Question about Icom IC M504 Black Submersible PLUS Marine VHF with Class D DSC ()
I have an icom marine radio m505 (nearest model) which I bought over two years ago. The channels were very quiet including channel 16 so I tested it with local coast guard. I can transmit but cannot receive. The problem would appear to be with faulty squelch control which is blocking receipt. Any solutions , if repair is required where is the nearest agent Kind regards Paul Dobbyn Dublin Ireland
    Sergeant:
  • 331 Answers
First of all check if your antenna cable is in good shape.
Check if there are no shorts in the connectors between the center lead and the screen tress.
Also check if the center lead is soldered into his connector pin on each connector on the cable.
Set squelsh just out of the noise zone.
Posted on Sep 25, 2017
SOURCE: Handheld Marine Radio
This applies to all battery powered radios. Take out the battery and measure the voltage to see if it is indeed charged. If it's not, then the fault is the charger or the battery or both. If the battery voltage shows that it is fully charged, then clean the terminals on the battery and on the radio with a pencil eraser to remove any corrosion. If still no joy, then look up in your user's manual on how to do a reset. If you don't have a manual, get on the ICOM website and download one.
Good luck.
Posted on Nov 16, 2008
  • 64 Answers
SOURCE: radio turns on , channels change, but no sound or
It sounds like your vhf speaker has failed. I recommend taking your radio to a repair shop and replacing the speaker...this should solve your problem.
Posted on Jun 24, 2010
SOURCE: I have an ICOM-504 . I can transmit but I can not
I had the same problem and traced it to a bad connection between flex cables and boards.It seems the SQL signal from the Rx board is not reaching the processor on the front panel. Check all connections (reseat all cables) and try again.
servstan
Posted on Aug 19, 2010
reyjoshua07
  • 1157 Answers
SOURCE: Icom M710 Transceiver dosen't transmit.
Hi mesquaukee,
Are you trying to connect the SCS PTC-IIpro to an Icom M710 (or M700pro) marine transceiver? If you do kindly refer on the information below:
The audio connections are the same as the PTC-II/IIe, the radio-control connection is specific to the IIpro.
Audio connections:
PTC-IIpro Audio Icom M710 ACC(1)
(8-pin SCS DIN) (8-pin Icom DIN)
(Tx audio) Pin 1----(vio)-----Pin 4 (Mod)
(Rx audio) Pin 4----(grn)-----Pin 5 (AF out)
(PTT) Pin 3----(yel)-----Pin 3 (PTT in)
(Gnd) Pin 2----(wht)-----Pin 2 (ground)
(+12V) Pin 5----(blu)-----Pin 7 (12V out- see note)
Shell---(shield)---Shell
Notes:
1. The colors shown above are for the pigtail cable supplied with the PTC-IIpro. Check the colors with an ohmmeter, errors are possible.
2. The German-style DIN connector has a different physical pin geometry, and is not interchaneable with the US-style DIN connector used by Icom. Label the cable ends to avoid any confusion over which end goes where.
3. The PTC-IIpro has provision for an alternate 12V input on its HF audio connector. This provides a convenient way to connect power to the modem, but if the cable is particularly long then this could be a source of RF interference. Consider a separate power connection for long cables.
Remote Control:
Remote frequency-control is optional, but highly recommended when a PTC-IIpro modem is used with an Icom M710/M700pro transceiver. There are two options for connecting remote control to the radio, the recommended connection is to use the M710's 9-pin "Remote" connector (supported from Airmail ver 3.0.857 onwards). As an alternative, the 1/8" mini-phone "Clone" jack can be used, see "option 2" below.
PTC-IIpro "Control" ICOM 710 "Remote"
(13-pin DIN) (DB-9P 9-pin male)
Pin 3 (yellow) -------- NMI+ 5
Pin 8 (red) ----------- NMO+ 7
Pin 13 (orange) ---+--- NMI- 6 (see note)
+--- GND 9
Shell ----(shield)----- Shell
Note: Add a jumper between pin 6 and 9 on the 9-pin connector, so that the (orange) ground wire connects to both pins. Also make sure that unused wires are carefully insulated, short-circuits can damage the radio or modem.
Radio Settings:
In order to use the NMEA interface, it must first be selected using the front-panel "Set Mode" functions (turn power on while holding down the "Func" and "1" buttons-- or "Ent" and "1" for the 700 pro). Select the "REMT-IF" (remote interface) setting and change it "d-Sub" (or "RS-232" on some models). Also check that the "REMT-ID" setting matches Airmail's "AIcom Addr" setting).
AirMail Options Settings:
Modem (TNC) connection:
Modem type: PTC-IIpro
Comm port: COM1 or as appropriate
Baud rate: 38400 or 57600
Show link messages: no check
Ignore CTS: no check
Audio Tones:
Center Frequency: 1500
Check "USB"
Check "Marine (FSK dial=center)"
Amplitudes: as appropriate, start with 130/170
Radio connection:
Check "Direct using PTC-II control port"
RS-232: Checked (this is important!)
Radio type: "Icom-M710" (select appropriate model)
Baud: 4800
Icom Addr (hex): 01 for M710, 02 for M700pro, or 03 for M710RT (must match radio's REMT-ID setting)
Dial offset: 00
Note: Entering the radio modes with the "Modes" button is no longer required.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 14, 2011
Ironfist109
  • 3018 Answers
SOURCE: I had a ICOM IC-M505
  • Icom's are a nightmare when programming MMIS frequencies into it.
