enlighten you if you'll allow on what to look for, and why.
The issue with your Bosch dishwasher likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). This is why it runs forever unless pressing the two buttons for "cancel". It has nothing to do with a "delay". The 2H stands for two hours and is actually the estimated time the unit took to complete it's previous cycle based on data to the control gathered and stored in memory...it is not "actual" time, it never is on Bosch. there are far too many variables to be "actual" time and since it only goes to two hours in the display, that's what is displayed even if it runs for four hours.
To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s at 2H ( because it can`t heat to advance or until canceled ) trying to heat the water.
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question's, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied.
Good luck.
macmarkus :)
Posted on May 01, 2010
Can I exchange the white door panel for a stainless steel panel on Bosch Dishwasher SHU5312UC/U11?
from my research all but 3 models have that option, I didn't see yours there, But if you contact sears or www.homeeverything.com I'm sure they can assist you
May 18, 2011 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishes not getting clean - a film is left on the glasses and plates - we tried cleaning the bottom tray and filter out but didn't help shv4303uc/u12 is the built in model #
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Sep 18, 2010 | Bosch SHV4803 Dishwasher
Need to replace drain hose on bosch dishwasher model shv4303UC/11
Hi, Welocome to Fixya. You just need to remove the small plastic holding tab at the back where the hose exits the machine. Then along the left side ( from the front...right side from back ) remove the side panel and the hose will simply pull out of place. Hope that answer's your question, let me know how you make out. Thanks for visiting "fixya" today. Please take a moment to leave a comment and also rate the solution provided accordingly. Good luck. Macmarkus :)
May 29, 2010 | Bosch 24 in. SHV4303 Built-in Dishwasher
Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
Bosch Dishwasher. Mushroom float
I have a guide here that covers problems with the drainage functions and also the float switch. It is on the left side as viewed from the front, and it's behind a panel held on by 2 - T-25 screws. Be careful that you do not break the plastic holding the switches in when you take it apart. you will need to clean the float thoroughly.
Feb 07, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher finis tone
Jan 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher repair
Dec 12, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch Dishwasher
Nov 16, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch Dishwasher Micro Filter 428216 Logo
88 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
