Question about Icom IC M504 Black Submersible PLUS Marine VHF with Class D DSC ()
I have an ICOM IC M505 marine VHF which is the closest model to the one described below. It is less than 3 years old. The channels have been very quiet including channel 16. This prompted me to test the radio with the local coast guard. While the radio will transmit it is not receiving. The fault would appear to lie with the squelch control which is blocking receipt. any solutions Paul Dobbyn Dublin
2 Suggested Answers
SOURCE: Handheld Marine Radio
This applies to all battery powered radios. Take out the battery and measure the voltage to see if it is indeed charged. If it's not, then the fault is the charger or the battery or both. If the battery voltage shows that it is fully charged, then clean the terminals on the battery and on the radio with a pencil eraser to remove any corrosion. If still no joy, then look up in your user's manual on how to do a reset. If you don't have a manual, get on the ICOM website and download one.
Good luck.
Posted on Nov 16, 2008
I need amounting brack for my icom ic m302 vhf marine transceive where can i get it
Try Ebay as a source. I have had good luck finding such accessories for reasonable.
Aug 20, 2014 | Icom IC-M302 VHF Marine Radio
Ic m505 not receiving
turn the squelch down? the RF gain down too
do you have an attenuator turned on ?
Apr 01, 2014 | Icom IC-M505 - VHF/DSC Marine Transciever
Icom ic-m35, no transmitting
Contact the Icom service center. Their main web-page is www.icom.com. From there you can select your geographic area and service (commercial, marine, amateur, etc).
Aug 17, 2013 | Icom IC-M36 VHF Marine Radio
Not transmitting
Contact ICOM service at www.icom.com, or take it to a marine radio service center.
Icom m505 no rx
See the sensitivity if it is low then change the filter (wide) of your Radio.
May 23, 2013 | Icom M505 VHF/DSC Marine Transceiver -...
IC-M302 VHF Marine Radio: need to have wiring schematic coming out the back ...
Blue: Speaker (+)
Gray: Speaker ( -)
Yellow: NMEA IN (+)
Green: NMEA IN (- )
May 17, 2010 | Icom IC-M302 VHF Marine Radio
I would lke to know the reference code on the audio out put ic, used in the VHF MARINE IC-M302.
Quick description as per ICOM Manuals:
Quote
The AF amplifier circuit amplifies the detected signals to drive a speaker. The AF circuit includes an AF mute circuit for the squelch. AF signals from IC1 (pin 9) are applied to the de-emphasis circuit (R61, C89). The de-emphasis circuit is an integrated circuit with frequency characteristic of –6 dB/octave. The integrated signals pass through the high-pass filter (Q5, R62–R67, C90, C91) to suppress unwanted lower noise signals. The filtered signals are applied to the AF mute circuit (IC7B), and then passes through the [VOLUME] control (VR board; R1) via the “VOL1” signal. The signals are applied to the AF power amplifier (IC6, pin 1). The output signal from IC6 (pin4) drives the internal (external) speaker.
Unquote
I thus assume the IC you are looking for is the IC described as IC 6.
Data sheet availible online: http://www.datasheetcatalog.org/datasheet/sanyo/ds_pdf_e/LA4425A.pdf
The IC is a Sanyo LA4425A. A 5W Power amplifier.
Apr 02, 2010 | Icom IC-M302 VHF Marine Radio
I have an icom m304marine vhf with a shakespeare
Sound like you have an antenna issue. Try a different antenna with coax. If the problem is still there, than you have a problem with the radio. Icom makes really good marine radios but you could have a defective one.
Jun 30, 2009 | Cobra Mr F75b Marine Vhf Radio Fixed Mount...
Good luck.
Mar 19, 2008 | Icom M302 VHF Radio
Icom IC M504 Black Submersible PLUS Marine VHF with Class D DSC () Logo
113 people viewed this question
Top Icom Boating Experts
Steve
Steve
Tony
Jeremy W.
Jeremy W.
Are you an Icom Boating Expert? Answer questions, earn points and help others