  • Here is the manual http://www.icom-france.com/files/not-IC-M505-angl.pdf
  • For starters you want to reference page 7
  • Then go to page 15 - 53 (chapter 6) for the programming / transmitting / receiving procedure.
  • This is not a simple procedure. It will take some fooling around with and lots of time.. Every HAM has to master their radio. I urge you to read that section of the manual and follow it step by step and don't get over frustrated at it. It's gonna take some time for you to get the hang of this part of your radio.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Aug 09, 2011
Ic m505 not receiving
turn the squelch down? the RF gain down too
do you have an attenuator turned on ?
Apr 01, 2014 | Icom IC-M505 - VHF/DSC Marine Transciever
Icom m505 no rx
See the sensitivity if it is low then change the filter (wide) of your Radio.
May 23, 2013 | Icom M505 VHF/DSC Marine Transceiver -...
W do I turn off squelch control on a digitech DC-1065 marine radio hand held 5 Watt
Hi David,
Before I try to give advice, I need more info.
I possess a Digitech DC1065 UHF 80 Channel CB hand held, so there seems to be some confusion here.
I live near Perth, Western Australia.
Firstly, How many channels does your radio have?
If the answer is 80, then what you have is a UHF CB, not a marine band radio.
Marine band is VHF with 87 Channels, in Australia that is, and the default channel is always 16.
Digitech are an Australian radio manufacturer, so you'll get great backup service.
If your radio is not defaulting to Ch16, then I am right about it being a UHF CB.
Therefore, it is useless for VHF anything, let alone Marine band.
I'm almost 100% sure this is a UHF CB in your possession.
Try this to prove me right please.
Reply to me with your Country and nearest city, I'll then be able to find a solution for you real quick, though I believe I already have.
Looking forward to your response.
Regards,
Peter
Dec 21, 2012 | Motorola Walkie Talkie 2-Way Radio
Radio not receiving on any channel
Hi Mike,
The manual for this radio (in Adobe .pdf format) is available for download directly from Icom America, free of charges.
Since the "AquaQuake" function works and you do hear static when the squelch is off, that is sufficient to let us know that the voice coil of the speaker is functional and should produce sounds with the right signal applied.
The first thing to determine is if you're close enough to another operating transmitter for the radio to receive a signal. One of the 10 weather channels the radio is capable of tuning should be close enough produce some intelligible audio from the speaker - assuming the squelch setting isn't set too high.
If a WX channel works, then you'll need to see if there's a VHF Marine band transmitter operating nearby. You might need to set another Marine band radio receiver up to verify that there is indeed a signal present on the particular Marine band channel that you're monitoring. A list of frequencies is published on pg 27 (of the manual linked above) in case you need to convert between channel and frequency to tune on a non-channelized radio.
Outside of that, there's little the end user can do without specialized test equipment, schematics and of course, training. Many shops will be happy to provide an estimate for repair when provided with a small bench diagnostic fee. This fee is usually applied towards an authorized repair by most reputable repair shops.
I hope this helps & good luck!
Nov 27, 2012 | Icom Ic-m34 Vhf Waterproof Marine Two-way...
On the ICOM M604 will not receive the weather channels, will receive other close radio's.
Hi!
This is almost ALWAYS caused by a problem (a short OR an open) in the coax cable from the VHF radio to the antenna. An easy way to check is to JUST insert the PL-259 connector into the socket of the radio, making sure that ONLY the center pin is making contact with the socket. If the weather channels come in clearly, then it's usually an easy fix. Simply check the connections at each end of the coax, looking for a poor center pin solder connection or perhaps a bit of the ground braid is shorting out the center lead. A magnifying glass is a great tool to spot problems.
If the coax proves NOT to be the problem, then the fault is likely to be in the radio itself and is probably a bad solder connection where the antenna chassis mount attaches to the PC board.
Hope this is helpful.
Good Luck!
Jan 09, 2011 | ICOM Informatique Icom M604 Vhf Marine...
Radio turns on , channels change, but no sound or squelch..
Jun 16, 2010 | Icom ICM422 FixedMount Marine VHF Radio...
How to add frequencies/channels to ICOM IC-F21 two-way radios?
Sorry, but your radio is limited to 16 channels in the 400-430 and 440-470 MHz ranges. The number of channels cannot be expanded, nor can the frequency coverage.
Bill B
Mar 28, 2010 | ICOM Informatique Icom IC-F21 16ch UHF...
1 have a icomf3s-3 32 channeli can ony see 16
Hi, the problem is you only have 16 channels programmed in the radio. you can program the full 32 if you have- the software, http://hamradio.online.ru/ftp/dw.php?icf3f4.zip . And the programming lead- http://cgi.ebay.co.uk/USB-Interface-cable-for-ICOM-IC-v8-Radios-6-030_W0QQitemZ330356207021QQcmdZViewItemQQptZUK_ConsumerElectronics_SpecialistRadioEquipment_SM?hash=item4ceac3adad&_trksid=p3286.c0.m14
Hope this helps.
Aug 16, 2009 | ICOM Informatique Icom Radio IC-F3, IC-F4,...
Screen locked can 16 (model HX270S)
Hi there, I think you might have the priority channel switched on. Look for a button labeled PRI or somthing like that, press it once or if that fails press for 3 seconds.
Apr 24, 2009 | ICOM Informatique Icom IC-F11S 5W 2ch VHF...
Icom IC M504 Black Submersible PLUS Marine VHF with Class D DSC () Logo
138 people viewed this question
Top Icom Boating Experts
Steve
Steve
Tony
Lawrence Oravetz
Are you an Icom Boating Expert? Answer questions, earn points and help others
