Question about MinoltaFax 2600 Printer
Polygonal error on a minolta fax 2600 - MinoltaFax 2600 Printer
  • Minolta Master
  • 6,161 Answers
First check the connection between main control board and print head. The Print Head house the LASER and a motor called the polygon motor which is use to spread the laser bean across the drum. IT move at about 35,000 rpm some time you can hear it when machine turn s on, so check the connection if good get a new print head worse case the control board is bad
try below web site they mite have parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Posted on Feb 22, 2015
I have a Konica Minolta C6500 and I have error code C4717 what can be done
Index sensor output does not
change by the execution of
APC. Index sensor cannot
detect the laser because the
polygon mirror does not rotate,
or because of the index sensor
out of position or defective index sensor
Basically the (Black print head/LASER UNIT/Write Unit) for Black drum is causing problems internally. Inside the unit the Index sensor output does not change by the execution of APC. Index sensor cannot detect the laser because the polygon mirror does not rotate, or because of the index sensor out of position or defective index sensor. Or one of the many control boards is causing issues with Black Laser Unit, such as:
Printer control board (PRCB)
Image processing board
(IPB)
I/F board (IFB)
Image memory control board
(IMCB)
Serious Cost for these boards, recommend a Konica Minolta Tech check this out. Sorry
Nov 03, 2015 | Konica Minolta Bizhub Pro C6500 Printer...
POLYGONAL ERROR / WHAT DOES THIS MEANS AND HOW I WILL REST IT... THANKS
Polygon error. There is a LASER inside the machine which hits a 5 sided minor spinning at about 35000 rpm. That minor is spun my the polygon motor. More then likely you have a bad print head. That is what the entire assy. LASER/motor/Minor/Sensors are called. Power off/then on if it comes back have a technician looks at it.
Feb 26, 2013 | Minolta MF2800 Plain Paper Laser Fax
On my fax Minoltafax 2600, I have the following error message "error polygon" and the fax does not work anymore, what has the engine polygonal can you help me please Thank you in advance
Polygon is the motor that is located inside the FAX print hear which is where the LASER is located. Have a technician (Konica Minolta) have him check the connection between the print head and its control board. If not need a new print head or worse the control board for the whole machine.. The polygon motor is what makes the LASER beam move across the drum to place the image on the drum, it travel around 35.000 RPM, you mite heard it as very high pitch as gets up to speed. So the LASER and the Motor are inside the PRINT HEAD.
Jun 07, 2011 | MinoltaFax 2600 Printer
Error code c4101
Error cod C4101
Machine Konica Minolta c6500
Nov 25, 2009 | Minolta bizhub 200 All-In-One Printer
Polygon error
Bad laser unit, uneconomical to repair.
Oct 22, 2009 | Sharp FO 2950M Plain Paper Laser Fax
Our minolta fax 2600 is showing us we have a polygonal error
Not 100%, but I would say this referring to the laser unit.
Switch off/on...if no joy, it's probably an engineer job.
Jun 16, 2009 | OKIFAX 2600 Fax
Sharp fo 4700 display error ( polygon )
You have a bad printhead unit(laser unit) . The polygon mirror is not rotating within a specific amount of time. I recommend you to replace your fax unless your willing to spend between 200 to 500 dollars.
May 03, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Sharp FO-4650 fax machine
You have a bad printhead unit(laser unit) only if the problem persist. The polygon mirror is not rotating within a specific amount of time.
Feb 10, 2009 | Sharp FO 4450 Laser Fax
Minolta Fax 3600
Yeah, pretty much s(****). That message means the polygon mirror in the laser unit is not spinning up.
If you want to try to fix it, it's a square black box under the top covers. You can take it apart and oil the mirror shaft.
Sep 07, 2008 | Office Equipment & Supplies
MinoltaFax 2600 Printer Logo
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
